GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
03-25-2013, 11:39 | #1 (permalink) |
Junior Member Join Date: Mar 2013
Member: 1906439 Status: Offline Thanks Meter: 0 | Call forwarding using AT commands and a USB modem (Huawei E160) There is a Gsm code available ("**21*number#") which switches the number from here to there. If I dial this number with a mobile all works well and the number is switched accordingly. If I put the Sim card into the USB modem and use AT-commands it doesn't work, although the modem always gives back an "OK". I use hterm to test this. The AT-commands I've tested with is: "ATD**21*+436641234567#;" "ATDT**21*+436641234567#;" The modem is voice enabled. A test call to my private mobile using "ATD+436641234444;" works well and my phone rings. Has anybody had this problem before and found a solution? Thanks in advance, Leo |
03-29-2013, 08:25 | #2 (permalink) |
Member: 1906439 Status: Offline Thanks Meter: 0 | Due to the lack of doc it turned out to be useless to find the right syntax for the AT commands. I use Software "gammu" now which works well on my RaspberryPi to establish a call diversion. |
03-29-2013, 16:25 | #3 (permalink) |
Freak Poster Join Date: Mar 2002 Location: Moscow, Russia Age: 53
Member: 10397 Status: Offline Thanks Meter: 45 | Data sets like "*some_stuff#" are not phone numbers but USSD commands. That's why ATD command doesn't work for this. You can use AT+CUSD command to send USSD. Google for tutorial - it's standard GSM command. For Huawei modems, it's often required to select a correct USSD processing mode (data coding scheme) with AT^USSDMODE command before you send. So, the sample command sequence to send "*100#" command should look like this: Code: AT^USSDMODE=0 AT+CUSD=1,"*100#",15 |
