GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
07-04-2013, 20:05 | #1 (permalink) |
Major Poster Join Date: Jun 2006
Member: 299378 Status: Offline Thanks Meter: 0 | AT command(s) to force 3G/4G on Huawei and/or ZTE GSM modems For example, Huawei E366, UMG366 (T-mobile). Modem is connected to a CradlePoint MBR95 router, so stock connection manager cannot be used to configure the modem. |
07-05-2013, 21:34 | #2 (permalink) |
Freak Poster Join Date: Mar 2002 Location: Moscow, Russia Age: 53
Member: 10397 Status: Offline Thanks Meter: 45 | For Huawei, AT^SYSCFG=14,2,3FFFFFFF,2,2 should work. For ZTE, try AT+ZSNT=2,0,0 . |
The Following User Says Thank You to vve For This Useful Post: |
07-07-2013, 22:32 | #4 (permalink) |
Product Supporter Join Date: May 2004 Location: INDIA Age: 55
Member: 65063 Status: Offline Thanks Meter: 2,419 | for zte AT+ZCDRUN=F eNABLE CDROM AT+ZCDRUN=E dISABLE CDROM for zte icera its ?AT%USBMODEM=0 dISABLE CDROM ?AT%USBMODEM=1 eNABLE CDROM for huawei see attached pdf br, |
The Following User Says Thank You to ~AKSingh~ For This Useful Post: |
07-08-2013, 11:38 | #7 (permalink) | |
Member: 10397 Status: Offline Thanks Meter: 45 | Quote:
Post results here and I will suggest you how to set CDROM-less config. | |
07-08-2013, 20:57 | #8 (permalink) | |
Member: 299378 Status: Offline Thanks Meter: 0 | Quote:
1:modem 2:pcui 3:diag 4:pcsc 5:gps 6:gps control 7:ndis a:blue tooth b:finger print d:mms e:pc voice a1:cdrom a2:sd at^setport? A1,a2:1,2,3,7,a1,a2 | |
07-08-2013, 21:22 | #9 (permalink) |
Member: 10397 Status: Offline Thanks Meter: 45 | Please be more careful here: there must be a semicolon (;) between "a2" and "1", not a colon (:)! There are two ways to disable CD-ROM for this configuration: 1. CD-ROM is disabled in Windows environment only, when driver was already installed: AT^SETPORT="A1,A2;1,2,3,7,A2" . 2. CD-ROM is totally disabled (no modeswitch needed, if you know what it is about): AT^SETPORT="FF;1,2,3,7,A2" . |
