GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
11-20-2012, 10:25 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Age: 28
Member: 745672 Status: Offline Thanks Meter: 555 | Create or modify Huawei Dashboard Tutorial Here Only you need one tool that is called 7zip And WinRar Seach On google for download it Lets Start .. Now copy your Huawei mobile partner software in a folder on your PC desktop. In my example you can see the screenshot : You will have at least two file in your folder -data and setup. Forget about all another file and concentrate on data file. Everything you have to do in your data.bin file (data file extension is .bin). Step by step tutorial / hack to change huawei dashboard : 1. Open winrar software and navigate to your Huawei folder which you have created. [IMG]http://3.bp.********.com/-eMVY1uDqbhg/UFRNXNr4PzI/AAAAAAAAErc/oPAkolR4ES4/s400/Mobile+partner+winrar.PNG[/IMG] 2. Now double click on data.bin file to open it. [IMG]http://1.bp.********.com/-fJTXV55DQTk/UFRNp6WOSlI/AAAAAAAAErk/KPFN6r2Vpko/s400/data.bin+huawei.PNG[/IMG] 3. Now select both file and drag all files from the winrar to folder. [IMG]http://1.bp.********.com/-8rxHUi5gtd4/UFRSLPiZHQI/AAAAAAAAEsQ/zz8iNfWEY6A/s1600/extraction+of+folder+from+data.bin[/IMG] 4. Here you can change, what ever you want to change, you can do it your own. 5. Suppose, if you want to change the skin, then just open skin folder and do the necessary changes in image or whatever you want. Note : Before changing any image make sure to note down the name, extension and size of the image file. You should replace that image with same size, name and extension. Otherwise, it will not work properly. [IMG]http://3.bp.********.com/-GHYKax5bAeA/UFRPhXhZGxI/AAAAAAAAEr0/qf-KW2COPDw/s400/custom+huawei+image.PNG[/IMG] 6. Select the image to which you want to change as per your choice. As you can see the first image of my article we have change the image of default skin of mobile partner, . 7. After doing the necessary changes, when you are satisfied then delete all data.bin file from your folder. 8. Now you have folder named common and file SysConfig.dat which you have extracted from data.bin. Now we have to put it back on data.bin file. For this follow the next step. [IMG]http://3.bp.********.com/-6y2bCDoduIg/UFRTckUov1I/AAAAAAAAEsY/aQcPfqH_riE/s400/Custom+Huawei+Mobile+Partner2.PNG[/IMG] 9. Now close the winrar and go to the custom huawei folder where you have file SysConfig.dat and folder common. [IMG]http://4.bp.********.com/-T11rSR1bjxw/UFRURlrDgPI/AAAAAAAAEsg/NCF9ZwZfJ0c/s400/Huawei+mobile+partner+folder.PNG[/IMG] 10. Select common folder and SysConfig.dat file both at time with the help of ctrl key and right click on it and click on Add to archieve... [IMG]http://2.bp.********.com/-LDd6oNuhMFY/UFRWtMJMwRI/AAAAAAAAEso/6qeFg-IlYjA/s320/add+to+archieve.PNG[/IMG] 11. Now delete the selected part (in my example Mobile_Partner_23_for_windows.rar) and put the name as data.bin and click on ok button. 12. Now its will create data.bin file which is the part of your dashboard. 13. After all the process you will get data.bin file. 14. Now your custom dashboard is ready for use in your computer. :::: dont forget to say thanks ::: Any problem contact me [email protected] Last edited by Gsmbizz; 11-20-2012 at 10:33. |
The Following 4 Users Say Thank You to Gsmbizz For This Useful Post: |
11-20-2012, 11:02 | #2 (permalink) |
No Life Poster Join Date: Apr 2012 Location: India ( Gurukrupa ) Age: 32
Member: 1753913 Status: Offline Thanks Meter: 298 | Use 7-Zip for Edit data.bin Easy and Very Helpful Tool 1. Make ISO of this files : *Use PowerISO Free for 300MB Limit [+]--------- ISO FILE +---------- [+] Mobile Partner [DIR] +------------+-------- data.bin [FILE] +------------+-------- setup.exe [FILE] +---------- Aurorun.exe [FILE] +---------- Aurorun.inf [FILE] +---------- Startup.ico [FILE] +---------- Sysconfig.dat [FILE] 2. Create EXE Updater with this Dashboard Creator WBR, Nirav Soni |
The Following User Says Thank You to NiRaV.SoN! For This Useful Post: |
11-20-2012, 11:07 | #3 (permalink) | |
Member: 745672 Status: Offline Thanks Meter: 555 | Quote:
Hmmmm Last Step Thanks for posting | |
11-23-2012, 05:54 | #12 (permalink) |
Member: 745672 Status: Offline Thanks Meter: 555 | |
11-23-2012, 12:33 | #15 (permalink) | |
bro my net is too slow i cant upload that if u need help u can conact me sure i "ll help you [email protected] Br.Shibu | |
