GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
01-01-2015, 17:10 | #4 (permalink) |
Junior Member Join Date: Dec 2014
Member: 2316665 Status: Offline Thanks Meter: 0 | Well since almost nobody was interested in this problem I fixed it myself. Some soldering and a couple of diods with resistors and some more secret things I now have a working modem. Best regards J |
03-15-2016, 22:40 | #5 (permalink) | |
Junior Member Join Date: Mar 2016
Member: 2546502 Status: Offline Thanks Meter: 0 | Quote:
sounds like you had success with repairing the modem, could you share how you manged to replace which diods with resistors? I have also a modem that is bricked hope you get this message,, of this old thread BR | |
06-27-2016, 14:57 | #7 (permalink) | |
Freak Poster Join Date: Aug 2014
Member: 2234281 Status: Offline Thanks Meter: 4 | Huawei E3276 Quote:
Do you get the problem solved? | |
07-27-2017, 20:15 | #11 (permalink) |
Junior Member Join Date: Oct 2013
Member: 2039485 Status: Offline Thanks Meter: 0 | When passing the flash does not repair and gives error the flash: E3276s-150_21.192.99.13.00_BL_FW Mkey Dongle Logs: 13.27.06 : --------------- Read device information ----------------------- 13.27.09 : DLOADVER : 2.0 13.27.11 : SwVers : 21.420.99.23.00 13.27.11 : IsoVers : 00.000.00.000.0 13.27.11 : PrdName : B710S0 13.27.11 : DloadType : 1 13.27.12 : Auth.Vers: : 1000 13.27.12 : New HiSi-TYPE 2 Identified. 13.27.16 : Open Flashing Protocol OK.. 13.27.38 : 13.27.47 : --------------- Flash-mode operations ------------------------ 13.27.50 : Verify download mode: 7200B--SKCBADZM 13.27.51 : Detected: [EHUAWEI B710S0] 13.27.57 : HiSilicon CPU mode-2 Selected. 13.27.58 : Write Part1...[PtableTailHD] Ok 13.28.14 : Write Part2...[PtableTail] Ok 13.28.19 : Write Part3...[BootRomA] Ok 13.28.25 : Write Part4...[BootRomB] 13.28.28 : Init device...ERROR! Help please. |
