E5573cs-322 after update with unlocked file dead need help E5573cs-322 after update with unlocked file dead need help if i update with 21.318.99.03.00 so device both green lights on and never worked imei write ok sn write ok webui write ok but still both green lights on every time when charger connected the problem comes after update with unlocked file its version is 21.329.63.00.1456 this device come from zong if anyone have its stock firmware so plz share here |
Hi, You can try with this firmware, E5573_P711s-E5_UPDATE_21.110.99.03.00.7z via professional tools. |
use this file through boot short method ZONG E5573Cs-322 open password unlocku |
????????? USB-????????? Balong-???????, ?????? 2.10, (c) for***2, 2015 ???? ??? Windows 32bit (c) rust3028, 2016 ????? ????? ????????? ????????... ????: "HUAWEI Mobile Connect - 3G PC UI Interface (COM158)" ????????? ????? ?????? %???????? ------------------------------------------ raminit 10000000 3936 100% usbboot 57900000 5844136 100% ???????? ???????? __________________________________________________ ______________________________ ---------------------------------- - - - WAITING FOR DEVICE RESTART - - - ---------------------------------- ENTER PC UI PORT: bro stuck here |
and write only number of pc ui port in console and press enter |
thanks bro bundle of thanks problem solved with your file unlock ok work with all sims |
how I can solve this same issue with blinking solid green light |
Sent from my SM-J600F using Tapatalk |
mine is MTN 5573Cs-322 bricked |
me write this one hi dear unlock zong e5573cs-322 21.329.63.00.1456 using this file enjoy https://drive.google.com/file/d/14q0...ew?usp=sharing detect modem in dc then give at^godload commnd then wait 10 sec then run fiile after flash done modme will unlcok say thanks if you like my help Report Post my device zong e5573cs-322 21.329.63.00.1456 dead plz help me |
????????? USB-????????? Balong-???????, ?????? 2.10, (c) for***2, 2015 ???? ??? Windows 32bit (c) rust3028, 2016 ????? ????? ????????? ????????... ????: "HUAWEI Mobile Connect - 3G PC UI Interface (COM77)" ????????? ????? ?????? %???????? ------------------------------------------ raminit 10000000 3936 100% ????? ?????? ????? ????? ?????? usbboot 57900000 5844136 0% :mad::mad::mad: ????? ?????? ????? ??????____________________________________________ ___________ _________________________ ---------------------------------- - - - WAITING FOR DEVICE RESTART - - - ---------------------------------- ENTER PC UI PORT: |
password not working |
------------------------------------------ raminit 10000000 3936 100% ????? ?????? ????? ????? ?????? usbboot 57900000 5844136 0% ????? ?????? ????? ??????____________________________________________ ___________ _________________________ ---------------------------------- - - - WAITING FOR DEVICE RESTART - - - ---------------------------------- ENTER PC UI PORT:290 ????? ???????? ???????: ONLY_FW (2958 ????) ????????? ??? ???????? ????????? ?? Balong-???????, V2.6.116, (c) for***2, 2015 , GNU GPLv3 ???? ??? Windows 32bit (c) rust3028, 2016 -------------------------------------------------------------------------------- ------------------ ????????? ???? ????????... ?????? ????????: :BV7R11EU8__3:21.318.03.01.306 ???? ??????: 2016.08.15 07:49:27 ?????????: ?????? 1, ????????? HWEW11.1 ??????? 13 ???????? Software stuck here for a while and then closes automatically |
Same Here I Need Help |
