Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM / HSDPA Modems and Routers
GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares
Old 04-08-2019, 10:36   #1 (permalink)
/\/\A/\/|'s Avatar
Member: 900083
Thanks Meter: 595
E5573cs-322 after update with unlocked file dead need help
if i update with 21.318.99.03.00
so device both green lights on and never worked
imei write ok
sn write ok
webui write ok
but still both green lights on every time when charger connected
the problem comes after update with unlocked file
its version is 21.329.63.00.1456
this device come from zong if anyone have its stock firmware so plz share here
Old 04-08-2019, 14:34   #2 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 9,717
Hi,
You can try with this firmware, E5573_P711s-E5_UPDATE_21.110.99.03.00.7z via professional tools.
__________________
Use Search Button to get Instant Result | Follow Forum Rules
Avoid Spams in the forum to prevent ban your account.
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post:
Old 04-09-2019, 07:51   #3 (permalink)
Member: 2782064
Thanks Meter: 3
imei write ok
sn write ok
webui write ok
use this file through boot short method
ZONG E5573Cs-322 open
password unlocku
The Following User Says Thank You to heroumar For This Useful Post:
Old 04-09-2019, 13:13   #4 (permalink)
/\/\A/\/|'s Avatar
Member: 900083
Thanks Meter: 595
password unlocku
????????? USB-????????? Balong-???????, ?????? 2.10, (c) for***2, 2015
???? ??? Windows 32bit (c) rust3028, 2016
????: "HUAWEI Mobile Connect - 3G PC UI Interface (COM158)"
raminit 10000000 3936 100%
usbboot 57900000 5844136 100%
__________________________________________________ ______________________________
- WAITING FOR DEVICE RESTART -
ENTER PC UI PORT:
bro stuck here
Old 04-09-2019, 13:19   #5 (permalink)
/\/\A/\/|'s Avatar
Member: 900083
Thanks Meter: 595
password unlocku
ENTER PC UI PORT:
bro stuck here
Old 04-09-2019, 20:12   #6 (permalink)
Member: 2782064
Thanks Meter: 3
ENTER PC UI PORT:
bro stuck here
open device manager and check pc ui port number
and write only number of pc ui port in console and press enter
Old 04-10-2019, 11:17   #7 (permalink)
/\/\A/\/|'s Avatar
Member: 900083
Thanks Meter: 595
thanks bro bundle of thanks problem solved with your file
unlock ok work with all sims
Old 04-11-2019, 08:35   #8 (permalink)
Member: 2903434
how I can solve this same issue with blinking solid green light
Old 04-11-2019, 11:32   #9 (permalink)
/\/\A/\/|'s Avatar
Member: 900083
Thanks Meter: 595
brother pull out battery then press and hold power button then insert usb cable then start this file
Sent from my SM-J600F using Tapatalk
Old 04-29-2019, 16:42   #10 (permalink)
Member: 341771
mine is MTN 5573Cs-322 bricked
Old 07-07-2019, 13:39   #11 (permalink)
Member: 1555233
Thanks Meter: 27
password unlocku
me write this one
hi dear unlock zong e5573cs-322 21.329.63.00.1456 using this file
enjoy
https://drive.google.com/file/d/14q0...ew?usp=sharing
detect modem in dc then give at^godload commnd
then wait 10 sec then run fiile
after flash done modme will unlcok
say thanks if you like my help
Report Post
my device zong e5573cs-322 21.329.63.00.1456 dead plz help me
Page generated in 0.30296 seconds with 7 queries
