Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM / HSDPA Modems and Routers
GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares
Old 04-14-2019, 07:46   #1 (permalink)
Member: 2888365
Thanks Meter: 33
Red face E5573Cs-322 how to unkock???????????
Found Applications port COM61
Found modem : E5573Cs-322
Model : Huawei AuthVer 4 modem (New)
IMEI : 860000000000009
Serial NR. : DGF7S18C07006426
Firmware : 21.333.64.00.1456
Dashboard version : WEBUI_17.100.20.01.306_MRE5
Web UI version : WEBUI_17.100.20.01.306_MRE5
SIM Lock status : Locked (Card Lock)
Wrong codes entered : 0 (unlock attempts left : 10)
Old 04-14-2019, 08:06   #2 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 9,523
Before create a post just use the search button,
Already has been discussion & solution above your same issue here, E5573cs-322 after update with unlocked file dead need help
I Strongly recommended to you, try with this firmware, hopefully your device should unlocked.
__________________
Use Search Button to get Instant Result | Follow Forum Rules
Avoid Spams in the forum to prevent ban your account.
Old 04-18-2019, 11:19   #3 (permalink)
Member: 2812460
Thanks Meter: 11
e5573cs-322 imei repair
Please guide i have a zong e5573cs-322 s/w 21.323 i want to repair imei but device is locked when i try to update it t0 21.328 through a file it gives error#13
how can i fix this issue????
Page generated in 0.16577 seconds with 7 queries
