GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
03-14-2019, 08:21 | #1 (permalink) |
Freak Poster Join Date: May 2015 Location: Pakistan
Member: 2401943 Status: Offline Thanks Meter: 182 | E8372h-153 - COMMAND NOT SUPPORT Model : Huawei AuthVer 4 modem (New) IMEI : 86XXXXXXXXXXXX Serial NR. : B7Z7S18921002847 Firmware : 21.327.62.00.1460 Dashboard version : WEBUI_17.100.45.00.1456_RE5 Web UI version : WEBUI_17.100.45.00.1456_RE5 SIM Lock status : unlocked Wrong codes entered : 0 (unlock attempts left : 10) at^datalock=11111111 ERROR & COMMAND NOT SUPPORT anyone have tested solution ? |
03-16-2019, 13:02 | #3 (permalink) | |
Member: 2401943 Status: Offline Thanks Meter: 182 | Quote:
i need solution to fix imei for working zong sim. i have already unlocked for other network.. but zong data sim not work. need free/paid solution. but tested and working. | |
04-10-2019, 17:30 | #5 (permalink) |
Freak Poster Join Date: Dec 2014 Location: amateur team
Member: 2303526 Status: Offline Thanks Meter: 24 | If AT comamnd not support, you need to downgrade the firmware. after unlock your modem, and upgrade firmware. DON"T FLASH ANY WRONG FIRMWARE for your device, check CORRECT FIRMWARE |
10-03-2019, 07:30 | #6 (permalink) |
Freak Poster Join Date: Dec 2014 Location: KPK Age: 34
Member: 2304199 Status: Offline Sonork: 100.1656573 Thanks Meter: 203 | whats is this Error Found modem : E5372 Model : Huawei E5372 / MegaFon MR100-3 IMEI : 86XXXXXX668659 Serial NR. : N7GBY14A13002554 Firmware : 21.290.23.01.397 Dashboard version : WEBUI_17.100.11.01.274 SIM Lock status : unlocked Wrong codes entered : 0 (unlock attempts left : 10) ====================================== AT^DATALOCK="18239855" OK AT^CIMEI="860XXXXXX800137" ERROR |
The Following User Says Thank You to zebafridi For This Useful Post: |
