-   GSM / HSDPA Modems and Routers (http://forum.gsmhosting.com/vbb/f804/)
-   -   E8372h-153 - COMMAND NOT SUPPORT (http://forum.gsmhosting.com/vbb/f804/e8372h-153-command-not-support-2574909/)
Silent Angel 03-14-2019 08:21
Found modem : E8372
Model : Huawei AuthVer 4 modem (New)
IMEI : 86XXXXXXXXXXXX
Serial NR. : B7Z7S18921002847
Firmware : 21.327.62.00.1460
Dashboard version : WEBUI_17.100.45.00.1456_RE5
Web UI version : WEBUI_17.100.45.00.1456_RE5
SIM Lock status : unlocked
Wrong codes entered : 0 (unlock attempts left : 10)
at^datalock=11111111
ERROR
& COMMAND NOT SUPPORT
anyone have tested solution ?
heroumar 03-15-2019 06:45
latest 1460 unlocked devices not accept commands
u can do it only if telnet or adb is enable
Silent Angel 03-16-2019 13:02
i need solution to fix imei for working zong sim. i have already unlocked for other network.. but zong data sim not work. need free/paid solution. but tested and working.
K-B MOBILE 03-16-2019 13:09
you have unlock with bad file now your device cannot acept at commands now you cannot use ZONG sim......
odilonse 04-10-2019 17:30
If AT comamnd not support, you need to downgrade the firmware.
after unlock your modem, and upgrade firmware.
DON"T FLASH ANY WRONG FIRMWARE for your device, check CORRECT FIRMWARE
Page generated in 0.16441 seconds with 5 queries
