Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM / HSDPA Modems and Routers
GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares
Old 03-14-2019, 09:21   #1 (permalink)
Member: 2401943
Thanks Meter: 143
E8372h-153 - COMMAND NOT SUPPORT
Found modem : E8372
Model : Huawei AuthVer 4 modem (New)
IMEI : 86XXXXXXXXXXXX
Serial NR. : B7Z7S18921002847
Firmware : 21.327.62.00.1460
Dashboard version : WEBUI_17.100.45.00.1456_RE5
Web UI version : WEBUI_17.100.45.00.1456_RE5
SIM Lock status : unlocked
Wrong codes entered : 0 (unlock attempts left : 10)
at^datalock=11111111
ERROR
& COMMAND NOT SUPPORT
anyone have tested solution ?
Old 03-15-2019, 07:45   #2 (permalink)
Member: 2782064
Thanks Meter: 3
latest 1460 unlocked devices not accept commands
u can do it only if telnet or adb is enable
Old 03-16-2019, 14:02   #3 (permalink)
Member: 2401943
Thanks Meter: 143
i need solution to fix imei for working zong sim. i have already unlocked for other network.. but zong data sim not work. need free/paid solution. but tested and working.
Old 03-16-2019, 14:09   #4 (permalink)
K-B MOBILE's Avatar
Member: 2574306
Thanks Meter: 261
you have unlock with bad file now your device cannot acept at commands now you cannot use ZONG sim......
Old 04-10-2019, 18:30   #5 (permalink)
Member: 2303526
Thanks Meter: 11
If AT comamnd not support, you need to downgrade the firmware.
after unlock your modem, and upgrade firmware.
DON"T FLASH ANY WRONG FIRMWARE for your device, check CORRECT FIRMWARE
Old 10-03-2019, 08:30   #6 (permalink)
zebafridi's Avatar
Member: 2304199
Sonork: 100.1656573
Thanks Meter: 78
whats is this Error
Found modem : E5372
Model : Huawei E5372 / MegaFon MR100-3
IMEI : 86XXXXXX668659
Serial NR. : N7GBY14A13002554
Firmware : 21.290.23.01.397
Dashboard version : WEBUI_17.100.11.01.274
AT^DATALOCK="18239855"
OK
AT^CIMEI="860XXXXXX800137"
ERROR
Old 11-03-2019, 08:56   #7 (permalink)
Member: 2592342
plz share any sulotion
Old 11-12-2019, 06:44   #8 (permalink)
Member: 2934401
I have a paid solution of Rs. 300\-
Contact me
03312722525
Old 11-15-2019, 16:40   #9 (permalink)
Member: 2592342
bro your number power off
Page generated in 0.13623 seconds with 7 queries
