GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
02-02-2010, 05:51 | #1 (permalink) |
Junior Member Join Date: Jan 2010
Member: 1215008 Status: Offline Thanks Meter: 0 | HELP - Huawei E156G error "Only the specified SIM/USIM card can be used..." I have also tried other SIM card in my E156G, and I got the same problem. So I think it is not the SIM card problem, but the modem. Then I tried to update my E156G firmware. I got the NCK code and Flash code and when the firmware upgrade ask for a password, i entered the Flash code. The firmware upgrade was successful, but I still got the error message "Only the specified SIM/USIM card can be used..." I have also tried to update the dashboard to Mobile Partner 11.030.01.04.03 but to no avail. Does anybody know how to fix the problem? Did I use the wrong code? (I used the Flash code instead of the NCK code) Any help will be highly appreciated. Thanks |
02-05-2011, 10:33 | #4 (permalink) |
Junior Member Join Date: Feb 2011
Member: 1509270 Status: Offline Thanks Meter: 0 | i have a huawei e156g (bsnl 3g) modem wic i bought fm mumbai for mtnl sim, i chked it, its unlocked. wen i tried using the bsnl sim on win7 it gives error 628. and on xp error 619. but i am able to use the same modem with, wirtel, mtnl "delhi sim". i tried updating the mobile partner software as well as firmware. still m unable to connect. i have been googling for long time. but m not still not able to use the bsnl sim on it. any kinda help iin this regard wd be appreciated friends. plz help |
02-08-2011, 17:07 | #5 (permalink) | |
Junior Member Join Date: Feb 2009
Member: 966146 Status: Offline Thanks Meter: 1 | Quote:
I fix 1 but the problem was hardware. i make a resoldering in sim port and fixed this error. Felox... Last edited by Winner58; 02-08-2011 at 22:00. Reason: non english | |
02-08-2011, 17:09 | #6 (permalink) | |
The error 619 is when the programation APN have problems. Felox... | |
02-14-2011, 23:36 | #8 (permalink) |
Member: 966146 Status: Offline Thanks Meter: 1 | This configuration dont need name and pass?? I use another provider... but if you have a same configuration than other modem i dont now why have problem... i was looking in gogle for same apn and found this Try APN name----------------------->bsnlnet Phone number----------------->*99***1# sorry i speak spanish... |
09-07-2011, 21:56 | #9 (permalink) | |
Freak Poster Join Date: Nov 2010
Member: 1445998 Status: Offline Thanks Meter: 47 | Quote:
hi, i get the ki from 3g usim card can i clone it to silvercard with sim-emu | bandess | Sim Cloning and Scaning | 1 | 10-23-2009 22:52 |
The Specified Com Port Could Not Be Opend | ghost__ | NSPRO | 1 | 09-17-2007 09:11 |
The downloader can be used for the I300? | sim1 | Trident/AGERE Platform | 21 | 08-04-2007 13:16 |
SIM Card can be reprogram? | kasamiko | Sim Cloning and Scaning | 4 | 05-17-2007 09:16 |
What cards can be used | netzon10 | Sim Cloning and Scaning | 0 | 05-17-2002 02:02 |
