GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
12-18-2017, 13:34 | #1 (permalink) |
Insane Poster Join Date: Jan 2010
Member: 1198942 Status: Offline Thanks Meter: 3 | HELP for huawei e8372h-608 Firmware ver- 21.316.01.04.274 Web Ui- 17.100.15.10.274 i tried Update_WEBUI_17.100.13.01.03_HILINK_Mod1.0 after it modem downloading started & failed and now modem hang on downlaod Mode showing FC application port FC PC UI interface port tested all firmware ver all software not able to update anything. error code 13, 19 anything possible or anyone have Firmware ver- 21.316.01.04.274 Web Ui- 17.100.15.10.274 |
12-20-2017, 12:44 | #2 (permalink) | |
Freak Poster Join Date: Aug 2014
Member: 2234281 Status: Offline Thanks Meter: 4 | Huawei E8372h-608 Quote:
12-23-2017, 18:40 | #5 (permalink) |
Member: 1198942 Status: Offline Thanks Meter: 3 | Thanks Brother! Got sucess! using Your Tips /Soft Found modem : E8372 Model : Huawei E8372h IMEI : 8662xxxxxxxx065 Serial NR. : 0123456789ABCDEF Firmware : 21.316.01.04.274 Compile date / time : Mar 17 2017 09:29:51 Hardware ver. : CL1E8372HM Dashboard version : WEBUI_17.100.08.00.1133 Web UI version : WEBUI_17.100.08.00.1133_RE5 SIM Lock status : unlocked Wrong codes entered : 0 (unlock attempts left : 10) |
09-05-2020, 08:41 | #9 (permalink) |
Junior Member Join Date: Aug 2020 Location: N/A
Member: 2965921 Status: Offline Thanks Meter: 1 | Unlocked Firmware for Huawei E8372-608 21.316.01.04.274 Unlocked Firmware for Huawei E8372-608 21.316.01.04.274 Use command: AT^GODLOAD and run Unlocked Firmware file. If Modem is already in blinking mode, then just run Unlocked Firmware file Tested File: https://mega.nz/file/GlojlThJ#aoZQZT...9xpqLy_e3DL0cU Regards.! |
09-05-2020, 09:13 | #10 (permalink) |
Member: 2965921 Status: Offline Thanks Meter: 1 | Need new usbloader for E8372h-608 (21.327.62.00.1460) I need new usbloader for E8372h-608 (21.327.62.00.1460). Modem stuck in usb mode after Boot Point short. Only Showing one Com Port: (HUAWEI Mobile Connect - 3G PC UI Interface) I have tried all available usbloaders for E8372h but no success yet. This modem is secuboot=1 and with efuse. That's why no older usbloader is working on it. Only new usbloader or some patched usbloader will work on it. Please help, if someone can.. Thanks & Regards.! |
