Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM / HSDPA Modems and Routers
GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares
Old 09-05-2016, 20:48   #1 (permalink)
Member: 1780156
Thanks Meter: 2
help:Reset Unlock Code Counter E5573?
Is zero meters
Old 09-05-2016, 20:59   #2 (permalink)
Member: 1780156
Thanks Meter: 2
I used the following solution , but error +CME ERROR: 50
The numbers are an example
AT^CARDUNLOCK=” NEW / OLD ALGO HASH Code” Check Below Screen Shot I have used
AT^CARDLOCK=”57ae817cf69404d564dc42e82d552c29” to modem
Old 09-06-2016, 08:05   #3 (permalink)
Member: 1780156
Thanks Meter: 2
Is the firmware that will make 10 meters .؟
Old 09-08-2016, 06:50   #4 (permalink)
Member: 1780156
Thanks Meter: 2
No help?
The Following User Says Thank You to darvish1900 For This Useful Post:
Old 09-09-2016, 13:21   #5 (permalink)
Member: 2234281
Thanks Meter: 4
Huawei e5573
Is zero meters
What's the IMEI number of your Huawei E5573?
The Following User Says Thank You to Veikko For This Useful Post:
Old 09-09-2016, 21:40   #6 (permalink)
Member: 1780156
Thanks Meter: 2
10 to lock the user himself has wasted
IMEI:
8661620243 40193
8661620243 74952
Old 09-14-2016, 19:36   #7 (permalink)
Member: 1780156
Thanks Meter: 2
Does not anyone help؟
Old 09-20-2016, 08:44   #8 (permalink)
Member: 1780156
Thanks Meter: 2
Old 09-22-2016, 15:45   #9 (permalink)
Member: 2234281
Thanks Meter: 4
Huawei e5573
IMEI:
8661620243 40193
8661620243 74952
Try the unlock codes:
8661620243 40193 Unlock Code = 60144753
8661620243 74952 Unlock Code = 60306252
Old 09-24-2016, 13:52   #10 (permalink)
Member: 1780156
Thanks Meter: 2
Is zero meters
Page generated in 0.19342 seconds with 8 queries
