Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM / HSDPA Modems and Routers
GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares
Old 03-10-2016, 18:32   #1 (permalink)
Member: 1883136
Thanks Meter: 3
Help unlock Huawei E3372H-153
Hello
A new version of the DC-unlocker does not give advice. Then it can be unlocked.
selection :
manufacturer - Huawei modems
model - Auto detect (recommended)
Found Applications port COM23
Found modem : E3372
Model : Huawei E3372h
IMEI : 8687570***********
Serial NR. : G4PDW15*********
Firmware : 22.200.15.00.391
Compile date / time : Nov 17 2015 17:17:14
Hardware ver. : CL2E3372HM
Dashboard version : WEBUI_17.100.12.03.391_HILINK
Web UI version : WEBUI_17.100.12.03.391_HILINK
SIM Lock status : Locked (Card Lock)
Wrong codes entered : 0 (unlock attempts left : 10)
Old 04-07-2016, 09:16   #2 (permalink)
Member: 2555327
You can just read the Modem NVRAM commands,there a NVRAM record # that gives you an AT Command that Unlocks the modem Directly.
You could rather use the procedure of Unlock code v4
Old 04-16-2016, 19:25   #3 (permalink)
Member: 2560597
how can i unlock please give me unlock software
Old 04-16-2016, 22:13   #4 (permalink)
TestBox2's Avatar
Member: 772096
Sonork: 100.69222
Thanks Meter: 8,277
Mkey can do unlock this modem voa write special firmware.
Old 04-21-2016, 14:18   #5 (permalink)
Member: 2234281
Thanks Meter: 4
Huawei E3372
Originally Posted by raferti View Post
Hello
selection :
Found modem : E3372
If you can provide the full IMEI number, i will provide the unlock code for you.
The Following User Says Thank You to Veikko For This Useful Post:
Old 04-27-2016, 18:28   #6 (permalink)
Member: 1883136
Thanks Meter: 3
After the update frimware E3372h-153_Update_22.315.01.00.00_M_AT_05 unlock without trouble
The Following User Says Thank You to raferti For This Useful Post:
Old 06-17-2016, 19:50   #7 (permalink)
Member: 2168655
hello
hello Sir , Please how did you get the unlock code for this router?
Old 02-17-2017, 14:16   #8 (permalink)
Member: 142994
Thanks Meter: 66
where is the update file sir....and after updating firmware how and with which tool u updated this...???
Old 07-12-2017, 15:23   #9 (permalink)
louisgsm's Avatar
Member: 605126
Sonork: 100.1617907
Thanks Meter: 297
download from this link
https://www.lteforum.at/mobilfunk/fi...inkl-mod.2691/
The Following User Says Thank You to louisgsm For This Useful Post:
Old 02-13-2018, 19:43   #10 (permalink)
Member: 2751138
how to get firmwa3re of e3372h-15
Page generated in 0.16243 seconds with 9 queries
