GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
01-07-2014, 09:24 | #1 (permalink) |
No Life Poster Join Date: Jun 2011 Location: manila
Member: 1595088 Status: Offline Thanks Meter: 184 | Unlock Huawei E5172 STC Saudi Arabia WiFi Router Gateway i want to change wifi pass but i dont know what is the admi password in confi thank you Huawei E5172 4G 150Mbps LTE Cat4 CPE Review - Upload and stream using StreamUpload.com |
01-10-2014, 05:29 | #2 (permalink) |
Insane Poster Join Date: Aug 2013 Location: hong kong
Member: 2001252 Status: Offline Sonork: 100.1645439 Thanks Meter: 4 | Hello, The Huawei E5172 default admin password is admin. You can also check to the back label of HUAWEI E5172 for reference. you can refer to the image on this page: http://www.4gltemall.com/huawei-e517...-cat4-cpe.html |
03-20-2015, 14:47 | #8 (permalink) | |
Junior Member Join Date: Nov 2005
Member: 200382 Status: Offline Thanks Meter: 4 | Quote:
Important! It is better to use a LAN cable to connect to the router not wi-fi 1. Download the firmware named: E5172S-920_Anti_STC_927_Update from the link below. The firmware unlocks the router by downgrading it’s firmware to the firmware for E5172s 920. E5172S-920_Anti_STC_927_Update 2. Access router manager by entering 192.168.1.1 (also written on the bottom of the router) into your web browser. 3. Enter the user name and password for the router ( default user: admin password: admin) 4. From the HOME page go to UPDATE. 5. Click on browse to navigate to the place where you downloaded the E5172S-920_Anti_STC_927_Update file too and click on open to select it. 6. Press update and wait for it to finish. When it has finished click on login to once again login to the router manager. 7. Download the update firmware from the following link or any other firmware you want. Different firmware give access to different features available on the router that STC block, such as, external antenna, voice calls, different frequencies etc. The linked firmware unlocks most of the stuff. https://mega.co.nz/#!sQxFWR4I!nwuYOO...VODek_y2vM0Fdc 8. Search the folder until you locate file named: MPWUDPUPDATE_V200R001C115SP100.BIN 9. Once again, login to the router manger and update the firmware following the previous steps (4 – 6). 10. When it has completed updating, login again. That’s it! Your router is now unlocked 11. If you want to update the firmware you have to first update with the file named: E5172s-927_AntiOM100.BIN then update with your desired firmware. Credit for the links to the files goes out to HAMD.G https://www.youtube.com/watch?v=Gi0XsQAld74 | |
The Following 4 Users Say Thank You to jamalx For This Useful Post: |
04-06-2015, 09:25 | #10 (permalink) |
Junior Member Join Date: Mar 2011
Member: 1528407 Status: Offline Thanks Meter: 8 | file verfication failed. update failed file verfication failed. Last edited by monish111; 04-06-2015 at 09:31. |
The Following User Says Thank You to monish111 For This Useful Post: |
05-05-2015, 17:04 | #11 (permalink) |
No Life Poster Join Date: Feb 2004 Location: PaKiStAn Age: 44
Member: 51639 Status: Offline Thanks Meter: 76 | File varification failed on every router i tried so i think the method described above is either for some other router or fake |
The Following User Says Thank You to shakeelajmal For This Useful Post: |
