GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
01-26-2019, 13:35 | #16 (permalink) |
Freak Poster Join Date: Oct 2018 Location: GSMHOSTING
Member: 2869280 Status: Offline Thanks Meter: 112 | ZONG E5573CS-322 21.329.63.00.1456 https://drive.google.com/file/d/1IKZ...ew?usp=sharing |
The Following 3 Users Say Thank You to samsamsolutions For This Useful Post: |
03-05-2019, 10:46 | #18 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | Quote:
Tested 100% Working | |
The Following User Says Thank You to maplegsm For This Useful Post: |
03-15-2019, 07:57 | #19 (permalink) |
Crazy Poster Join Date: Mar 2015
Member: 2363010 Status: Offline Thanks Meter: 1 | Solution for dead modem e5573cs-322 people flashing 21.329.63.00.1456 file into 21.328/21.327 and result (dead modem) with red light no sign of life. only show (huawei mobile connect 3G pC UI port) in device manager. safe loder file or usbloader.bin of e5573cs-322 not working. what is solution. |
03-15-2019, 08:21 | #23 (permalink) | |
Member: 2363010 Status: Offline Thanks Meter: 1 | This file not good Quote: Also imei fix will not work after this file. This is for 21.328 not 21.329.63. Dont flash this file.. Original file is from samsamsolution | |
07-26-2019, 23:32 | #25 (permalink) |
Freak Poster Join Date: Feb 2014 Location: MEA Age: 30
Member: 2119579 Status: Offline Thanks Meter: 44 | E5573cs-322 Dead Boot After unlocking Zong E5573Cs-322 got a new update, then the modem updated to 21.33x.xx and got locked again, I missed with it flashing some files, and got only RED led mode, the version before update was 21.22x.xx not sure exactly, and many users reported about that issue. When you try to load the boot-loader using Balong Flasher you got error in Russian means "Modem rejected the packs". I've attached the photos of Balong after correcting the Charset to be compatible with Balong running one. https://ibb.co/0GGrFYL https://ibb.co/tzgHj7p |
11-09-2019, 05:38 | #26 (permalink) |
Junior Member Join Date: Oct 2009 Location: sargodha
Member: 1132151 Status: Offline Thanks Meter: 0 | zong bolt E5573cs 322 after flash device dead plz give me solution ???old firmware 21 328 62 00 1456 wrong flash with 21.329.63.00.1456 now not coming on .only show in device manager plz any soloution |
