GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
10-04-2013, 11:36 | #1 (permalink) |
Freak Poster Join Date: May 2010 Location: karnataka
Member: 1313327 Status: Offline Sonork: 100.1650723 Thanks Meter: 11 | huawei 3276s-920 airtel india need unlocking thank you |
10-05-2013, 13:09 | #5 (permalink) |
Member: 1313327 Status: Offline Sonork: 100.1650723 Thanks Meter: 11 | dc-unlocker dont support this model.........? frendz i need to just flash the dashboard to mobile ptnr i tryed with dc-dashboard writer but didnt wrk for me any other way to write dashboard in modem |
10-05-2013, 19:10 | #6 (permalink) |
Freak Poster Join Date: Mar 2002 Location: Moscow, Russia Age: 53
Member: 10397 Status: Offline Thanks Meter: 45 | Please keep in mind that you should have a proper dashboard to flash it into HiSilicon-based Huawei modem like E3276. Most of common dashboadrs were intended to be flashed into Qualcomm-based devices so they are wrong for your task. To be more clear, dashboards themselves (binary maps of ISO images) are fairly the same in both versions. Flasher's code only is platform-dependent. |
10-06-2013, 10:20 | #7 (permalink) |
Member: 1313327 Status: Offline Sonork: 100.1650723 Thanks Meter: 11 | @ vve but huawei 303d 303c and many other modems r of hisilicon-based huawei modem those modem dashboard can be easily changed but y not his .....i can read and make backup of dashboard but the same backup file cant be written in same modem ........some thing only read mode is on writting mode has been locked.......i dont know more about ... |
10-06-2013, 10:54 | #8 (permalink) |
Member: 10397 Status: Offline Thanks Meter: 45 | cool.maddy1920 Try this one. It was proved to work with E3276. One mode thing: have you installed the Huawei driver before flashing? You may get it, say, here. And you surely know that dashboard update will not help you to unlock your modem. More than that, Airtel, in some cases (e.g., for E392), used customized firmware with "internal simlock". I don't know if this is the case with your E3276 but if it is - unlock code will not help you as well. The only way to do it is to flash it with non-customized firmware or with other customized build where internal lock is not implemented. |
The Following User Says Thank You to vve For This Useful Post: |
10-06-2013, 11:43 | #9 (permalink) |
Member: 1313327 Status: Offline Sonork: 100.1650723 Thanks Meter: 11 | thanx VVE i have allready unlocked E3276s-920 its working perfect with other sim...but the problem was with dashboard thank you so much i wish the given solution by u must work on it |
