Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM / HSDPA Modems and Routers
GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares
Old 09-09-2018, 12:05   #1 (permalink)
/\/\A/\/|'s Avatar
Member: 900083
Thanks Meter: 601
huawei 35573-cs-609 imei 0000 need help
i tried with dc unlocker crack say imei ok but still 0000 s/n write ok but imei write failed i think its nv data fault or else but i need help for it thanks
here is dc unlocker logs
selection :
manufacturer - Huawei modems
model - Auto detect (recommended)
Found Applications port COM86
Found modem : E5573CS-609
Model : Huawei E5573 (untested)
IMEI : 000000000000000
Serial NR. : 5LL7S17401025990
Firmware : 21.318.99.03.00
Compile date / time : May 13 2016 11:45:50
Hardware ver. : CL1E5573CSM Ver.B
Dashboard version : 00.00.00.000.00
SIM Lock status : unlocked
Wrong codes entered : 0 (unlock attempts left : 10)
AT^CIMEI="861350032976612"
OK
after that still same
Detecting modem :
selection :
model - Huawei E5573 (untested)
Selected Applications port COM86
Old 09-10-2018, 04:10   #2 (permalink)
/\/\A/\/|'s Avatar
Member: 900083
Thanks Meter: 601
any modem expert plz told me how to solve or back to stock
Old 09-11-2018, 10:24   #3 (permalink)
/\/\A/\/|'s Avatar
Member: 900083
Thanks Meter: 601
close please i solved my problem
Old 09-11-2018, 17:34   #4 (permalink)
Member: 2601587
Thanks Meter: 201
Need unlock firmware Stc.5573s.932
Old 09-12-2018, 06:11   #5 (permalink)
alirazamanzoor's Avatar
Member: 2562113
Sonork: alirazamanzoor
Thanks Meter: 89
selection :
OK
Detecting modem :
selection :
you use un-pached loader as a result you vipe all NV ram .now you need to repair these value .
for restore imei (repair)
AT^NVWREX=0,0,16,x x x x x x x x x x x x x x 0
put x = digit of imei numer
for seriel number=
at^sn=xxxxxxxxxxxxxxx
store these NV values ​​in NVRAM, put this command
AT ^ INFORBU
done it .fix i more thing you use D99 firmware after reapir these values you need to change fw.
The Following 2 Users Say Thank You to alirazamanzoor For This Useful Post:
Old 09-17-2018, 15:03   #6 (permalink)
/\/\A/\/|'s Avatar
Member: 900083
Thanks Meter: 601
for seriel number=
AT ^ INFORBU
thx bro but before your reply i solved imei isuue with flash this version
E5573Cs-609TCPU-V200R001B323D01SP01C274_Firmware_Pakistan_Telenor Pakistan (Pvt) Limited_05014LHK
but now i need to unlock it do you help me for
Old 09-17-2018, 17:10   #7 (permalink)
balwinder27's Avatar
Member: 2634133
Thanks Meter: 2,939
yes i can help you
https://drive.google.com/file/d/1HJb...ew?usp=sharing
download telnor e5573cs-609 unlock file
detect modme in dc
then give at^godload command
wait 5 sec for make com port in device manger
then run file
after flash modem will unlock done
done
The Following User Says Thank You to balwinder27 For This Useful Post:
Old 09-18-2018, 13:53   #8 (permalink)
/\/\A/\/|'s Avatar
Member: 900083
Thanks Meter: 601
Originally Posted by balwinder27 View Post
yes i can help you
detect modme in dc
then run file
done
Thx bro Love you i was stuck with it before some days but u solved my problem in just a few minuts thanks bro now you are in my friends list and if u need any help from me i m always online for you
The Following User Says Thank You to /\/\A/\/| For This Useful Post:
Old 09-19-2018, 09:31   #9 (permalink)
/\/\A/\/|'s Avatar
Member: 900083
Thanks Meter: 601
yes i can help you
detect modme in dc
then run file
done
b
alwinder bro i need a last help for it after all sim work ok but now device cannot reset or factory default not work what i can do
Old 09-19-2018, 12:04   #10 (permalink)
Member: 2634133
Thanks Meter: 2,939
b
usbloader you used that reason reset button not work
i will upload program it will fix your modem
then your modem will ok
Old 09-19-2018, 12:22   #11 (permalink)
Member: 2634133
Thanks Meter: 2,939
b
https://drive.google.com/file/d/1szG...ew?usp=sharing
download this program
then detect modem in dc
then run file and enter pc ui com port number
then press enter
enter
enter
your modem will repair
Old 09-16-2021, 13:42   #12 (permalink)
Member: 1555233
Thanks Meter: 2,192
Help
link not working sir
then press enter
enter
enter
Report Post
Page generated in 0.24524 seconds with 8 queries
