GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
06-17-2016, 15:35 | #1 (permalink) |
Junior Member Join Date: Jun 2016
Member: 2587501 Status: Offline Thanks Meter: 5 | Huawei B190 connection(?) / firmware It's a LTE Router, please google for images, can't post em yet. The device has a microUsb-connector. But when connected to Win or Unix it only constantly restarts. Win also states "unknown device", so no luck there. I can't find a way to get it connected to some COM to issue some AT-Commands or anything. Is it possible that i need some sort of special cable (crossed USB?) or am i missing something here? Any other way to unlock/mess with it? Also, i like to start a bit with reverse engineering, but i can't get my hands on the firmware (tried exploiting the website-urls, update-server etc, but no luck). Maybe one of you has something on hand Thanks in advance! |
The Following User Says Thank You to bitflip For This Useful Post: |
06-20-2016, 09:19 | #2 (permalink) |
Member: 2587501 Status: Offline Thanks Meter: 5 | Just wanted to update what i got so far. First guess due to the constant restarts was that the B190 needs more power over the USB than my PC gives. But even with active hub it doesn't work. I opened up the router and started probing some testpoints. I still can't post images (10 posts limit), but it seems i found an active UART, will try to connect it with my pi today. I also eventually found JTAG, but i still have no idea what the micro-usb is doing. When i power the device with socket-outlet, the micro-Usb starts transmitting on two pins (same signal) and ground is connected. No Vdd. I also found an unpopulated interface, looks like another micro-Usb (sorry, no image possible). Will report further when i find more. |
06-21-2016, 13:23 | #3 (permalink) |
Member: 2587501 Status: Offline Thanks Meter: 5 | I've successfully connected to the B190 via serial. The pins for Tx and Rx can be found at imgur /a/XA5Ad When connected and booted, you get dropped into a VxWorks shell. It's the first time I've seen this OS, so I'll need some time to find my way around. I'm able to browse through the filesystem, but it contains mostly binary files (executeables?). Next, I'll try to extract the firmware. Maybe some of you have experience with VxWorks? Do you know any way i can communicate with the modem through this shell? My goal is still to issue some AT-commands or find a way of unlocking the modem. |
06-24-2016, 00:15 | #4 (permalink) |
Member: 2587501 Status: Offline Thanks Meter: 5 | Got no luck with VxWorks so far. I got lucky again when i was probing with the oscilloscope. I found another UART connection, this time booting into a nice Linux kernel, starting BusyBox and doing some stuff. Sadly, i couldn't get a shell (or it just didn't take my input). Both UARTs can be found at the 10-testingpoint array. Pin Layout: Vdd (5V) ---> (0) (0) <--- Rx (Linux) Vdd (5V) ---> (0) (0) <--- Tx (Linux) ?? ---------> (0) (0) <--- ?? GND -------> (0) (0) <--- Rx (VxWorks) GND -------> (0) (0) <--- Tx (VxWorks) For documentation, here some output of VxWorks UART: Code: onchip NF_boot! UnSec_boot! Balong V7R1 MCore bootloader... Compile date:Sep 26 2013 Compile time:15:10:18 NANDC_V4.00Partition Table list(HEX):BOOTROM_V01.02H6920CS_UDP NO. |offset |loadsize |capacity |loadaddr |entry |property |count |id |name | ------------------------------------------------------------------------------------------------------- 00000001: 00000000 ,0000FBE4 ,00020000 ,2FFC0000 ,2FFC0000 ,00000000 ,00000002 ,00000101 ,BootLoad 00000002: 00020000 ,00000000 ,00180000 ,00000000 ,00000000 ,00000800 ,00000000 ,0000010D ,NvBackLTE 00000003: 001A0000 ,00000000 ,00100000 ,00000000 ,00000000 ,00000800 ,00000000 ,0000010E ,NvBackGU 00000004: 002A0000 ,000A264C ,00200000 ,30003F80 ,30004000 ,00000000 ,00000002 ,00000102 ,BootRom 00000005: 004A0000 ,000A267B ,00200000 ,30003F80 ,30004000 ,00000000 ,00000001 ,00000102 ,BootRom 00000006: 006A0000 ,016FD05C ,02000000 ,30003F80 ,30004000 ,00000000 ,00000002 ,00000103 ,VxWorks 00000007: 026A0000 ,00000000 ,00000000 ,00000000 ,00000000 ,00000000 ,00000000 ,00000110 ,Logo 00000008: 026A0000 ,00000000 ,00C00000 ,00000000 ,00000000 ,00000201 ,00000000 ,00000106 ,/yaffs0 00000009: 032A0000 ,0000F858 ,00060000 ,369E0000 ,369E0000 ,00000000 ,00000002 ,00000104 ,FastBoot 0000000A: 03300000 ,002A2000 ,003A0000 ,36A40000 ,36A40000 ,00000000 ,00000002 ,00000105 ,kernel 0000000B: 036A0000 ,01249800 ,01C00000 ,00000000 ,00000000 ,00004401 ,00000002 ,00000107 ,/yaffs1 0000000C: 052A0000 ,00000000 ,00500000 ,00000000 ,00000000 ,00004001 ,00000000 ,00000109 ,/yaffs3 0000000D: 057A0000 ,00000000 ,00000000 ,00000000 ,00000000 ,00004001 ,00000000 ,00000111 ,/yaffs4 0000000E: 057A0000 ,00000000 ,00000000 ,00000000 ,00000000 ,00004401 ,00000000 ,00000108 ,/yaffs2 0000000F: 057A0000 ,00000000 ,00080000 ,00000000 ,00000000 ,00004001 ,00000000 ,00000113 ,/yaffs6 00000010: 05820000 ,00000000 ,02260000 ,00000000 ,00000000 ,00004401 ,00000000 ,00000112 ,/yaffs5 00000011: 07A80000 ,00000000 ,08580000 ,00000000 ,00000000 ,00004000 ,00000000 ,0000010C ,cdromiso ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ sec disabled IsBootromStart value = %d00000000 press space key to enter bootrom: Start from: vxWorks Kernel. >>loading: VxWorks ... OK. >>loading: FastBoot ... OK. hw main id:00000909, sub id:00000001activate_fastboot...0x369E0000 Starting from entry: 0x30004000 Target Name: vxTarget Adding 62360 symbols for standalone. ]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]] ]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]] ]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]] ]]]]]]]]]]] ]]]] ]]]]]]]]]] ]] ]]]] (R) ] ]]]]]]]]] ]]]]]] ]]]]]]]] ]] ]]]] ]] ]]]]]]] ]]]]]]]] ]]]]]] ] ]] ]]]] ]]] ]]]]] ] ]]] ] ]]]] ]]] ]]]]]]]]] ]]]] ]] ]]]] ]] ]]]]] ]]]] ]]] ]] ] ]]] ]] ]]]]] ]]]]]] ]] ]]]]]]] ]]]] ]] ]]]] ]]]]] ] ]]]] ]]]]] ]]]]]]]] ]]]] ]] ]]]] ]]]]]]] ]]]] ]]]]]] ]]]]] ]]]]]] ] ]]]]] ]]]] ]] ]]]] ]]]]]]]] ]]]] ]]]]]]] ]]]]] ] ]]]]]] ] ]]] ]]]] ]] ]]]] ]]]] ]]]] ]]]] ]]]]]]]] ]]]]] ]]] ]]]]]]] ] ]]]]]]] ]]]] ]]]] ]]]] ]]]]] ]]]]]]]]]]]]]]]]]]]]]]]]]]]]]] ]]]]]]]]]]]]]]]]]]]]]]]]]]]]] Development System ]]]]]]]]]]]]]]]]]]]]]]]]]]]] ]]]]]]]]]]]]]]]]]]]]]]]]]]] VxWorks 6.8 ]]]]]]]]]]]]]]]]]]]]]]]]]] KERNEL: WIND version 2.13 ]]]]]]]]]]]]]]]]]]]]]]]]] Copyright Wind River Systems, Inc., 1984-2009 CPU: ARM RealView PBX-A9. Processor #0. Memory Size: 0x40fa000. BSP version 2.0/0. Created: Sep 26 2013, 14:51:21 ED&R Policy Mode: Deployed ##### icc init ok!, cnt=1999, connet=1 0x340f9d7c (tRootTask): PMU PWR IRQ1 : 0x2 0x340f9d7c (tRootTask): PMU PWR IRQ2 : 0x0 0x340f9d7c (tRootTask): PMU PWR IRQ3 : 0x0 0x340f9d7c (tRootTask): PMU REG IRQ1 : 0x2 0x340f9d7c (tRootTask): PMU REG IRQ2 : 0x0 0x340f9d7c (tRootTask): PMU REG IRQ3 : 0x0 0x340f9d7c (tRootTask): PMU REG H_N_STATUS(0x43) : 0x0 0x340f9d7c (tRootTask): PMU REG H_N_STATUS(0x44) : 0x0 0x340f9d7c (tRootTask): PMU FLAG REG 0x4 : 0x0 0x340f9d7c (tRootTask): PMU FLAG REG 0x5 : 0x0 0x340f9d7c (tRootTask): PMU FLAG REG 0x6 : 0x0 0x340f9d7c (tRootTask): PMU FLAG REG 0x7 : 0x5 0x340f9d7c (tRootTask): PMU FLAG REG 0x8 : 0x5 0x340f9d7c (tRootTask): softtimer uninit! -> --->GPIO_2_4 id high,enter normal state Hisilicon NANDC_V4.00 initialize... NAND device: Manufacturer ID: 0xad, Chip ID: 0xaa (Hynix NAND 256MiB 1,8V 8-bit) Partition Table list(HEX):BOOTROM_V01.02H6920CS_UDP NO. |offset |loadsize |capacity |loadaddr |entry |property |count |id |name | ------------------------------------------------------------------------------------------------------- 01: 00000000 ,0000fbe4 ,00020000 ,2ffc0000 ,2ffc0000 ,00000000 ,00000002 ,00000101 ,BootLoad 02: 00020000 ,00000000 ,00180000 ,00000000 ,00000000 ,00000800 ,00000000 ,0000010d ,NvBackLTE 03: 001a0000 ,00000000 ,00100000 ,00000000 ,00000000 ,00000800 ,00000000 ,0000010e ,NvBackGU 04: 002a0000 ,000a264c ,00200000 ,30003f80 ,30004000 ,00000000 ,00000002 ,00000102 ,BootRom 05: 004a0000 ,000a267b ,00200000 ,30003f80 ,30004000 ,00000000 ,00000001 ,00000102 ,BootRom 06: 006a0000 ,016fd05c ,02000000 ,30003f80 ,30004000 ,00000000 ,00000002 ,00000103 ,VxWorks 07: 026a0000 ,00000000 ,00000000 ,00000000 ,00000000 ,00000000 ,00000000 ,00000110 ,Logo 08: 026a0000 ,00000000 ,00c00000 ,00000000 ,00000000 ,00000201 ,00000000 ,00000106 ,/yaffs0 09: 032a0000 ,0000f858 ,00060000 ,369e0000 ,369e0000 ,00000000 ,00000002 ,00000104 ,FastBoot 0a: 03300000 ,002a2000 ,003a0000 ,36a40000 ,36a40000 ,00000000 ,00000002 ,00000105 ,kernel 0b: 036a0000 ,01249800 ,01c00000 ,00000000 ,00000000 ,00004401 ,00000002 ,00000107 ,/yaffs1 0c: 052a0000 ,00000000 ,00500000 ,00000000 ,00000000 ,00004001 ,00000000 ,00000109 ,/yaffs3 0d: 057a0000 ,00000000 ,00000000 ,00000000 ,00000000 ,00004001 ,00000000 ,00000111 ,/yaffs4 0e: 057a0000 ,00000000 ,00000000 ,00000000 ,00000000 ,00004401 ,00000000 ,00000108 ,/yaffs2 0f: 057a0000 ,00000000 ,00080000 ,00000000 ,00000000 ,00004001 ,00000000 ,00000113 ,/yaffs6 10: 05820000 ,00000000 ,02260000 ,00000000 ,00000000 ,00004401 ,00000000 ,00000112 ,/yaffs5 11: 07a80000 ,00000000 ,08580000 ,00000000 ,00000000 ,00004000 ,00000000 ,0000010c ,cdromiso ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ptable_yaffs_mount: /yaffs0 ...yaffs: Mounting /yaffs0 yaffs: yaffs_GutsInitialise() yaffs: yaffs_GutsInitialise() done. OK. NVM_Init start! ****************LXML_DecodeMain enter******************** ****************LXML_DecodeMain over********************* Collecting block 320, in use 48, shrink 0, wholeBlock 1 Collecting block 318, in use 47, shrink 0, wholeBlock 1 Collecting block 324, in use 47, shrink 0, wholeBlock 1 Collecting block 330, in use 47, shrink 0, wholeBlock 1 MSP_IPC udi_open Start MSP_IPC udi_open End Handle = 5a0001 ++++++++++u32pmu2usbAddr,0x2fffe210,*u32pmu2usbAddr 0x55430001++++++++ ============BSP_DMA_Init in========= ============BSP_DMA_Init out========= after read nv 0xD100: uintValue 0xff ret = 0 normal power on, tick: 2048019677, Board time: 0xd8 Collecting block 333, in use 48, shrink 0, wholeBlock 1 ulZSPSize = 1238512! ulZSPSize = 0012e5f0, ulZSPReadSize = 0012e5f0 Read dsp file succeeded! Enter pwctrl initial routing! cdm_SetCoderSrcBufList pucDataBuf1 = 0x33464060 cdm_SetCoderSrcBufList pucDataBuf2 = 0x335b5060 cdm_SetCoderSrcBufList pucDataBuf3 = 0x335d0060 mcpu msp cdm waitSemaphore 0x340f9d7c (tRootTask): IFC Process init success! 0x340f9d7c (tRootTask): NVIM: C Core NVIM Init Begin! 0x340f9d7c (tRootTask): NVIM: C Core NVIM Init End! 0x340f9d7c (tRootTask): [PMU]USB insert 0x340f9d7c (tRootTask): pmu:save record start flag ok! 0x340f9d7c (tRootTask): PMU NV is 3,0,0,1! 0x340f9d7c (tRootTask): MEMDBG - addr of read-only page = 0x314a1000 0x340f9d7c (tRootTask): stNvSwVer-ulStatus is 0 0x340f9d7c (tRootTask): dload version:21.260.00.00.000 0x340f9d7c (tRootTask): SocpInit: connect tds bbp int OK. 0x340f9d7c (tRootTask): SocpInit: enable tds bbp OK. 0x340f9d7c (tRootTask): stNvSwVer-ulStatus is 0 0x340f9d7c (tRootTask): dload version:0[1ô[1[1 cò0 ***********MCPU REV CDM CODER DEST OK****************** ulModuleId: 3 enIpcAppId: 3 ulBuffLen : 4 ucBuff : 0x315AF3F8 mcpu msp cdm recv Semaphore GU_OamSocpCoderSrcCInit ulRet = 0x0 GU_OamSocpCoderSrcCStart ulRet = 0x0 UE_Root Start ! UE_Root end ! 0x340f9d7c (tRootTask): value1 is ff, value2 is ff, value is 0xffff 0x340f9d7c (tRootTask): --Maybe WM8990 is not exist, or communicate failure! 0x340f9d7c (tRootTask): --wm8990 codec is not exist. 0x340f9d7c (tRootTask): audio_create fail, result = 0xffffffff 0x340f9d7c (tRootTask): ========== HIFI read ========= !!!!! VOS_Startup Begin !!!!! ulHifiSize = 606700! ulHifiSize = 000941ec, ulHifiReadSize = 000941ec NOTE: Hifi file buffer Addr: 0x3363c010 Hifi bin release time : XTENSA:2013/09/26 15:21:36. process_mac_FidInit Copyright (C) 2004-2020 Hisilicon Technologies Co., Ltd. BalongV100R001,build on Sep 26 2013 15:22:17. ------------------------codec_open devname /dev/codec0 flags 0x0 mode 0x0 0x330fb820 (root): audio device not create yet! NAS_PTT_PidInit Pid:195 BSP_DDR_GetSectInfo g_ulDdrMemBase ok 0x37d00000! BSP_DDR_GetSectInfo g_ulSysRegBase ok 0x9000d000! BSP_DDR_GetSectInfo g_ulDhiMemBase ok 0x11000000! zkzlenth error zzzlenth error Start addr is 37d10380,1 ftm_MsgProcInit DRV_SDMMC_ADD_HOOK [007.21s][OK] sdmmcAddHook[0] is done! !!!!! VOS_Startup End !!!!! Read hifi file succeeded! 0x340f9d7c (tRootTask): ========== HIFI read ok ========= 0x336d0754 (F1_I1): ErrlogRegFunc entered 0x336ef274 (USIMM_FID): sci record ATR save OK! 0x336ef274 (USIMM_FID): sci record REG save OK! 0x336ef274 (USIMM_FID): sci record exc global variables begin: 0x336ef274 (USIMM_FID): sci record exc global variables OK! 0x336ef274 (USIMM_FID): sci tick get begin: 0x336ef274 (USIMM_FID): sci tick get End! 0x336ef274 (USIMM_FID): event save 1!pRegData=0x3426e330 0x336ef274 (USIMM_FID): sci record event save OK! 0x336ef274 (USIMM_FID): sci record file save OK! INFO :MNTN_ErrorLog:Can't Get Reset Info. NAS_MMC_GetPsStartInfo: 0 Collecting block 336, in use 46, shrink 0, wholeBlock 1 UimLockMsg_c 186 >> _$ Uimlock_UsimMsg: PS_USIM_GET_STATUS_IND NAS_MMC_SndAsStartReq, ulReceiverPid:128, ulRet:0. NAS_MMC_RcvGasStartCnf_SwitchOn_WaitGasStartCnf_ulResult = 0. 0x3311e264 (LRRC_FID): LHPA_CfgRF6360Info, LHPA_CfgRFInfo Succ 0x3311e264 (LRRC_FID): LHPA_LoadDsp,LOAD DSP SUCCESS! 0x3311eb4c (MACRLCUL_FID): LHPA_ProcSaveSelfAdjustPara NAS_MMC_RcvLmmStartCnf_SwitchOn_WaitLStartCnf_ulResult = 0. NAS_MMC_SndAsStartReq, ulReceiverPid:133, ulRet:0. NAS_UTRANCTRL_SndGuAsStartReq, ulReceiverPid:207, ulRet:0. Load Dsp 1! Load Dsp 2! Load Dsp 3! beg load section:.vect, load addr:0x13040000, len:260, flag:0x0 beg load section:.text, load addr:0x13048a00, len:113308, flag:0x0 beg load section:.data, load addr:0x13000000, len:25084, flag:0x0 beg load section:.dmc, load addr:0x13040400, len:1068, flag:0x0 beg load section:.statemain, load addr:0x13040a00, len:1596, flag:0x0 beg load section:.text1, load addr:0x13041800, len:3720, flag:0x0 beg load section:.asmtext, load addr:0x13042700, len:23772, flag:0x0 beg load section:.dynprotect, load addr:0x13065200, len:16, flag:0x0 beg load section:.dyntext, load addr:0x1307f000, len:640, flag:0x0 beg load section:.dataspecial, load addr:0x1300d000, len:4096, flag:0x1 beg load section:.nvm_data, load addr:0x1300e040, len:3168, flag:0x0 beg load section:.bss1, load addr:0x13012000, len:73616, flag:0x0 beg load section:.ovly, load addr:0x13026600, len:28672, flag:0x1 load ZSP SUCCESS Load Dsp 4! Load Dsp 5! Tds_Hl1_Write_DspNv_Parameter begin! 0x3311e264 (LRRC_FID): LHPA_ProcGetSelfAdjustPara Tds_Hl1_Write_DspNv_Parameter SUCCESS! Load Dsp 6! hl103_05InitDspToIrat 1 hl103_05InitDspToIrat 2 hl103_05InitDspToIrat 3 NAS_MMC_RcvWasStartCnf_SwitchOn_WaitWasStartCnf_ulResult = 0. Function DRV_START_MODEGET unsupport! NORMAL: TTF_MemPoolInfoEventRpt, Pool 0 Normal !NORMAL: TTF_MemPoolInfoEventRpt, Pool 1 Normal !NORMAL: TTF_MemPoolInfoEventRpt, Pool 2 Normal !0x3324eae0 (RR_FID): SHPA_LoadPhy: Start ! 0x3324eae0 (RR_FID): SHPA_LoadPhy: Load W DSP! 0x3324eae0 (RR_FID): SHPA_LoadPhy: Load DSP wait Sem! 0x3324eae0 (RR_FID): SHPA_LoadPhy: Load DSP OK! 0x3319d9c0 (tSoftTimerHandle): temperature_detect_timer_callback: sim adc = 1592 0x3319d9c0 (tSoftTimerHandle): temperature_detect_timer_callback: averge sim adc = 52746 UimLockMsg_dot_c 304 >> _$ Uimlock_AtMsg: usMsgName = 1 UimLockMsg_dot_c 304 >> _$ Uimlock_AtMsg: usMsgName = 1 Collecting block 337, in use 44, shrink 0, wholeBlock 1 Collecting block 348, in use 47, shrink 0, wholeBlock 1 0x340f9d7c (tRootTask): Exc1: remove file /yaffs0/DrvLog/amsg00000001. bin (2) 0x340f9d7c (tRootTask): Exc1: remove file /yaffs0/DrvLog/amsg00000001. bin (2) [M]->cmd [vxWorks]#help List of the registered topics: basic List of basic shell commands. breakpoint List of the shell commands related to breakpoints. filesystem List of the shell commands related to file system. interpreter Interpreter shell commands. memory List of the shell commands related to memory. modules List of the shell commands related to kernel modules. network Network commands object List of the shell commands related to objects. symbols List of the shell commands related to symbols. tasks List of the shell commands related to tasks. List of the registered commands: C Switch to C interpreter alias Add an alias or display alias arp IPNET arp control bp Display, set or unset a breakpoint cd Change current directory. demangle Display demangled string dprintf Insert a dynamic printf eventpoint echo Display a line of text exit Exit the shell session. expr Evaluate expressions file ... func ... getenv Get an environment variable help Display the list of the shell commands ifconfig IPNET interface configuration logout Logout the shell session. lookup Lookup a symbol mem ... module ... more Browse and page through a text file. object ... ping IPNET ping utility print ... printf Write formatted output pwd Display current working directory. reboot Reboot the system repeat Repeat a command set ... setenv Set an environment variable show ... slab Print slab cache information sleep Suspend execution for an interval. string ... sysctl IPNET sysctl configuration task ... unalias Remove an alias unset ... version Display VxWorks version information. [vxWorks]# C [M]->devs drv name 0 /null 1 /tyCo/0 8 host: 9 /yaffs0 value = 25 = 0x19 [M]->pwd host: value = 10 = 0xa [M]-> [M]-> exit Au revoir! When space is pressed at loading, following comes up: Code: onchip NF_boot---------------------------------------------------------- 00000001: 00000000 ,0000FBE4 ,00020000 ,2FFC0000 ,2FFC0000 ,00000000 ,00000002 ,00000101 ,BootLoad 00000002: 00020000 ,00000000 ,00180000 ,00000000 ,00000000 ,00000800 ,00000000 ,0000010D ,NvBackLTE 00000003: 001A0000 ,00000000 ,00100000 ,00000000 ,00000000 ,00000800 ,00000000 ,0000010E ,NvBackGU 00000004: 002A0000 ,000A264C ,00200000 ,30003F80 ,30004000 ,00000000 ,00000002 ,00000102 ,BootRom 00000005: 004A0000 ,000A267B ,00200000 ,30003F80 ,30004000 ,00000000 ,00000001 ,00000102 ,BootRom 00000006: 006A0000 ,016FD05C ,02000000 ,30003F80 ,30004000 ,00000000 ,00000002 ,00000103 ,VxWorks 00000007: 026A0000 ,00000000 ,00000000 ,00000000 ,00000000 ,00000000 ,00000000 ,00000110 ,Logo 00000008: 026A0000 ,00000000 ,00C00000 ,00000000 ,00000000 ,00000201 ,00000000 ,00000106 ,/yaffs0 00000009: 032A0000 ,0000F858 ,00060000 ,369E0000 ,369E0000 ,00000000 ,00000002 ,00000104 ,FastBoot 0000000A: 03300000 ,002A2000 ,003A0000 ,36A40000 ,36A40000 ,00000000 ,00000002 ,00000105 ,kernel 0000000B: 036A0000 ,01249800 ,01C00000 ,00000000 ,00000000 ,00004401 ,00000002 ,00000107 ,/yaffs1 0000000C: 052A0000 ,00000000 ,00500000 ,00000000 ,00000000 ,00004001 ,00000000 ,00000109 ,/yaffs3 0000000D: 057A0000 ,00000000 ,00000000 ,00000000 ,00000000 ,00004001 ,00000000 ,00000111 ,/yaffs4 0000000E: 057A0000 ,00000000 ,00000000 ,00000000 ,00000000 ,00004401 ,00000000 ,00000108 ,/yaffs2 0000000F: 057A0000 ,00000000 ,00080000 ,00000000 ,00000000 ,00004001 ,00000000 ,00000113 ,/yaffs6 00000010: 05820000 ,00000000 ,02260000 ,00000000 ,00000000 ,00004401 ,00000000 ,00000112 ,/yaffs5 00000011: 07A80000 ,00000000 ,08580000 ,00000000 ,00000000 ,00004000 ,00000000 ,0000010C ,cdromiso ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ sec disabled IsBootromStart value = %d00000000 press space key to enter bootrom: IMAGE_BOOTROM load from:0x002A0000>>loading: BootRom ... try inflate. image length: 000A25CC ram_inflate_addr: 3414538C inflating... return value: 00000000 inflate success! data check OK! hw main id:00000909, sub id:00000001Starting from entry: 0x300040Target Name: vxTarget Adding 5394 symbols for standalone. ]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]] ]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]] ]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]] ]]]]]]]]]]] ]]]] ]]]]]]]]]] ]] ]]]] (R) ] ]]]]]]]]] ]]]]]] ]]]]]]]] ]] ]]]] ]] ]]]]]]] ]]]]]]]] ]]]]]] ] ]] ]]]] ]]] ]]]]] ] ]]] ] ]]]] ]]] ]]]]]]]]] ]]]] ]] ]]]] ]] ]]]]] ]]]] ]]] ]] ] ]]] ]] ]]]]] ]]]]]] ]] ]]]]]]] ]]]] ]] ]]]] ]]]]] ] ]]]] ]]]]] ]]]]]]]] ]]]] ]] ]]]] ]]]]]]] ]]]] ]]]]]] ]]]]] ]]]]]] ] ]]]]] ]]]] ]] ]]]] ]]]]]]]] ]]]] ]]]]]]] ]]]]] ] ]]]]]] ] ]]] ]]]] ]] ]]]] ]]]] ]]]] ]]]] ]]]]]]]] ]]]]] ]]] ]]]]]]] ] ]]]]]]] ]]]] ]]]] ]]]] ]]]]] ]]]]]]]]]]]]]]]]]]]]]]]]]]]]]] ]]]]]]]]]]]]]]]]]]]]]]]]]]]]] Development System ]]]]]]]]]]]]]]]]]]]]]]]]]]]] ]]]]]]]]]]]]]]]]]]]]]]]]]]] VxWorks 6.8 ]]]]]]]]]]]]]]]]]]]]]]]]]] KERNEL: WIND version 2.13 ]]]]]]]]]]]]]]]]]]]]]]]]] Copyright Wind River Systems, Inc., 1984-2009 CPU: ARM RealView PBX-A9. Processor #0. Memory Size: 0x40fa000. BSP version 2.0/0. Created: Sep 26 2013, 14:51:41 ED&R Policy Mode: Deployed ===== beg mem usr function ===== Hisilicon NANDC_V4.00 initialize... NAND device: Manufacturer ID: 0xad, Chip ID: 0xaa (Hynix NAND 256MiB 1,8V 8-bit) Partition Table list(HEX):BOOTROM_V01.02H6920CS_UDP NO. |offset |loadsize |capacity |loadaddr |entry |property |count |id |name | ------------------------------------------------------------------------------------------------------- 01: 00000000 ,0000fbe4 ,00020000 ,2ffc0000 ,2ffc0000 ,00000000 ,00000002 ,00000101 ,BootLoad 02: 00020000 ,00000000 ,00180000 ,00000000 ,00000000 ,00000800 ,00000000 ,0000010d ,NvBackLTE 03: 001a0000 ,00000000 ,00100000 ,00000000 ,00000000 ,00000800 ,00000000 ,0000010e ,NvBackGU 04: 002a0000 ,000a264c ,00200000 ,30003f80 ,30004000 ,00000000 ,00000002 ,00000102 ,BootRom 05: 004a0000 ,000a267b ,00200000 ,30003f80 ,30004000 ,00000000 ,00000001 ,00000102 ,BootRom 06: 006a0000 ,016fd05c ,02000000 ,30003f80 ,30004000 ,00000000 ,00000002 ,00000103 ,VxWorks 07: 026a0000 ,00000000 ,00000000 ,00000000 ,00000000 ,00000000 ,00000000 ,00000110 ,Logo 08: 026a0000 ,00000000 ,00c00000 ,00000000 ,00000000 ,00000201 ,00000000 ,00000106 ,/yaffs0 09: 032a0000 ,0000f858 ,00060000 ,369e0000 ,369e0000 ,00000000 ,00000002 ,00000104 ,FastBoot 0a: 03300000 ,002a2000 ,003a0000 ,36a40000 ,36a40000 ,00000000 ,00000002 ,00000105 ,kernel 0b: 036a0000 ,01249800 ,01c00000 ,00000000 ,00000000 ,00004401 ,00000002 ,00000107 ,/yaffs1 0c: 052a0000 ,00000000 ,00500000 ,00000000 ,00000000 ,00004001 ,00000000 ,00000109 ,/yaffs3 0d: 057a0000 ,00000000 ,00000000 ,00000000 ,00000000 ,00004001 ,00000000 ,00000111 ,/yaffs4 0e: 057a0000 ,00000000 ,00000000 ,00000000 ,00000000 ,00004401 ,00000000 ,00000108 ,/yaffs2 0f: 057a0000 ,00000000 ,00080000 ,00000000 ,00000000 ,00004001 ,00000000 ,00000113 ,/yaffs6 10: 05820000 ,00000000 ,02260000 ,00000000 ,00000000 ,00004401 ,00000000 ,00000112 ,/yaffs5 11: 07a80000 ,00000000 ,08580000 ,00000000 ,00000000 ,00004000 ,00000000 ,0000010c ,cdromiso ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ptable_yaffs_mount: /yaffs0 ...yaffs: Mounting /yaffs0 yaffs: yaffs_GutsInitialise() yaffs: yaffs_GutsInitialise() done. OK. ptable_yaffs_mount: /yaffs1 ...yaffs: Mounting /yaffs1 yaffs: yaffs_GutsInitialise() yaffs: yaffs_GutsInitialise() done. OK. ptable_yaffs_mount: /yaffs2 ...CANCEL!************* ptable_yaffs_mount: /yaffs5 ...yaffs: Mounting /yaffs5 yaffs: yaffs_GutsInitialise() yaffs: yaffs_GutsInitialise() done. OK. Collecting block 400, in use 47, shrink 0, wholeBlock 1 0x340f9d7c (tRootTask): PMU PWR IRQ1 : 0x0 0x340f9d7c (tRootTask): PMU PWR IRQ2 : 0x8 0x340f9d7c (tRootTask): PMU PWR IRQ3 : 0x0 0x340f9d7c (tRootTask): PMU REG IRQ1 : 0x0 0x340f9d7c (tRootTask): PMU REG IRQ2 : 0x8 0x340f9d7c (tRootTask): PMU REG IRQ3 : 0x0 0x340f9d7c (tRootTask): PMU REG H_N_STATUS(0x43) : 0x0 0x340f9d7c (tRootTask): PMU REG H_N_STATUS(0x44) : 0x0 0x340f9d7c (tRootTask): PMU FLAG REG 0x4 : 0x0 0x340f9d7c (tRootTask): PMU FLAG REG 0x5 : 0x0 0x340f9d7c (tRootTask): PMU FLAG REG 0x6 : 0x0 0x340f9d7c (tRootTask): PMU FLAG REG 0x7 : 0x5 0x340f9d7c (tRootTask): PMU FLAG REG 0x8 : 0x5 0x340f9d7c (tRootTask): softtimer uninit! 0x340f9d7c (tRootTask): hw main id:0x909, sub id:0x1 0x340f9d7c (tRootTask): [PMU]USB insert 0x340f9d7c (tRootTask): PMU NVM_Read ERROR. 0x340f9d7c (tRootTask): getFactoryMode:not in factory mode! 0x340f9d7c (tRootTask): no need to do fota update 0x3035b680 (tUSBTask): BSP_USB_GetDevDescIdx: MDM+PCUI+DIAG in Bootrom image 0x3035b680 (tUSBTask): Starting USBware stack, Version 3.4.30.21 -> 0x340f7738 (uw_Controller): Acm:1 Suspend 0x340f7738 (uw_Controller): Acm:2 Suspend 0x340f7738 (uw_Controller): Acm:3 Suspend 0x340f7738 (uw_Controller): ACM:1 Enable, line:531 0x340f7738 (uw_Controller): ACM:2 Enable, line:531 0x340f7738 (uw_Controller): ACM:3 Enable, line:531 0x302b1edc (tSoftTimerHandle): temperature_detect_timer_callback: sim adc = 1777 0x302b1edc (tSoftTimerHandle): temperature_detect_timer_callback: averge sim adc = 52783 0x302b1edc (tSoftTimerHandle): temperature_detect_timer_callback: sim adc = 1763 0x302b1edc (tSoftTimerHandle): temperature_detect_timer_callback: averge sim adc = 40029 [M]-> [M]->task C interp: unknown symbol name 'task'. [M]->ts sorry, the shell can't suspend itself. value = 10 = 0xa [M]-> [M]->cmd shellLib: interpreter 'Cmd' not registered. [M]->help help Print this list dbgHelp Print debugger help info edrHelp Print ED&R help info ioHelp Print I/O utilities help info nfsHelp Print nfs help info netHelp Print network help info rtpHelp Print process help info spyHelp Print task histogrammer help info timexHelp Print execution timer help info h [n] Print (or set) shell history i [task] Summary of tasks' TCBs ti task Complete info on TCB for task sp adr,args... Spawn a task, pri=100, opt=0x19, stk=20000 taskSpawn name,pri,opt,stk,adr,args... Spawn a task tip "dev=device1#tag=tagStr1", "dev=device2#tag=tagStr2", ... Connect to one or multiple serial lines td task Delete a task ts task Suspend a task tr task Resume a task Type <CR> to continue, Q<CR> or q<CR> to stop: tw task Print pending task detailed info w [task] Print pending task info d [adr[,nunits[,width]]] Display memory m adr[,width] Modify memory mRegs [reg[,task]] Modify a task's registers interactively pc [task] Return task's program counter iam "user"[,"passwd"] Set user name and passwd whoami Print user name devs List devices ld [syms[,noAbort][,"name"]] Load stdin, or file, into memory (syms = add symbols to table: -1 = none, 0 = globals, 1 = all) lkup ["substr"] List symbols in system symbol table lkAddr address List symbol table entries near address checkStack [task] List task stack sizes and usage printErrno value Print the name of a status value period secs,adr,args... Spawn task to call function periodically repeat n,adr,args... Spawn task to call function n times (0=forever) version Print VxWorks version info, and boot line shConfig ["config"] Display or set shell configuration variables Type <CR> to continue, Q<CR> or q<CR> to stop: strFree [address] Free strings allocated within the shell (-1=all) NOTE: Arguments specifying 'task' can be either task ID or name. value = 10 = 0xa [M]->devs drv name 0 /null 1 /tyCo/0 5 /yaffs0 5 /yaffs1 5 /yaffs5 6 /acm/1 6 /acm/2 6 /acm/3 value = 25 = 0x19 [M]->cd "/yaffs0" C interp: syntax error. Code: rom booting... DDR! Hit <ctrl+c> to stop autoboot: 0 try to bootsel1 = bootsel 0 20000 40000!!! ## Starting application at 0x86000000 ... U-Boot 2010.03-svn ( 9ÔÂ 26 2013 - 20:57:59) DRAM: 128 MB Boot From NAND Flash NAND: Special Nand id table Version 1.23 Nand ID: 0x98 0xD1 0x90 0x15 0x76 0x14 0x01 0x00 Nand(Hardware): NAND device: Manufacturer ID: 0x98, Chip ID: 0xd1 (Toshiba NAND 128MiB 3,3V 8-bit) Block:128KB Page:2KB Chip:128MB*1 OOB:64B ECC:4Bytes 128 MiB bbt base ram Scanning device for bad blocks... *** Warning - bad CRC or NAND, using default environment In: serial Out: serial Err: serial MEM_MODE = DDR! Hit <ctrl+c> to stop autoboot: 0 entry gpio values:0x00100000 ---- bootmtd from nand flash---- found 0 boot from main! ######## copy 2112300 bytes successful! ## Booting kernel from Legacy Image at 86000000 ... Image Name: Linux-2.6.30 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2112236 Bytes = 2 MB Load Address: 81000000 Entry Point: 81000000 kernel data at 0x86000040, len = 0x00203aec (2112236) Loading Kernel Image ... OK OK found 0 Starting kernel ... init started: BusyBox vv1.9.1 (2013-09-26 20:51:58 CST) starting pid 271, tty '': '/etc/init_dot_d/rcS' RCS DONE starting pid 273, tty '': '/bin/sh' BusyBox vv1.9.1 (2013-09-26 20:51:58 CST) built-in shell (ash) Enter 'help' for a list of built-in commands. rootdir=/ table='/etc/devicetable' mount: mounting /dev/mtdblock13 on /coredump failed: Input/output error cat: can't open '/etc/router_dot_version': No such file or directory Loading SDK modules Loading HSAN modules Loading WLAN modules ifconfig: SIOCGIFFLAGS: No such device bridge br0 does not exist! ========================================= start hisilicon access platform ========================================= hisilicon init sd5115 chip successfully ...! ========================================== function name= hi_kernel_accel_cmdtype_config_set attribute(00)-alias(hw ) = 00000000 attribute(01)-alias(sw ) = 00000001 ========================================== Loading drivers and kernel modules... [main: 4856L]:exit func regist ok [udp_server_main: 2001L]:Udp initialize successful udp_server_main:2004 g_udpfd=4 parent_pid=400 [main: 4880L]:Main branch continue execute! Unable to open device /dev/bhal. [main: 4943L]:Tcp initialize successful ========================================== function name= hi_wancmd_add_ext attribute(00)-alias(vifname ) = bcm-ssid0 attribute(01)-alias(devname ) = ra0 attribute(02)-alias(phyport ) = 00000009 ========================================== ========================================== function name= hi_wancmd_add_ext attribute(00)-alias(vifname ) = vrmnet0 attribute(01)-alias(devname ) = rmnet0 attribute(02)-alias(phyport ) = 0000000a ========================================== Start mic now ... Unable to open device /dev/bhal. Unable to open device /dev/bhal. GlobeMac Init load cfm ok. mkdir: cannot create directory '/coredump': File exists chmod: /coredump: Read-only file system ##sendmsg return 16, errno 0. INSMOD START...... insmod: cannot insert '/lib/extra/rt5390ap_dot_ko': File exists INSMOD Done ifconfig: SIOCGIFFLAGS: No such device ifconfig: SIOCSIFHWADDR: No such device ifconfig: SIOCGIFFLAGS: No such device interface eth0.3 does not exist! ifconfig: SIOCGIFFLAGS: No such device ifconfig: SIOCGIFFLAGS: No such device ifconfig: SIOCSIFHWADDR: No such device ifconfig: SIOCGIFFLAGS: No such device interface eth0.4 does not exist! ifconfig: SIOCGIFFLAGS: No such device Invalid port: should is <0-3> lanchip {enable|disable} enable/disable all port of lan chip[port 0-3] enable/disable a port of lan chip device eth0 is not a slave of br0 atp: cur kernel version:[2.6.30] ========================================== function name= hi_kernel_misc_util_inner_mdiowrite attribute(00)-alias(phy_addr ) = 00000001 attribute(01)-alias(reg_addr ) = 00000000 attribute(02)-alias(data ) = 3900 attribute(03)-alias(resv ) = 0000 ========================================== ========================================== function name= hi_kernel_misc_util_inner_mdiowrite attribute(00)-alias(phy_addr ) = 00000001 attribute(01)-alias(reg_addr ) = 00000000 attribute(02)-alias(data ) = 3100 attribute(03)-alias(resv ) = 0000 ========================================== ========================================== function name= hi_kernel_misc_util_inner_mdiowrite attribute(00)-alias(phy_addr ) = 00000002 attribute(01)-alias(reg_addr ) = 00000000 attribute(02)-alias(data ) = 3900 attribute(03)-alias(resv ) = 0000 ========================================== ========================================== function name= hi_kernel_misc_util_inner_mdiowrite attribute(00)-alias(phy_addr ) = 00000002 attribute(01)-alias(reg_addr ) = 00000000 attribute(02)-alias(data ) = 3100 attribute(03)-alias(resv ) = 0000 ========================================== ========================================== function name= hi_kernel_misc_util_inner_mdiowrite attribute(00)-alias(phy_addr ) = 00000003 attribute(01)-alias(reg_addr ) = 00000000 attribute(02)-alias(data ) = 3900 attribute(03)-alias(resv ) = 0000 ========================================== ========================================== function name= hi_kernel_misc_util_inner_mdiowrite attribute(00)-alias(phy_addr ) = 00000003 attribute(01)-alias(reg_addr ) = 00000000 attribute(02)-alias(data ) = 3100 attribute(03)-alias(resv ) = 0000 ========================================== ========================================== function name= hi_kernel_misc_util_inner_mdiowrite attribute(00)-alias(phy_addr ) = 00000004 attribute(01)-alias(reg_addr ) = 00000000 attribute(02)-alias(data ) = 3900 attribute(03)-alias(resv ) = 0000 ========================================== ip6_min=fd00:: ip6_max=fdff:ffff:ffff:ffff:ffff:ffff:ffff:ffff ========================================== function name= hi_kernel_misc_util_inner_mdiowrite attribute(00)-alias(phy_addr ) = 00000004 attribute(01)-alias(reg_addr ) = 00000000 attribute(02)-alias(data ) = 3100 attribute(03)-alias(resv ) = 0000 ========================================== 0 ifconfig: SIOCGIFFLAGS: No such device ========================================== function name= hi_kernel_misc_util_inner_mdiowrite attribute(00)-alias(phy_addr ) = 00000004 attribute(01)-alias(reg_addr ) = 00000000 attribute(02)-alias(data ) = 3900 attribute(03)-alias(resv ) = 0000 ========================================== ========================================== function name= hi_kernel_misc_util_inner_mdiowrite attribute(00)-alias(phy_addr ) = 00000004 attribute(01)-alias(reg_addr ) = 00000000 attribute(02)-alias(data ) = 3100 attribute(03)-alias(resv ) = 0000 ========================================== dms init come in set no private ioctls. set no private ioctls. Get mac3: 3CDFBDXXXXX Get mac3: 3CDFBDXXXXX Get mac3: 3CDFBDXXXXX Get mac3: 3CDFBDXXXXX begin WlanUpInterfaces... ========================================== function name= hi_kernel_gpio_cmdtype_bit_write attribute(00)-alias(port ) = 00000001 attribute(01)-alias(bit ) = 00000014 attribute(02)-alias(level ) = 00000000 ========================================== wait_wm_ready:Pcui is existent srv_status nok 1 at_repetition_query g_sysinfoRoamingStatus=<1>,ucRoamStatus=<1> begin WlanSetChannel... PHY mode status=9 begin WlanStartServices... [1-----3internet-----*99#--------------NONE ] [2-----3internet-----*99#--------------NONE ] [3-----some link-----*99#--------------NONE ] [4-----some link-----*99#--------------NONE ] [5-----some link-----*99#--------------NONE ] [6-----some link-----*99#--------------NONE ] [7-----some link-----*99#--------------NONE ] [8-----some link-----*99#--------------NONE ] set redirection success ! Recvd netlink msg now ... Cms netlink msg 173015048 finished. Recvd netlink msg now ... Cms netlink msg 173015048 finished. Recvd netlink msg now ... Cms netlink msg 173015048 finished. Recvd netlink msg now ... Cms netlink msg 173015048 finished. WanSetRedirection has been set ! Recvd netlink msg now ... Cms netlink msg 173015048 finished. WanSetRedirection has been set ! ************************Write db to flash now ... done sync ATP_DMS_StartByUsbmount g_bDmsEnable == VOS_FALSE =====ATP_StorageServiceControlByUsbmount: check printer now...===== Code: rom booting... DDR! Hit <ctrl+c> to stop autoboot: 0 try to bootsel1 = bootsel 0 20000 40000!!! ## Starting application at 0x86000000 ... U-Boot 2010.03-svn ( 9ÔÂ 26 2013 - 20:57:59) DRAM: 128 MB Boot From NAND Flash NAND: Special Nand id table Version 1.23 Nand ID: 0x98 0xD1 0x90 0x15 0x76 0x14 0x01 0x00 Nand(Hardware): NAND device: Manufacturer ID: 0x98, Chip ID: 0xd1 (Toshiba NAND 128MiB 3,3V 8-bit) Block:128KB Page:2KB Chip:128MB*1 OOB:64B ECC:4Bytes 128 MiB bbt base ram Scanning device for bad blocks... *** Warning - bad CRC or NAND, using default environment In: serial Out: serial Err: serial MEM_MODE = DDR! Hit <ctrl+c> to stop autoboot: 0 hisilicon # hisilicon # help ? - alias for 'help' base - print or set address offset bbt - display bbt info bootm - boot application image from memory bootp - boot image via network using BOOTP/TFTP protocol ccs - change double system boot flag,ccs 0~5 cmp - memory compare cmpdata - compare the data in different address crc32 - checksum calculation ge_phy - ge phy utility commands go - start application at address 'addr' gpio_read- gpio_read gpioid(0-128) flag(0:data | 1:dir | 2:mode) gpio_write- gpio_write gpioid(0-128) flag(0:data | 1:dir | 2:mode) value(0 | 1) help - print command description/usage inner_phy- inner phy utility commands load_image- load image to nandflash, and boot load_nf_kernel- load kernel to nand flash load_nf_rootfs- load rootfs to nand flash load_nf_uboot- load u-boot to nand flash load_sf_kernel- load kernel to spi flash load_sf_rootfs- load rootfs to spi flash load_sf_uboot- load u-boot to spi flash loop - infinite loop on address range md - memory display mii - MII utility commands mm - memory modify (auto-incrementing address) mtest - simple RAM read/write test mw - memory write (fill) nand - NAND sub-system nboot - boot from NAND device nm - memory modify (constant address) phy_powerdown- all phy powerdown phy_powerup- all phy powerup ping - send ICMP ECHO_REQUEST to network host pphy - patch genius phy printenv- print environment variables rarpboot- boot image via network using RARP/TFTP protocol rcs - get double system boot flag reset - Perform RESET of the CPU saveenv - save environment variables to persistent storage setenv - set environment variables sf - SPI flash sub-system tftpboot- boot image via network using TFTP protocol version - print monitor version hisilicon # ls Unknown command 'ls' - try 'help' hisilicon # version U-Boot 2010.03-svn ( 9ÔÂ 26 2013 - 20:57:59) hisilicon # bootm Wrong Image Format for bootm command ERROR: can't get kernel image! MEM_MODE = DDR! hisilicon # nboot ** No boot device ** They talked about when pressing the wifi-button at boot, a TFPT-service shows up waiting for a binary (packet. bin). And, suprise, it's the same here: Code: rom booting... DDR! Hit <ctrl+c> to stop autoboot: 0 try to bootsel1 = bootsel 0 20000 40000!!! ## Starting application at 0x86000000 ... U-Boot 2010.03-svn ( 9ÔÂ 26 2013 - 20:57:59) DRAM: 128 MB Boot From NAND Flash NAND: Special Nand id table Version 1.23 Nand ID: 0x98 0xD1 0x90 0x15 0x76 0x14 0x01 0x00 Nand(Hardware): NAND device: Manufacturer ID: 0x98, Chip ID: 0xd1 (Toshiba NAND 128MiB 3,3V 8-bit) Block:128KB Page:2KB Chip:128MB*1 OOB:64B ECC:4Bytes 128 MiB bbt base ram Scanning device for bad blocks... *** Warning - bad CRC or NAND, using default environment In: serial Out: serial Err: serial MEM_MODE = DDR! Hit <ctrl+c> to stop autoboot: 0 entry gpio values:0x00000000 entry gpio 1 values:0x00000000 entry gpio 1 values:0x00000000 entry gpio 1 values:0x00000000 entry gpio 1 values:0x00000000 entry gpio 1 values:0x00000000 entry gpio 1 values:0x00000000 entry gpio 1 values:0x00000000 entry gpio 1 values:0x00000000 entry gpio 1 values:0x00000000 entry gpio 1 values:0x00000000 MEM_MODE = DDR! start read image file to DDR... load_addr = 0x86000000, file_name = packet. bin TFTP from server (IP here, no links allowed -.-); our IP address is (IP here, no links allowed -.-) Filename 'packet. bin'. Load address: 0x86000000 Loading: T T T T T T T T T T T T T T T T T T T T Retry count exceeded; starting again TFTP from server (IP here, no links allowed -.-); our IP address is (IP here, no links allowed -.-) Filename 'packet. bin'. Load address: 0x86000000 Loading: T T T T T T T T T T T T T T T T T T T T Retry count exceeded; starting again TFTP from server (IP here, no links allowed -.-); our IP address is (IP here, no links allowed -.-) Filename 'packet. bin'. Load address: 0x86000000 Loading: T T T T T T T T T T T T T T T T T T T T ... ... about 10x ... ... ARP Retry timeout resetting ... Also, HiStudio was mentioned and a AT/DIAG port. NMap brought up following open ports: ------ TCP -------- 53 80 1280 33443 37215 37443 ----- UDP --------- 53 67 514 1900 18234 18676 20359 20424 33281 36108 40441 41058 42056 45247 49396 53037 I guess many of the UDP are false-positives. Well, but after all this i'm stuck again. Dunno what to do next... |
07-02-2016, 20:21 | #5 (permalink) |
Member: 2587501 Status: Offline Thanks Meter: 5 | I was able to dump the whole 128MB-Nand. I found 4 jffs2-filesystems. In 2 of them, there was a boot-able Linux Kernel (Linux kernel version "2.6.30 () (gcc version 4.4.6 (crosstool-NG 1.13.2 - hsan-5115) ), the 3rd contained the whole html/js/css stuff. 4th is just images. I found some interesting files,but i didn't analyzed all of them yet (some certs, .pem and bunch of config files). I was interested in getting somehow a shell on the running system to issue some at-command. Good thing: there exists an Code: atcmd I started with reverse engineering the webserver, looking for some fail in input handling. The webservice they use seems to be a self written server called Code: web I've now analyzed this for about 20h+, no luck. The only vulnerable Code: system("....%s...") All other system-calls are with static strings. There isn't even a string-format-attacksurface anywhere. Well, it's not D-Link i guess. They even encrypt the Pin-transmission over TCP/IP with the IMEI in javascript! (Well, no strong encryption, but hey, better than nothing) I further found all the initialization is done by a binary called Code: mic |
10-25-2017, 17:25 | #6 (permalink) |
Junior Member Join Date: Oct 2017
Member: 2771765 Status: Offline Thanks Meter: 0 | Hello, awesome info in this thread. Have you managed to unlock it? I am having the same problem these days (weeks) so I am hoping to hearing from you soon... Thanks in advance! |
