GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
04-02-2016, 11:29 | #1 (permalink) |
Insane Poster Join Date: Feb 2008
Member: 700717 Status: Offline Thanks Meter: 7 | Huawei E5172As-22 by NOS after update cannot login I try to reset pressing reset button for 10 sec. but same problem, no login, after i try other firmware versions (V200R001C00SP066, etc...) but same no login. I can login again only if i come back to original firmware version: V200R001C58SP102. Someone can help me? Thanks and BR Giocon71 |
04-07-2016, 12:10 | #4 (permalink) |
Junior Member Join Date: Nov 2008
Member: 897566 Status: Offline Thanks Meter: 2 | You can try this, but before you begin think that you have some possibilities to brick your router. 1. Edit and fit to C58 Russian firmware C314SP100 and flash it; 2. Edit and fit to C58 firmware C209SP205 and Flash it; 3. Flash C00SP208 general firmware without any modification. Good luck Tell me if this work |
The Following User Says Thank You to ToTo_fixe For This Useful Post: |
04-12-2016, 16:54 | #5 (permalink) |
Member: 700717 Status: Offline Thanks Meter: 7 | I try this sequence but same results, all update are succesfully (after first update to megafone firmware i cannot login and i use E5172 Updater tool), also i try to change PC and Browser (delete chache too...), but when in web management page i put user / password admin/admin i cannot login. If i come back to original firmware version i can login again |
06-01-2016, 20:26 | #9 (permalink) | |
Junior Member Join Date: Sep 2003
Member: 40270 Status: Offline Thanks Meter: 0 | Quote:
Thank you | |
11-09-2018, 12:04 | #12 (permalink) |
Junior Member Join Date: Nov 2012
Member: 1840716 Status: Offline Thanks Meter: 0 | Hi, I have the same router. Have you tried using the update tool with huawei firmware E5172As-22(V200R001C58SP100,Portugal,operatorValue,05012FS Q) to fix what's wrong? Also ,how did update with the no brand firmware? I am trying to do the same. |
11-11-2018, 02:08 | #13 (permalink) | |
Product Manager Join Date: May 2008 Location: Ukraine Age: 45
Member: 772096 Status: Offline Sonork: 100.69222 Thanks Meter: 8,277 | Quote:
http://forum.gsmhosting.com/vbb/f695...-beta-1336989/ | |
01-10-2019, 20:48 | #14 (permalink) |
Member: 1840716 Status: Offline Thanks Meter: 0 | New login is: login: Superuser pass: wowygsk#us!r!564 Or to find out: After flashing (wouldn't hurt full hard reset) connect via SSH to the router using admin. If the connection will swear by the key exchange diffie-hellman-group1-sha1, try with the key ssh oKexAlgorithms = + diffie-hellman-group1-sha1 Enter password SSH: 4E044890 When entering via SSH Dial: sh at AT ^ WUUSER? AT ^ WUPWD? The last two lines of this username and password to the Web interface of the router. In my case it is wowygsk and Superuser # us! r! 564 more infos: post from forum zwame post from 4pda ru |
