Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM / HSDPA Modems and Routers
GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares
Old 04-02-2016, 11:29   #1 (permalink)
Member: 700717
Thanks Meter: 7
Huawei E5172As-22 by NOS after update cannot login
Hi to All, i've a couple of Huawei E5172As-22 branded NOS firmware version V200R001C58SP102 (Portughese mobile operator) and i've successfully update with no brand firmware version V200R001C00SP208 ,but after i cannot login in web interface (192.168.1.1), user/pwd: admin , admin but no login!
I try to reset pressing reset button for 10 sec. but same problem, no login, after i try other firmware versions (V200R001C00SP066, etc...) but same no login. I can login again only if i come back to original firmware version: V200R001C58SP102. Someone can help me?
Thanks and BR
Giocon71
Old 04-05-2016, 15:24   #2 (permalink)
Member: 897566
Thanks Meter: 2
Hi, can you tell me, all the steps you do to update the general firmware 208 ?
thanks.
Old 04-05-2016, 19:12   #3 (permalink)
Member: 700717
Thanks Meter: 7
Need to edit generic firmware file to fit C58 brand version, but after you cannot access more in web page admin (192.168.1.1)
Giocon71
Old 04-07-2016, 12:10   #4 (permalink)
Member: 897566
Thanks Meter: 2
You can try this, but before you begin think that you have some possibilities to brick your router.
1. Edit and fit to C58 Russian firmware C314SP100 and flash it;
2. Edit and fit to C58 firmware C209SP205 and Flash it;
3. Flash C00SP208 general firmware without any modification.
Good luck
Tell me if this work
The Following User Says Thank You to ToTo_fixe For This Useful Post:
Old 04-12-2016, 16:54   #5 (permalink)
Member: 700717
Thanks Meter: 7
I try this sequence but same results, all update are succesfully (after first update to megafone firmware i cannot login and i use E5172 Updater tool), also i try to change PC and Browser (delete chache too...), but when in web management page i put user / password admin/admin i cannot login.
If i come back to original firmware version i can login again
Old 04-17-2016, 22:47   #6 (permalink)
Member: 897566
Thanks Meter: 2
Try this:
User name: admin
Password: CPE#123456 123456 are the last six numbers of your E5172 serial number
Old 04-24-2016, 06:58   #7 (permalink)
Member: 553143
giocon71, i am facing the same problem ... after flashing to V200R001C00SP208, cannot login to web management.
Have you found a solution?
Old 04-26-2016, 07:02   #8 (permalink)
Member: 700717
Thanks Meter: 7
Hi, at moment no solution, i try downgrade and upgrade different firmware and User/Password but no solution.
Thanks & BR
Old 06-01-2016, 20:26   #9 (permalink)
Member: 40270
Thanks & BR
How did you manage to downgrade from 208 ? After using file MPWUDPUPDATE_102_208.BIN to change from c58 to c00 I have the admin admin problem but haven't been able to change back to C58 firmware. Care to share how to flash back ?
Thank you
Old 09-26-2017, 18:44   #10 (permalink)
Member: 1638782
Thanks Meter: 4
I have same problem with E5172s-927 V200R001C115SP100 (ooredoo Oman).
Is there any way for this problem?
Old 10-15-2017, 19:29   #11 (permalink)
THE GREAT ONE's Avatar
Member: 751235
Sonork: 100.1662008
Thanks Meter: 526
i was having same problem... but have solve it.. i unlock with dc unlocker... now using glo ghana sim fine
Old 11-09-2018, 12:04   #12 (permalink)
Member: 1840716
Hi,
I have the same router. Have you tried using the update tool with huawei firmware E5172As-22(V200R001C58SP100,Portugal,operatorValue,05012FS Q) to fix what's wrong?
Also ,how did update with the no brand firmware? I am trying to do the same.
Old 11-11-2018, 02:08   #13 (permalink)
TestBox2's Avatar
Member: 772096
Sonork: 100.69222
Thanks Meter: 8,277
Thanks and BR
Giocon71
read info via mkeysoftware nd you see login pass
http://forum.gsmhosting.com/vbb/f695...-beta-1336989/
Old 01-10-2019, 20:48   #14 (permalink)
Member: 1840716
New login is:
login: Superuser
pass: wowygsk#us!r!564
Or to find out:
After flashing (wouldn't hurt full hard reset) connect via SSH to the router using admin.
If the connection will swear by the key exchange diffie-hellman-group1-sha1, try with the key
ssh oKexAlgorithms = + diffie-hellman-group1-sha1
Enter password SSH: 4E044890
When entering via SSH
Dial:
sh
at
AT ^ WUUSER?
AT ^ WUPWD?
The last two lines of this username and password to the Web interface of the router.
In my case it is wowygsk and Superuser # us! r! 564
more infos:
post from forum zwame
post from 4pda ru
Page generated in 0.21259 seconds with 9 queries
