Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM / HSDPA Modems and Routers
GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares
Old 12-11-2016, 05:47   #46 (permalink)
Member: 1970813
Sonork: kofi
Thanks Meter: 14
Originally Posted by Bossmd View Post
Please I have a problem, during bootshot I noticed the new device installing in task bar but after that I could not see the desired ports under device manager, I have tried bootshot like 6 times now still the same problem, the ports are not showing inn device manager. Also I can no longer view my Mifi Web UI like before again, when I connect the mifi to PC, the web UI is not loading again. My device is the MTN locked Huawei E5573Cs-322. Please help. What can I do to see the ports? How do I use the USB loader bin file? Help please
I will appreciate if you can put me through the step by step, I have downloaded all the new files uploaded, how do I use them? When do I use each file at which step? The problem I have now is that I can not view the "Huawei 3G ports in device manager". I have tried more than 6 times already. When I double clicked on the USB loader bin file it was opened by my PC VLC player and nothing happened. Is this normal? How do I utilize the usb loader bin file? Thanks for your anticipated assistance.
Install Huawei mobile partner for drives
1. Run Balong tool.
2. Click “Detect” button. It will show COM Port with “BOOT_3G”.
3. Locate the “Loader” file which you have got in the email.
4. Click on “Load”
5. Once progress bar reaches the end, you will again notice something is installing on your PC.
Note: You can check in COM ports, you will see two Huawei ports.
Old 12-11-2016, 06:01   #47 (permalink)
Member: 1970813
Sonork: kofi
Thanks Meter: 14
if u are having problem loading the usb loader , then take a look of this link
https://s28.postimg.org/79ig30obh/ba...01_696x604.jpg
Old 12-11-2016, 13:57   #48 (permalink)
Member: 592519
i have done all the process successfully. but browser doesnt open but can open manually by entering ip address.
now let me know how to rewrite the imei........?
i tried putty it shows cme error 0.
kindly help
Old 12-11-2016, 17:45   #49 (permalink)
Member: 1970813
Sonork: kofi
Thanks Meter: 14
how to write imei e5573
kindly help
when u did the boot shot imei and ur s/n will become 00000000000
so u have to rewite it with dc-unlocker like this
u will run dc-unlocker as an administrator then Click “Detect” button if the dc-unlock it, then ur will copy this :
AT^DATALOCK="00000000"
at the bottom of the line and click enter on ur key broad, if all things goes well it will ok then u can now rewrite ur imei by pasteing this with ur imei AT^DATALOCK="ur imei" then click enter on ur key broad and it will say ok then u write RESET , now u have ur imei back but ur s/n is still missing but u can follow this link to rewrite ur s/n
https://gadgetgurumelville.wordpress...illefernandes/
Old 12-12-2016, 08:31   #50 (permalink)
Member: 2659271
1. Run Balong tool.
4. Click on “Load”
That's where my problem is; the ports are not showing in Device Manager. Help Please......I already Installed Mobile Partner
Old 12-15-2016, 05:59   #51 (permalink)
Member: 1970813
Sonork: kofi
Thanks Meter: 14
installed all the drivers u have download and try again
Old 12-18-2016, 10:23   #52 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 448
@sech444
Sir Need E5573CS-322 usbloader Plz
Where To Mail To Get Usb Loaders?
In E5573CS-322 WORKING FILES Folder Available E5573cs-323_usbloader.bin
Error Is Here
Need Help Plz
Thanks Anticipation
Old 12-18-2016, 11:17   #53 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 448
Originally Posted by shoaibrao View Post
@sech444
Error Is Here
Need Help Plz
Thanks Anticipation
I Managed All But Dead On Last Process
After Writing
E5573cs_Update_21.318.03.00.00
Now Modem Is Dead
Old 12-18-2016, 19:36   #54 (permalink)
Member: 1970813
Sonork: kofi
Thanks Meter: 14
i managed all but dead on last process
after writing
e5573cs_update_21.318.03.00.00
now modem is dead
change the usbloader COS IT IS NOT FOR E5573cs-322 and try again
Old 12-18-2016, 19:42   #55 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 448
Sir Will You Point Me Exact Usbloader Plz?
Thanks Anticipation
Old 12-18-2016, 20:02   #56 (permalink)
Member: 1970813
Sonork: kofi
Thanks Meter: 14
e5573cs-322 usbloader only for e5573cs-322
Thanks Anticipation
this the link
https://drive.google.com/open?id=0B0...Xhpb1gzcVlaQ1U
The Following 3 Users Say Thank You to sech444 For This Useful Post:
Old 12-18-2016, 20:09   #57 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 448
Thanks A Lot Sir
Now At Home
Will Try Tomorrow
And Will Post Result Here
Best Wishes For You Sir
Old 12-18-2016, 21:10   #58 (permalink)
Member: 1970813
Sonork: kofi
Thanks Meter: 14
thanks a lot sir
now at home
will try tomorrow
and will post result here
best wishes for you sir
don`t forget the thank button
Old 12-19-2016, 07:54   #59 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 448
Still Same Sir
When Write
Modem Gets Dead
Old 12-19-2016, 15:54   #60 (permalink)
Member: 1970813
Sonork: kofi
Thanks Meter: 14
your ba3 must be 50%
Still Same Sir
When Write
Modem Gets Dead
the battery most be charge up to 50%
Page generated in 0.40577 seconds with 7 queries
