Huawei E5577s-321 no service after firmware update Hi How are you? I have Huawei E5577s-321 (Zain) unlocked Device information before unlock and firmware update Found modem : E5577s-321 Model : Huawei E5577 (untested) IMEI : Serial NR. : Firmware : 21.200.07.02.1367 Dashboard version : WEBUI_17.100.11.03.1367_MRE5 Web UI version : WEBUI_17.100.11.03.1367_MRE5 SIM Lock status : Locked (Card Lock) Wrong codes entered : 0 (unlock attempts left : 10) Device information after unlock and firmware update Found modem : E5577s-321 Model : Huawei E5577 (untested) IMEI : Serial NR. : Firmware : 21.316.01.00.00 Dashboard version : WEBUI_17.100.11.00.03-Mod1.3_MRE5 Web UI version : WEBUI_17.100.11.00.03-Mod1.3_MRE5 SIM Lock status : unlocked Wrong codes entered : 0 (unlock attempts left : 10) The device is now unlocked but the problem it's showing no service even if I insert a supported sim card I have found this firmware V200R001B200D07SP02C1367 with this webui V100R007B100D11SP03C1367 on the internet but i cannot find download link Please any body have firmware and webui for this device Sorry of my English Thank you in advance |
changing the firmware i believe cuse ur device to loose NVRAM data which has the IMEI stored So u need IMEI Repair .. |
How i can fix the nvram data |
Hi I have fixed the imei but the device still showing no service any help |
I have same problem E5336Bs-2 |
try with this webui verHuawei_E5577s-Update_WEBUI_17.100.13.01.03 hopefully problem will solve if no then contact me in pm |
you may try this webui "webui_17.100.12.02.1232". |
Hi, i have same problem after unlock with downnrate firmware nvram deleted i write imei and sn but on 3G no service work only 4G. How it is possible repair? |
which country modm and carrier |
Before unlock Software Version: 21.316.01.00.250 Web UI Version: 17.100.13.01.250 and operator locked is Telenor Bulgaria. After unlock is same firmware: Found modem : E5577Cs-321 Model : Huawei AuthVer 4 modem (New) IMEI : 8677xxxxxxxxx Serial NR. : 2XDxxxxxxxxxx Firmware : 21.316.01.00.00 Compile date / time : Dec 15 2015 15:01:07 Hardware ver. : CL1E5573SM11 Dashboard version : WEBUI_17.100.13.01.03_MRE5 Web UI version : WEBUI_17.100.13.01.03_MRE5 SIM Lock status : unlocked Wrong codes entered : 0 (unlock attempts left : 10) I test with sim card on two operators (telenor, A1) but problem is same on 3G no service connect on 2G and after 5 second return to 3G and no service. On 4g working good but operators don't have full 4g coverage. |
then update nv.bin to this router.then your problem will solve and 3g issue because your device mac address is killed you used non safe loader after mac address fixed your modem work as normal and all sims work take mac address from working device and write mac on same modem |
Ok i have another same router but what is needed to read write nv bin |
Yes tell us how to backup and restore nv data...... Quote:
Do you have save loader for e5577cs-321? |
