GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
02-08-2013, 15:13 | #151 (permalink) | |
Freak Poster Join Date: Mar 2002 Location: Moscow, Russia Age: 53
Member: 10397 Status: Offline Thanks Meter: 45 | Quote:
If not, post here the results of following commands execution: AT^VERSION? AT^SYSCFGEX=? AT^SYSCFGEX? AT+GSN AT+CIMI AT+COPS=? | |
02-08-2013, 15:58 | #152 (permalink) |
Major Poster Join Date: Jan 2013 Location: Belgium
Member: 1875869 Status: Offline Thanks Meter: 2 | Em820w flash downgrade completed ! @ vve @ fr3nsis I eventually was successfull with the flash downgrade ! See snapshot below. Thanks a million to vve for teaching me many tips on that matter. Thanks a million to fr3nsis for his outstanding job to make Huawei Flasher. It works like a charm ... once my hacked drivers were correctly setup ! There was a bug in my drivers hack. It's so complex with so many ports and drivers options to be setup for a unknown device. There is a difference in drivers assignment between the modem with pid 1404 and the same MBIM type with pid 1571. When in Download mode with pid 1568 devices instances have to be swapped compared to the standard modem with pid 1003 ! That did the trick ! No need to change ^SETMODE or any other option. again. Yves |
02-08-2013, 16:12 | #153 (permalink) | |
Member: 10397 Status: Offline Thanks Meter: 45 | Congratulations! Really good news. Quote:
I'm absolutely sure that your experience will be extremely helpful - a year later, when MBIM devices will flood the market. | |
02-08-2013, 18:04 | #154 (permalink) | |||||||
Member: 1875869 Status: Offline Thanks Meter: 2 | EM820W MBIM flash downgrade HOW TO @ vve , the trick is shown in red below in patch # 3. Huawei 3G modem drivers hack to use and flash an MBIM modem with an OS < Win8 This hack will allow a flash downgrade of your MBIM modem to the former standard mode. Modem : EM820W flashed with the MBIM Win8 update 11.810.10.02.00 Problem: The modem can no longer be used with any OS < Win8, Androпd, or even Linux with kernel < 3.85 (as of Feb 2013) Target : downgrade the modem to 11.810.09.24.00 standard mode. This hack will likely also work to downgrade the MU733 modem in Samsung computers.(change your vid/pid accordingly) The Samsung software update All-in-One package updates the firmware w/o asking the user to confirm that option ! It allows also to use the MBIM modem with Mobile Partner in a Win7 machine.(Huawei MP23 was happy with the hacked drivers) Driver set : 3G_Huawei(EM770W-EM820W) version 4.25.11.00 Tools : Revskills (credit B. Kerler) Flasher : Huawei Flasher 1.6 or > (credit fr3nsis) (I've used XP as I got some debugger errors under Win7 (.Net Framework), but it should work with Win7.) Requirements : ------------- Remove any other Huawei driver prior to start with the new drivers set.(Use DriverUninstall.exe) Remove Mobile Partner (installs it's own drivers set). Remove QPST that install a few drivers in confilt with the normal drivers. Optionnaly use USBDeview to check that the drivers have been removed and remove any remaining Huawei driver. Standard MODEM (NON MBIM) ------------------------------- You should know the vid-pid of your modem when in standard mode. EM820W: VID:12d1 PID:1404 You should know the vid-pid of your modem when in Download mode. EM820W: VID:12d1 PID:1003 MBIM MODEM -------------- You should know the vid-pid of your modem when in standard mode. EM820W: VID:12d1 PID:1571 You should know the vid-pid of your modem when in Download mode. EM820W: VID:12d1 PID:1568 Double click on the peripheral in Device Manager, select Details, Hardware ID to find the vid, pid and MI#. There are five files to hack in the drivers package. Quote:
If you have an X64 you should hack the X64 set AND take care of patching the correct X64 groups in the .inf files. That's easy. As my target was to flash-downgrade, I've not modified the ewdsc.inf for the Smartcard. The above listed inf files are including declarations for the standard mode with pid 1404/1003, EXCEPT ONE: ew_usbfilter.inf. Connect your modem via a USB port. The Windows Devices Manager will show only two devices: Quote:
There is of course a Yellow Warning in front of each device as there are no drivers available. The trick is to force the MBIM modem to enumerate all peripherals: That's the reason why we have to hack ew_busfilter.inf as follows: .INF files Patches: ------------------- 1- Add this in ew_busfilter.inf in the [Standard] section Quote:
This is the trick! The same modem (Standard) in download mode with pid 1003 uses interface MI_01 as PC UI Interface while the MBIM modem in download mode with pid 1568 uses the interface MI_00 for the PC UI Interface ! 4- Add this in ewusbwwan.inf in the [QCOM], [QCOM.NTia64], [QCOM.NTamd64] sections Quote:
This will install the drivers and you will see the process in the Devices Manager window. Click Continue when Windows complains about Unsigned Drivers. Once finished, run Revskills to verify that your Modem will switch between Normal and Download Mode. (thanks to vve and fr3nsis for that tip) Click Menu, Hardware Forensics, Port Utils, QC + AT-Cmd Check that Serial ComPort shows your modem PC UI Interface Click on Switch -> You should receive a "Done" answer. Got the BL tab In the second Drop box, Select DWNMODE:SwitchDwnMode Click on Send Command and look at your Device Manager Window The modem will switch to Download mode, loading new drivers In Devices Manager, check that you have a COM port assigned to PC UI Interface Go Back to the SETUP tab Select the new PC UI Interface with the new assigned COM Port number. Click on Switch -> You should receive a "Done" answer. Got the BL tab In the second Drop box, Select DWNMODE:ResetPhone Click on Send Command and look at your Devices Manager window. The modem will switch back to Normal mode, loading the normal drivers. As long as you cannot go back to Normal Mode with RevSkills, you cannot flash your modem. If it's OK, that means that you can use Huawei Flasher to successfully flash-downgrade your modem. Take care of leaving enough time for the drivers change before clicking OK to flash. Hope it will help many MBIM flashed modem owners Yves | |||||||
02-09-2013, 21:20 | #160 (permalink) | |
Junior Member Join Date: Feb 2013
Member: 1880663 Status: Offline Thanks Meter: 0 | Quote:
^VERSION:INTH:E398u-18CD3E398M Ver.A ^VERSION:EXTU:E398 ^VERSION:INTU:E398u-18 ^VERSION:CFG:104 ^VERSION:PRL: AT^SYSCFGEX=? ^SYSCFGEX"00","03","02","01","99"),((400380,"GSM 900/GSM1800/WCDMA2100"),(280000,"GSM850/GSM1900"),(3fffffff,"All Bands")),(0-2),(0-4),((c1,"LTE2100/LTE2600/LTE900"),(7fffffffffffffff,"All Bands")) AT^SYSCFGEX? ^SYSCFGEX:"0201",3FFFFFFF,1,2,7FFFFFFFFFFFFFFF 355258040591351 260019408379071 AT+COPS=? ERROR | |
02-09-2013, 21:40 | #161 (permalink) |
Member: 10397 Status: Offline Thanks Meter: 45 | kalbar555 Hmmm... Everything seems to be OK for now. Run some more commands: AT+GMR AT+CFUN? AT$QCSIMSTAT? AT^CARDLOCK? AT^SFM? AT^SETPORT? AT+CSQ |
02-09-2013, 21:44 | #162 (permalink) | |
11.433.57.00.000 at+cfun? +cfun: 4 at$qcsimstat? $qcsimstat: 0,sim init completed at^cardlock? ^cardlock: 2,10,0 at^sfm? ^sfm: 0 at^setport? Ff;1,2,3,7,a1,a2 at+csq +csq: 99,99 | |
NU2000a - All Nokia Flasher & Unlocker! | VictorGSM | Main Sales Section | 0 | 12-14-2000 19:58 |
6150 + NCDS3.0 + Win2000 + IBM600X + Xyrcom GSM modem (realport)? | bibi2k | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-21-2000 17:33 |
Universal SP Unlocker 4.0 - home page !!! | bp.bonus | GSM Mobile Links | 0 | 01-22-2000 22:31 |
