Unlock Server
Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM / HSDPA Modems and Routers
GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares
Old 02-29-2012, 16:13   #1 (permalink)
Registered User
Member: 76882
idea Huawei E1732 help.
hello.
idea huawei E1732 net setter unlock with dc unlocker.
but please know me how to use other sim. bu i am new for netsetters unlock.
Regards
Old 02-29-2012, 18:48   #2 (permalink)
Member: 771937
Sonork: 100.1605717
Originally Posted by kiran View Post
hello.
Idea huawei e1732 net setter unlock with dc unlocker.
But please know me how to use other sim. Bu i am new for netsetters unlock.
Regards
serch u r e1732 many time's post & 100% solution bro.
Old 02-29-2012, 19:38   #3 (permalink)
rahul_rocks3's Avatar
Member: 1312746
Sonork: 100.1604777
hello.
Regards
brother if you dont have dc unlocker you can unlock it with the process given below but if you have dc unlocker and are not able to unlock it or want to learn modem unlocking.....contact me on yahoo will surely help you out
Use CDMA WORKS Shope ( Crack working )
Connect Modem Port
Send SPC 000000
Backup NV 0 TO 9999 ( Dec )
Save file IMEI.
Download this http://www.4shared.com/file/52ZyC0U4...owngradeR.html
it will give error in last
Ignore it
Reconnect modem
Restore NV BY CDMA WORKSHOP
Open dc And check Info logs
The Following User Says Thank You to rahul_rocks3 For This Useful Post:
Old 03-01-2012, 13:45   #4 (permalink)
Registered User
Member: 76882
hello,
after unlock E1732 with dc-unlocker . unable to create new profiles . and also updated custom dash board "UTPS21.005.11.00.356_MAC21.005.11.00.356_LNX21.00 5.11.01.356.exe" still not changed dash board. please help how creat new profiles ?
Old 03-02-2012, 05:00   #5 (permalink)
senpulinat's Avatar
Member: 300529
E1732_all_op.exe - 4shared.com - online file sharing and storage - download
update with this
The Following User Says Thank You to senpulinat For This Useful Post:
Old 03-02-2012, 05:35   #6 (permalink)
Member: 1312746
Sonork: 100.1604777
hello,
this is dashboard issue....simply download dashboard from the below provided link and update ur modem.....it will be resolved
1732 Dashboard
Old 03-02-2012, 08:43   #7 (permalink)
Registered User
Member: 76882
hi rahul,
after update dash board . dash board install mobile partner all op . no cd install . but huawei drivers are asking. do u have e1732 drivers please help.
Old 03-02-2012, 15:55   #8 (permalink)
ezysuresh's Avatar
Member: 216081
Sonork: 100.1614205
e1732 and e1550 unlocked
Thanks to rahul_rocks3 for giving good solutions, here are screen shots
The Following User Says Thank You to ezysuresh For This Useful Post:
Old 03-02-2012, 15:56   #9 (permalink)
Member: 1312746
Sonork: 100.1604777
hi rahul,
remove all other dashboard and insert modem again to back port of ur pc and it will surely ask you install the mobile partner dashboard and if doesn't then manually click on setup from modem drive and install it.....
this dashboard is tested many times.....few minutes back also I tested it for a user
Old 03-02-2012, 15:57   #10 (permalink)
Member: 1312746
Sonork: 100.1604777
hi rahul,
just check this post its working perfect
http://forum.gsmhosting.com/vbb/f25/...1/#post8198306
Old 03-02-2012, 16:01   #11 (permalink)
ezysuresh's Avatar
Member: 216081
Sonork: 100.1614205
just cancel the first huewei mobile install tab which it cannot find driver file, then continue next installation steps, then when you install all remove modem and insert again then install will continue, just tested with the same.
Old 03-02-2012, 16:03   #12 (permalink)
Member: 1312746
Sonork: 100.1604777
hi rahul,
but if you only need the drivers then you can select the drivers manually for all ports from C:\Program Files\Mobile Partner\Driver
Old 03-03-2012, 05:39   #13 (permalink)
Registered User
Member: 76882
Hello Rahul,
Thank you for your kind replays and support software.
Actually I did one mistake before this update . I upgrade firmware when upgrade every thing ok but upgrade failed. After unknown IMEI & S/N.
please can help how to recover IMEI ?
regards
Old 03-03-2012, 05:49   #14 (permalink)
Member: 127269
Sonork: 100.1605945
Only solution to repair data card imei is Modem Unlock Key known as Mkey.
Old 03-03-2012, 05:58   #15 (permalink)
Registered User
Member: 76882
sorry i don,t have mkey only dcunlocker. other then mkey any solution.
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 16 02-01-2012 05:18
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-25-2011 23:56
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 11-29-2010 18:04
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
Winlock 1.10 - Help rdmfs Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 06-25-1999 08:21
Page generated in 0.73303 seconds with 12 queries
