GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
11-13-2018, 12:22 | #1 (permalink) |
Freak Poster Join Date: Oct 2018 Location: GSMHOSTING
Member: 2869280 Status: Offline Thanks Meter: 112 | Telenor e8372h-608 21.327.62.00.1460 unlcok+imei fixed also detect modem in dc and give at^godload commnd then run fiel https://drive.google.com/file/d/1zeL...ew?usp=sharing |
The Following 5 Users Say Thank You to samsamsolutions For This Useful Post: |
11-17-2018, 06:22 | #3 (permalink) |
Member: 2869280 Status: Offline Thanks Meter: 112 | Zong e8372h-153 21.327.62.00.1456 unlcok+imei fix+keygan hi dear how ar eyou i will share free zong e8372h-153 21.327.62.00.1456 unlcok+imei change+ keygan enjoy it say thanks https://drive.google.com/file/d/1MbD...2-I4-P_B-/view |
11-17-2018, 10:17 | #4 (permalink) | |
No Life Poster Join Date: May 2014 Location: Peshwar, Pakistan
Member: 2192793 Status: Offline Thanks Meter: 188 | Quote:
Can you plz share E5330bs-2 universal unlock file for all versions Thanks in advance | |
11-29-2018, 21:40 | #8 (permalink) |
Crazy Poster Join Date: Mar 2016 Location: Pakistan Peshawar
Member: 2545777 Status: Offline Thanks Meter: 8 | E5330BS-2 telenor unlocked file can flash to zong E5330BS-2 And no need to repair imei after unlock work all sims because of old modems but mobilink E5330Bs-2 unlock file can work only on mobilink |
01-13-2019, 10:24 | #9 (permalink) |
Junior Member Join Date: Feb 2018 Location: vehari
Member: 2814839 Status: Offline Thanks Meter: 0 | [QUOTE=samsamsolutions;13414007]hi dearr enjoy telenor e8372h 21.327.62.00.1460 without open unlcok and imei fixd detect modem in dc and give at^godload commnd then run fiel Found modem : E8372 Model : Huawei E8372h IMEI : 866457028009459 Serial NR. : B7Z7S18103001851 Firmware : 21.327.62.00.1460 Dashboard version : WEBUI_17.100.45.00.1456_RE5 Web UI version : WEBUI_17.100.45.00.1456_RE5 SIM Lock status : unlocked Wrong codes entered : 0 (unlock attempts left : 10) For unlock, may require firmware change, check tutorial or contact support ================================================== ================= at^godload COMMAND NOT SUPPORT |
01-23-2019, 06:18 | #10 (permalink) |
Junior Member Join Date: Sep 2007
Member: 584899 Status: Offline Thanks Meter: 0 | Found modem : E8372 Model : Huawei E8372h IMEI : 866457028009459 Serial NR. : B7Z7S18103001851 Firmware : 21.327.62.00.1460 Dashboard version : WEBUI_17.100.45.00.1456_RE5 Web UI version : WEBUI_17.100.45.00.1456_RE5 SIM Lock status : unlocked Wrong codes entered : 0 (unlock attempts left : 10) For unlock, may require firmware change, check tutorial or contact support ================================================== ================= at^godload COMMAND NOT SUPPORT |
07-07-2019, 10:02 | #12 (permalink) |
Junior Member Join Date: Mar 2018 Location: Pakistan
Member: 2819942 Status: Offline Thanks Meter: 3 | Model : Huawei E8372h IMEI : 410510100582321 Serial NR. : B7Z7S18C07002785 Firmware : 21.327.62.00.1460 Dashboard version : WEBUI_17.100.45.00.1456_RE5 Web UI version : WEBUI_17.100.45.00.1456_RE5 SIM Lock status : Locked (Card Lock) Wrong codes entered : 0 (unlock attempts left : 10) For unlock, may require firmware change, check tutorial or contact support ================================================== ================= AT^godload COMMAND NOT SUPPORT HELP ME |
