GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
11-27-2008, 19:35 | #1 (permalink) |
Insane Poster Join Date: Feb 2006 Location: NY,USA
Member: 231315 Status: Offline Sonork: none Thanks Meter: 68 | Unlock Huawei E220 at home Fallow the link and you will have a word document with pictures and instructions and links for the software neded on how to unlock Huawei E220.I am posting the link because i wanted to upload the file here but the forum sistem didn't allowed it. http://rapidshare.com/files/167984549/unlock_E220.doc If it helped you please give a thanks. |
The Following 13 Users Say Thank You to fantomel For This Useful Post: |
11-28-2008, 02:55 | #2 (permalink) |
Freak Poster Join Date: Mar 2003 Location: CT,SA
Member: 25213 Status: Offline Thanks Meter: 12 | Much easier way to unlock. Download and flash modem with this http://www.huawei.com/mobileweb/en/f...=20497&ctype=1 . You get Huawei dashboard. All you have to do is configure APN (on some networks). tested on Vodaphone E220. Works 100%. For South Africa MTN requires no configuration. Vodacomm APN must be set to STATIC and "internet" in lower case. Have not had achance to check settings for Cell C or Virgin yet. Will do so later later version of software http://www.huawei.com/mobileweb/en/f...=20517&ctype=1 I used the 1st one. The above is for XP and Vista, but I believe that you might have to do one or other tweaks to get modem to work on Vista For Mac Users http://www.huawei.com/mobileweb/en/f...=19957&ctype=1 latest Mac http://www.huawei.com/mobileweb/en/f...=20499&ctype=1 Last edited by shaggydogza; 11-28-2008 at 03:00. |
The Following 6 Users Say Thank You to shaggydogza For This Useful Post: |
11-28-2008, 03:16 | #3 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Philippines
Member: 218941 Status: Offline Thanks Meter: 1,801 | i want to downgrade my Huawei e220 ,is it donwgradable with the old firmware ? succesfully upgrade but not supported here in my country .... any one have? |
11-28-2008, 11:57 | #4 (permalink) |
Member: 231315 Status: Offline Sonork: none Thanks Meter: 68 | shaggydogza your solution is only to upgrade the data data card, like this you get rid of your provider software but does not unlock it to be used with other sim's from other providers. the dashboard and client software gives you access to mobilepartner software,drivers support for vista and upgrades the modem's speed to 7.2Mbits. |
The Following User Says Thank You to fantomel For This Useful Post: |
11-28-2008, 11:59 | #5 (permalink) |
Member: 231315 Status: Offline Sonork: none Thanks Meter: 68 | Mang mel to my modem i have managed to upgrade and downgrade it's firmware without any problems. |
11-28-2008, 12:08 | #6 (permalink) |
Member: 231315 Status: Offline Sonork: none Thanks Meter: 68 | i will post today all the firmware's that i have , here are two of them http://rapidshare.com/files/16818616...0.100.B268.exe http://rapidshare.com/files/16818776...0.100.B268.exe Last edited by fantomel; 11-28-2008 at 12:16. |
11-28-2008, 12:50 | #7 (permalink) | |
Member: 25213 Status: Offline Thanks Meter: 12 | Quote:
The Following User Says Thank You to shaggydogza For This Useful Post: |
11-28-2008, 13:21 | #8 (permalink) |
Member: 25213 Status: Offline Thanks Meter: 12 | [QUOTE=shaggydogza;3899394]Much easier way to unlock. Download and flash modem with this http://www.huawei.com/mobileweb/en/f...=20497&ctype=1 . You get Huawei dashboard. All you have to do is configure APN (on some networks). tested on Vodaphone E220. Works 100%. For South Africa MTN requires no configuration. Vodacomm APN must be set to STATIC and "internet" in lower case. Have not had achance to check settings for Cell C or Virgin yet. Will do so later QUOTE] Tested Cell "C" and Virgin...both work as well, same APN settings as MTN, just virgin is slow |
11-28-2008, 13:22 | #9 (permalink) |
Member: 25213 Status: Offline Thanks Meter: 12 | [QUOTE=shaggydogza;3899394]Much easier way to unlock. Download and flash modem with this http://www.huawei.com/mobileweb/en/f...=20497&ctype=1 . You get Huawei dashboard. All you have to do is configure APN (on some networks). tested on Vodaphone E220. Works 100%. For South Africa MTN requires no configuration. Vodacomm APN must be set to STATIC and "internet" in lower case. Have not had a chance to check settings for Cell C or Virgin yet. Will do so later QUOTE] Tested Cell "C" and Virgin...both work as well, same APN settings as MTN, just virgin is slow |
11-28-2008, 18:36 | #11 (permalink) |
Member: 231315 Status: Offline Sonork: none Thanks Meter: 68 | dear sir, i don't know how to unlock your card , all i can give u is a link from where you can have access to all software upgrades from huawei for datacards http://www.huawei.com/mobileweb/en/d...ype=-1&id=5286 shaggydogza as you are telling i have tried to my friend's card that it was locked to Vodafone RO and your solution it's not working. Maybe in your country worked but for my case here in Romania it's not working. Regards. |
12-01-2008, 14:38 | #14 (permalink) |
Member: 231315 Status: Offline Sonork: none Thanks Meter: 68 | Mang mel the lowest version of firmware that i could find is this one 11.110.05.00.00 Here is the link for it: http://www.vodacom4me.co.za/vodacom4...M%20Vista).zip |
The Following 3 Users Say Thank You to fantomel For This Useful Post: |
12-04-2008, 02:38 | #15 (permalink) | |
Member: 218941 Status: Offline Thanks Meter: 1,801 | Quote:
WOW!! its really work...... i been searching for a long time for this FIRMWARE,now my Huawei back to normal 3.6mbs again thanks bro...you realy help to downgrade my modem.. solved my problem now...good job! Now sorry for this.. http://forum.gsmhosting.com/vbb/showthread.php?t=607240 | |
The Following User Says Thank You to Mang mel For This Useful Post: |
Unlocking Huawei E220 for dummies (me) | candeloro | KULANKENDI Server | 45 | 09-29-2008 14:20 |
Successfully Unlock Huawei E220 HSDPA USB Modem !!! | CNW | KULANKENDI Server | 10 | 05-16-2008 08:08 |
Successfully Unlock Huawei E220 with latest firmware | t6e6 | KULANKENDI Server | 0 | 01-22-2008 18:15 |
