Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM / HSDPA Modems and Routers
GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares
Old 01-07-2014, 09:24   #1 (permalink)
tartcell18's Avatar
Member: 1595088
Thanks Meter: 184
Unlock Huawei E5172 STC Saudi Arabia WiFi Router Gateway
hi i got here Unlock Huawei E5172 STC Saudi Arabia WiFi Router Gateway
i want to change wifi pass but i dont know what is the admi password in confi thank you
Huawei E5172 4G 150Mbps LTE Cat4 CPE Review - Upload and stream using StreamUpload.com
Old 01-10-2014, 05:29   #2 (permalink)
Member: 2001252
Sonork: 100.1645439
Thanks Meter: 4
Hello,
The Huawei E5172 default admin password is admin. You can also check to the back label of HUAWEI E5172 for reference.
you can refer to the image on this page:
http://www.4gltemall.com/huawei-e517...-cat4-cpe.html
Old 04-02-2014, 11:39   #3 (permalink)
Member: 2159723
Hi..can you pls tell me how to unlock or give me a link to unlock
Old 06-23-2014, 07:01   #4 (permalink)
Member: 2209684
hi friends, how to unlock my Saudi Arabia STC router 5172s-920
Old 07-28-2014, 02:33   #5 (permalink)
Member: 1905773
by imie you can unlocked it
Old 01-09-2015, 16:24   #6 (permalink)
Member: 2100322
hi there everyone,, may i ask what is the best software you use for unlocking the stc 4g e5172
thank you in advance and keep us safe..
Old 03-20-2015, 07:28   #7 (permalink)
Member: 200382
Thanks Meter: 4
you can unlock the router by changing the firmware
Old 03-20-2015, 14:47   #8 (permalink)
Member: 200382
Thanks Meter: 4
unlock Huawei E5172S 927 STC router
Important! It is better to use a LAN cable to connect to the router not wi-fi
1. Download the firmware named: E5172S-920_Anti_STC_927_Update from the link below. The firmware unlocks the router by downgrading it’s firmware to the firmware for E5172s 920. E5172S-920_Anti_STC_927_Update
2. Access router manager by entering 192.168.1.1 (also written on the bottom of the router) into your web browser.
3. Enter the user name and password for the router ( default user: admin password: admin)
4. From the HOME page go to UPDATE.
5. Click on browse to navigate to the place where you downloaded the E5172S-920_Anti_STC_927_Update file too and click on open to select it.
6. Press update and wait for it to finish. When it has finished click on login to once again login to the router manager.
7. Download the update firmware from the following link or any other firmware you want. Different firmware give access to different features available on the router that STC block, such as, external antenna, voice calls, different frequencies etc. The linked firmware unlocks most of the stuff. https://mega.co.nz/#!sQxFWR4I!nwuYOO...VODek_y2vM0Fdc
8. Search the folder until you locate file named: MPWUDPUPDATE_V200R001C115SP100.BIN
9. Once again, login to the router manger and update the firmware following the previous steps (4 – 6).
10. When it has completed updating, login again. That’s it! Your router is now unlocked
11. If you want to update the firmware you have to first update with the file named: E5172s-927_AntiOM100.BIN then update with your desired firmware.
Credit for the links to the files goes out to HAMD.G https://www.youtube.com/watch?v=Gi0XsQAld74
The Following 4 Users Say Thank You to jamalx For This Useful Post:
Old 03-25-2015, 12:08   #9 (permalink)
Member: 585878
Thanks Meter: 2
Does anybody try this unlocking guide?
The Following User Says Thank You to 00ttang For This Useful Post:
Old 04-06-2015, 09:25   #10 (permalink)
Member: 1528407
Thanks Meter: 8
file verfication failed.
update failed
The Following User Says Thank You to monish111 For This Useful Post:
Old 05-05-2015, 17:04   #11 (permalink)
shakeelajmal's Avatar
Member: 51639
Thanks Meter: 76
File varification failed on every router i tried so i think the method described above is either for some other router or fake
The Following User Says Thank You to shakeelajmal For This Useful Post:
Old 05-05-2015, 17:52   #12 (permalink)
Member: 2389518
Thanks Meter: 2
reset router & plug wire
The Following User Says Thank You to ahmad4group For This Useful Post:
Old 10-21-2015, 22:28   #13 (permalink)
Member: 327867
Thanks Meter: 12
Becouse you don't have original firmware on it. i test it and it is work this metod.The problem is i can't change APN settings.
The Following User Says Thank You to djeddy For This Useful Post:
Old 11-15-2015, 22:26   #14 (permalink)
Member: 1977512
mine is YooMee cote d'ivoire and the meme error message appears
The Following User Says Thank You to desahouin For This Useful Post:
Old 12-11-2015, 05:12   #15 (permalink)
Member: 2078759
Thanks Meter: 2
Try to use some unlock software or buy the unlock service.
Page generated in 0.22982 seconds with 9 queries
