GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
01-03-2016, 17:06 | #16 (permalink) |
Junior Member Join Date: Jan 2016
Member: 2510153 Status: Offline Thanks Meter: 0 | Because the telecommunications company in my country has a 1800 and 2300 frequency for 4g but the frequency 1800 is banned in routers and works only in mobile phones and to lift the ban on frequency 1800 routers must change IMEI So is there a way to change it ? |
01-30-2016, 03:41 | #17 (permalink) |
Product Manager Join Date: May 2008 Location: Ukraine Age: 45
Member: 772096 Status: Offline Sonork: 100.69222 Thanks Meter: 8,277 | Yes IMEI Repair is possible in Mkey Mkey - Modem Unlock Key - GSM-Forum |
08-03-2016, 22:33 | #18 (permalink) |
Junior Member Join Date: Aug 2006
Member: 340718 Status: Offline Thanks Meter: 2 | help please huawei e5172bs [QUOTE=jamalx;10937277]unlock Huawei E5172S 927 STC router Important! It is better to use a LAN cable to connect to the router not wi-fi 1. Download the firmware named: E5172S-920_Anti_STC_927_Update from the link below. The firmware unlocks the router by downgrading it’s firmware to the firmware for E5172s 920. E5172S-920_Anti_STC_927_Update 2. Access router manager by entering 192.168.1.1 (also written on the bottom of the router) into your web browser. 3. Enter the user name and password for the router ( default user: admin password: admin) 4. From the HOME page go to UPDATE. 5. Click on browse to navigate to the place where you downloaded the E5172S-920_Anti_STC_927_Update file too and click on open to select it. 6. Press update and wait for it to finish. When it has finished click on login to once again login to the router manager. 7. Download the update firmware from the following link or any other firmware you want. Different firmware give access to different features available on the router that STC block, such as, external antenna, voice calls, different frequencies etc. The linked firmware unlocks most of the stuff. https://mega.co.nz/#!sQxFWR4I!nwuYOO...VODek_y2vM0Fdc 8. Search the folder until you locate file named: MPWUDPUPDATE_V200R001C115SP100.BIN 9. Once again, login to the router manger and update the firmware following the previous steps (4 – 6). 10. When it has completed updating, login again. That’s it! Your router is now unlocked 11. If you want to update the firmware you have to first update with the file named: E5172s-927_AntiOM100.BIN then update with your desired firmware. Credit for the links to the files goes out to HAMD.G https://www.youtube.com/watch?v=Gi0XsQAld74[/QUOTE Help me with Huawei E5172Bs-925 firmwares please. The one i have on my device is proprietary and i can't change APN or network mode. |
