Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM / HSDPA Modems and Routers
GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares
Old 11-25-2018, 09:32   #1 (permalink)
Member: 2057408
Unlocking Huawei E5573Cs-609 21.329.63.00.284
I recently bought the Airtel 4G Hotspot which is Huawei E5573cs-609 with firmware version 21.329.63.00.284.
I've tried lots of online instructions but I am stuck at the Balong USB Loader showing this output.
Пытаемся открыть устройство \\.\COM6 ...
Загрузка блока 0, адрес=10000000, размер=3936
Всего пакетов в блоке [0]: 4
Модем отверг пакет конца данных. Образ пакета:
0000: ED 05 FA 53 C0 *н.ъSА
I even tried AT^GODLOAD and flashing via a file provided by another user, but it just bricked my device. Now am stuck at the 3G PC UI Interface loader.
Is there anyone managed to unlock this device? Also someone told me that because of the new firmware version, the previous Balong usb loader bin files aren't supported, that's why it shows the above message.
Can someone provide the latest USB loader for the device for that firmware version?
Can someone tell if it's possible to switch to download mode from the 3G PC UI Interface mode? At least I could flash the original firmware if it's possible.
Old 11-25-2018, 10:33   #2 (permalink)
TestBox2's Avatar
Member: 772096
Sonork: 100.69222
Thanks Meter: 8,277
If ypu have Mkey dongle then you can unlock ur modem via writing patced fw: E5573CS_21.329.63.00.284_FW
Old 11-25-2018, 10:41   #3 (permalink)
Member: 2057408
Hi TestBox2,
Thanks very much for the reply.
Unfortunately I don't have a Mkey dongle. Is there any other way to get things done? I am looking for the USB loader binf ile to be used in Bolang please provide if you've one.
Or if you've any solution to switch from 3G PC UI Interface mode to Download mode also would be appreciated.
Page generated in 0.11299 seconds with 8 queries
