Unlock Server
Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM / HSDPA Modems and Routers
GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares
Old 07-16-2012, 01:12   #1 (permalink)
Member: 1456229
Vodafone Egypt Huawei HiLink E303
Well that a new modem vodafone has launched lately here in Egypt
the thing is totally different from other modem we used to know thats has com ports and a mobile partner dashboard
the modem works as soon as you plug it in your PC/Mac/linux
with this there plug-in-connect from huawei
the new modem installs a virtual network card based on Microsoft NDIS api library
that NDIS comes configured already with ip address that leads you to its dashboard
when ever i try to unlock it with dc-unlocker with different sim inserted the the dc-unlocker walk in the process and it's unlocked but whenever i get to the dashboard (from 192.168.1.1) it redirects me to a page asks for the unlock code but the box to insert the unlock code is greyed not active
the thing is i'm trying to discuss here is not me or how to unlock that little beast yeah it have good signal boost inside of it ..we/i wanna know
1-how to change its dashboard
2-is it possible to create an application that will insert a modded firmware to it
3-how to unlock it
4-that's huawei new future with these type of modems .. how we will deal with that
that gives us possibility to get com ports working
Edits :
here it is the detection info with dc-unlocker when vodafone SIM inserted
Detecting card :
selection :
manufacturer - Huawei modems
model - Huawei E303 HiLink
Interface           : 192.168.1.1
Found modem         : E303
Model               : Huawei E303 HiLink
IMEI                : 861737003993024
Serial NR.          : E9PBYA9250820195
Firmware            : 22.157.78.00.37
Hardware ver.       : CH2E303SM
Web UI version      : 11.010.06.00.37
SIM Lock status     : unlocked
Wrong codes entered : 0 (unlock attempts left : 10)
Old 07-16-2012, 04:53   #2 (permalink)
Member: 1456229
why no one replies to my thread ? !
Old 07-16-2012, 07:03   #3 (permalink)
NiRaV.SoN!'s Avatar
Member: 1753913
Arrow
Bro i have this modem also trying to Unlock.
If we get original firmware for E303HiLink VDF Egypt then i can do something for unlock..
Modem will show only NDIS adapter in normal mode.
If you want to show modem port Application + PC UI.
Then add this URL in Address-bar and Press Enter.
Modem will restart with port enabled.
HiLink DL Mode
http://192.168.1.1/html/switchProjectMode.html
Extracted from E353 Firmware by NiRaV ;)
You can change WebUI to UK H3G I have this updater + E353 HiLink updater.
E353 HiLink firmware is not completable with E303 HiLink due to hardware change.
Best Regards,
Nirav Soni.
India.
Old 07-16-2012, 07:08   #4 (permalink)
NiRaV.SoN!'s Avatar
Member: 1753913
Arrow
Firmware Version 22.157.78.00.37 have blocked unlock counter.
I tried modem accept unlock code but not unlock because of blocked counter.
If we change firmware OR patch firmware then its possible to unlock.
Old 07-16-2012, 13:16   #5 (permalink)
Member: 1456229
well thanks for the awesome reply and the link you provided cause i was upset that will be no modem port to deal with AT-Commands but there is no drivers available plus every time i plug the modem i have to send the link .. can you please provide me with the extracted firmware i'm also heard on some flippino forums that there is a method to insert some customized firmware ..but i'm missing the drivers of the new mode of the modem cause i tried the driver that stores in the ProgramData folder on C and it doesn't recognize it .. so the firmware i think is could be available .. but i'm trying to use the dashboard the normal one (Mobile partner) not the web version ..!
Old 07-16-2012, 13:18   #6 (permalink)
Member: 1456229
ah BTW i don't care to unlock the modem i have another one to use for other providers rather than Vodafone ... but as i i told ya i wanna use the modem ports and the normal dashboard not the web version
Old 07-16-2012, 15:04   #7 (permalink)
Member: 1456229
up up someone reply please !
Old 07-16-2012, 16:22   #8 (permalink)
NiRaV.SoN!'s Avatar
Member: 1753913
Arrow
No any Mobile Partner OR other dashboard will work with HiLink Modems
Only WebUI for Setting/Connect and other utility.
Use Huawei Latest Drivers Version 4.23.13.00
Can you provide the link of flippino forums so i can contact them.
BR,
Nirav Soni,
India.
Old 07-16-2012, 16:52   #9 (permalink)
Member: 1456229
please check the Pm and i've also added you on skype and yahoo mail can we contact and interact about this together ?
Old 07-16-2012, 16:58   #10 (permalink)
NiRaV.SoN!'s Avatar
Member: 1753913
Arrow
Added On Skype+Yahoo
The link you are provided is of E353u Normal not HiLink
btw I will contact my friend from Philippines if he have some firmware or HiLink Unlock knowledge
Old 07-16-2012, 17:06   #11 (permalink)
Member: 1456229
and also to be noted the driver didn't work manully and using the program inside of the package !
Old 07-16-2012, 17:11   #12 (permalink)
Member: 1456229
yeah the main thread but there is a post there about unlocking the e303 ! i'll pm it to you now
Old 07-16-2012, 17:11   #13 (permalink)
NiRaV.SoN!'s Avatar
Member: 1753913
Arrow
In this post Line 4 i given latest driver link
Old 07-16-2012, 17:57   #14 (permalink)
Member: 1456229
it doesn't work too the hilink device is not recognized after the switching
Old 07-17-2012, 04:33   #15 (permalink)
Member: 1456229
up up .. after the switching still the two of Huawei devices denies any drivers even the ones that comes built in the modem !
Vodafone? gurmk Various 9 01-04-2011 23:08
Vodafone MN-1 Frubin Various 0 01-18-2002 11:20
A35 Vodafone ver.13F/E/H bre786 x1x to x45/x50 3 11-14-2001 17:52
Vodafone ??? Unlocker AL Various 3 03-30-2001 23:20
MC920 from Vodafone asks PayT code:Please Help GreEn Infineon C16X M51 & ARM7 M52 BASED 0 09-18-2000 04:20
Page generated in 0.65848 seconds with 12 queries
