GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
10-25-2012, 06:54 | #286 (permalink) | |
Insane Poster Join Date: Nov 2008
Member: 896545 Status: Offline Sonork: ? Thanks Meter: 42 | Quote:
posted in same thread but you miss to see it it will work only wen you hv installed all drivers and modem will detected in firmware download from below click here regards khan | |
The Following User Says Thank You to sskhan17077 For This Useful Post: |
10-25-2012, 15:26 | #287 (permalink) | |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | Quote:
I did that as you mentioned above. but problem when i click on UPDATE the error is coming. The model in not correct, not allow to use this tool! now what i must do? thnx for your help. Br. | |
10-29-2012, 07:04 | #288 (permalink) |
Junior Member Join Date: Aug 2012
Member: 1801611 Status: Offline Thanks Meter: 0 | I tried to unlock my vodafone K3770z modem by your method but it got failed at 98% , so i tried to reflash it but each & every time it is getting failed at 98% and now the modem drive is also not showed in my computer when i plug it. so i had to install mf192 manually so that port can be automatically detected but problem remains same ie. reflashing fails at 98%. please provide a solution to this. my emailid is — [email protected] |
11-08-2012, 15:28 | #290 (permalink) | |
Junior Member Join Date: Oct 2012
Member: 1832685 Status: Offline Thanks Meter: 0 | Quote:
12-10-2012, 19:47 | #292 (permalink) |
Junior Member Join Date: Feb 2011
Member: 1508405 Status: Offline Sonork: [email protected] Thanks Meter: 1 | sir ,my data card k-3770z unlock karte hue dead ho gaya , plz help me |
12-17-2012, 19:05 | #294 (permalink) |
Junior Member Join Date: Dec 2012
Member: 1854396 Status: Offline Thanks Meter: 0 | hi henever I click on arrow button... process is cmpleting 98%,, after that FAIL..!! the process. What should I do..??? Read more: How to Unlock Vodafone K3770 z (ZTE modem) Net Setter ? pls help me |
12-17-2012, 19:05 | #295 (permalink) |
Member: 1854396 Status: Offline Thanks Meter: 0 | henever I click on arrow button... process is cmpleting 98%,, after that FAIL..!! the process. What should I do..??? Read more: How to Unlock Vodafone K3770 z (ZTE modem) Net Setter ? |
12-20-2012, 11:52 | #296 (permalink) |
Junior Member Join Date: Dec 2012 Location: delhi
Member: 1855731 Status: Offline Sonork: 100.1624928 Thanks Meter: 0 | sir i unlocked vodafone k3770z modem by your software but aircel and airtel net card is working.... i tried many chances but it does not work .... tell me how to over come with it . otherwise tell me how to revert back to its original vodafone mobile broadband dashboard ? |
12-24-2012, 06:54 | #297 (permalink) | |
Member: 1857534 Status: Offline Thanks Meter: 0 | Quote:
12-24-2012, 12:08 | #298 (permalink) |
Member: 1855731 Status: Offline Sonork: 100.1624928 Thanks Meter: 0 | Those who feel problem with China Dashboard can happily migrate back to Original Vodafone dashboard attached here ZTE k3770z Original Vodafone Dashboard.rar - 4shared.com - online file sharing and storage - download - Avi Sing but sir tell me how to use this original vodafone dashboard i download it and extract but after that i am not getting what to do ? |
12-24-2012, 20:52 | #300 (permalink) |
Product Supporter Join Date: May 2004 Location: INDIA Age: 55
Member: 65063 Status: Offline Thanks Meter: 2,419 | None of the modems are killed by above solution People never read postings and instructions carefully majority of them even dont know how to remove conflicting drivers read post who had replied clearly ..how other sim are working perfect with this solution are these peoples ...fools one can easily find the truth br, |
Nokia 3210 + datacable, use as a modem? | Lilacrazor | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 05-04-2001 18:03 |
using 7110 modem and laptop | ace2k1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 04-21-2001 05:33 |
using 7110 modem and laptop | ace2k1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 04-19-2001 18:36 |
nokia 6150 internal modem | mottile | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-21-2001 00:14 |
6150 + NCDS3.0 + Win2000 + IBM600X + Xyrcom GSM modem (realport)? | bibi2k | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-21-2000 17:33 |
