GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
12-25-2012, 08:53 | #301 (permalink) | |
Junior Member Join Date: Oct 2011 Location: Deeds Land
Member: 1674164 Status: Offline Thanks Meter: 1 | AirTel Quote:
I confirmed that the Vodafone K3770-Z Device using Unicom Dashboard (MF186) is working very well with BSNL, VODAFONE and TATA DOCOMO except AIRTEL. Any help towards connecting AIRTEL shall be highly appreciated. | |
The Following User Says Thank You to Khandelia For This Useful Post: |
01-03-2013, 09:37 | #303 (permalink) |
Junior Member Join Date: Jan 2013
Member: 1862270 Status: Offline Sonork: kumar Thanks Meter: 0 | hai thanks for the post... My device worked well after flashing.... Then I tried to revert back to original vodafone firmware. Then the error starts... stopped at 98% writing record success.... FAIL! In other computers not even detecting... solved by installing drivers... Now only windows dialup only works... None of the dashboard detecting the device... and not showing the drive when connecting... What to do??? PLS HELP |
01-04-2013, 07:37 | #304 (permalink) | |
Freak Poster Join Date: Dec 2007 Location: India, Haldwani Age: 38
Member: 650289 Status: Offline Thanks Meter: 56 | 98 % error solution for zte k3770-z (vodafone) Quote:
- first install vodafone dashboard (original) - second install a k singh dashboard / nirov soni dasboad (for drivers) - reboot system / pc - plug your modem - just write (unlock) your modam with a.k.singh / nirav soni tool (ORIGINAL DASBOARD) - 100 % sucess without any error - tested | |
01-08-2013, 12:18 | #307 (permalink) | |
Member: 1862270 Status: Offline Sonork: kumar Thanks Meter: 0 | 98% error Quote:
even reinstalled windows.. Dashboard detecting modem and connecting... windows dailup also detecting the modem and connection OK. ONLY Problem is... NO firmwares in the netsetter... i.e., not mounting... i have to install all the drivers separately. how to reflash with the dashboard installer and drivers...? Please help | |
01-10-2013, 15:07 | #309 (permalink) |
Product Supporter Join Date: May 2004 Location: INDIA Age: 55
Member: 65063 Status: Offline Thanks Meter: 2,419 | k3770z Whats The fault ??? Repeat Post With All possible links and drivers ¦Method 1 http://www.4shared.com/rar/Ji3NesJa/K-3770Z_New_Unlock_by_CellSold.html http://www.4shared.com/rar/244Ti8IX/K3770z_Download_Tool.html ¦Method 2 http://www.4shared.com/rar/p4v1y3KL/k3770z_unlock_file.html http://www.4shared.com/rar/244Ti8IX/K3770z_Download_Tool.html ¦Restore Original State (vodafone) http://www.4shared.com/rar/AT4Iajs-/ZTE_k3770z_Original_Vodafone_D.html http://www.4shared.com/rar/244Ti8IX/K3770z_Download_Tool.html ¦Drivers:- 3in1 http://www.4shared.com/rar/is-RieHr/ZTE_ICERA_Chipset_Drivers.html K3770z_MF186 http://rghost.net/42888305 k3770-z Original http://rghost.net/42888312 k3770-z_MF192 http://rghost.net/42888265 Installer Unlocked:- http://www.4shared.com/rar/ageSVkr7/MTS_MF192_Connection_manager_C.html http://www.4shared.com/rar/m6CvbC7p/UnicomDashboardMF186_CellSoldi.html ¦Note:- ¦ Plug in K3770z Dongle into USB port ¦ Let the modem install original software with drivers ¦ check in device manager for all installed ports ¦ Now uninstall the original vodafone software ¦ Open K3770z downloader_tool.exe, Which you downloaded ¦ Ignore any errors wait till downloader detects port and modem version ¦ Click on software version ¦ Browse to Unlock_file folder ¦ Click the big arrow button next to version info window ¦ Flashing will be started in a Second ¦ After The Flashing is complted it will say “Flashed Successfully” ¦ Now remove old Dashboard(installers) ¦ Replug modem and wait few seconds proceed with new cd install ¦ Warning : For proper functioning of modem, download tool must show pass(green). If download Tool shows fail (98%) mostly ¦ Uninstall all dashboard ¦ Give path of Drivers and check which best suits your modem to flash the firmware successfuly. ¦ run cc cleaner ¦ Reboot Your PC/Labtop ¦ Plug Modem and Prepare modem to flash with Original Firmware see - Restore Original State (vodafone) Above procedure Totally Risk Free Tested by thousands of users Make sure your system is healthy and usb ports are working well br CellSoldiers™ A.K.Singh |
01-12-2013, 05:14 | #310 (permalink) |
Member: 65063 Status: Offline Thanks Meter: 2,419 | K3770z MOre Resolutions !!! Some more Resolutions !!! Remove all previous dashboards,installers or drivers Plug in modem Ignore cd installer just give appropriate drivers Eg. if modem ask for MF186 give this driver http://rghost.net/42888305 for MF192 give http://rghost.net/42888265 for Original state modem (vodafone) give http://rghost.net/42936929 Restart PC Go to MY Computer > Properties > Hardware > Device Manager Check your modem must have created Ports. Now open downloader wait for detection browse to desired unlock firmware dashboard and flash modem Above procedure is 10000000% tested Still You fail just check your PC/Labtop Note : In china dashboard one need to change settings in dashboard for proper modem detection. Enjoy ! br, CellSoldiers™ A.K.Singh |
01-12-2013, 05:45 | #311 (permalink) | |
Member: 65063 Status: Offline Thanks Meter: 2,419 | Quote:
br, | |
01-14-2013, 14:36 | #312 (permalink) |
Freak Poster Join Date: Apr 2008 Location: india Age: 32
Member: 759661 Status: Offline Thanks Meter: 91 | sir after use ur method 1 my modem was dead in devise maneger need a driver and the name of driver is....vodafone usb scsi cd rom usb device pls help me how to recovery my modem??? |
01-15-2013, 07:57 | #313 (permalink) | |
above 2 postings are for all possible drivers,unlocking and curing for k3770z read 100 times br, | |
01-15-2013, 18:12 | #314 (permalink) |
Member: 65063 Status: Offline Thanks Meter: 2,419 | ZTE K3770z failed 98% Best way to cure failed 98% flashed modem - remove all dashboard/installers from PC - reboot PC - plug in modem - if modem open original dashboard Install it(Vodafone Installer) not from modem cd, let the pc prepare all modem ports - run downloader , browse to Original Vodafone file -flash the modem, if fails at 98% ,replug modem flash again with same original firmware This time you il get 100% passed flashing - now replug and flash your modem with Unlock method 1 or method 2 br, CellSoldiers™ A.K.Singh |
The Following User Says Thank You to ~AKSingh~ For This Useful Post: |
Nokia 3210 + datacable, use as a modem? | Lilacrazor | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 05-04-2001 18:03 |
using 7110 modem and laptop | ace2k1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 04-21-2001 05:33 |
using 7110 modem and laptop | ace2k1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 04-19-2001 18:36 |
nokia 6150 internal modem | mottile | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-21-2001 00:14 |
6150 + NCDS3.0 + Win2000 + IBM600X + Xyrcom GSM modem (realport)? | bibi2k | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-21-2000 17:33 |
