Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM / HSDPA Modems and Routers
GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares
Old 08-12-2012, 17:35   #1 (permalink)
Member: 1404245
Zte Mf190 (Smart/Reliance) invalid uim after movistar firmware write
Hi
Please help me for this problem
how to recover my modem from this.
thanks
The Following User Says Thank You to satrughna For This Useful Post:
Old 08-12-2012, 18:53   #2 (permalink)
J@zz's Avatar
Member: 43032
Sonork: 100.1619349
Originally Posted by satrughna View Post
Hi
thanks
I also face same problem, waiting for solution.
Thanks
J@zz
Old 08-12-2012, 21:07   #3 (permalink)
rahul_rocks3's Avatar
Member: 1312746
Sonork: 100.1604777
Hi
thanks
Can you read modem info using dc unlocker or the craked version of it and share it over here...i guess I can help you out
The Following User Says Thank You to rahul_rocks3 For This Useful Post:
Old 08-14-2012, 12:47   #4 (permalink)
Member: 1312746
Sonork: 100.1604777
brother did you check the imei...if the imei is not showing then you can repair it using multifun
Old 08-15-2012, 07:00   #5 (permalink)
Member: 1404245
dc unlocker failed read info.
data card making ports without any problem
i dont understand where is problem
Mr. Nirav & Mr. Sing plz give some input on this.
Old 08-15-2012, 08:11   #6 (permalink)
~AKSingh~'s Avatar
Member: 65063
Sonork: 100.1603561
BD_RELIANCEMF190V1.0.0B01 is easily unlockable by many tools , even infinity cdma tool can unlock it
but
BD_RELIANCEMF190V1.0.0B05 has issues can only be unlock after downgrading
dont use OEM versions flash you may kill this modem.
br,
The Following 2 Users Say Thank You to ~AKSingh~ For This Useful Post:
Old 08-15-2012, 08:19   #7 (permalink)
~AKSingh~'s Avatar
Member: 65063
Sonork: 100.1603561
known MF190 versions
can try with these
AIRCEL_IN_MF190AF3V1.0.0B03
BSNL_IN_MF190V1.0.0B08
SHYAM_IN_MF190V1.0.1B01
SHYAM_IN_MF190V1.0.0B02 and some !dea versions
br,
Old 08-15-2012, 08:33   #8 (permalink)
Member: 1312746
Sonork: 100.1604777
Brother I am 100% sure that the imei is lost....contact me on yahoo will help you out
Old 08-15-2012, 11:07   #9 (permalink)
J@zz's Avatar
Member: 43032
Sonork: 100.1619349
can try with these
br,
Where to find/download it?
BR.
J@zz
Old 08-15-2012, 16:05   #10 (permalink)
Crazy Poster
Member: 673457
mf 190 versions
can try with these
br,
wher to download link pls
The Following User Says Thank You to div9826611222 For This Useful Post:
Old 08-15-2012, 19:05   #11 (permalink)
..::CHAIN::..'s Avatar
Member: 1753928
Sonork: 100.1615906
I Think After Downgrading Stick Not Work Properly like that K3770z...
Old 08-15-2012, 21:55   #12 (permalink)
Member: 1312746
Sonork: 100.1604777
Its not clear that why did the user try to downgrade it when it can be easily unlocked.
And as far as now the modem is concerned i m sure his imei is lost and that's the reason why it is not showing up on dc-unlocker.
For the user who is facing the problem : Kindly if possible buzz me up, will try to repair your modem.
Old 08-16-2012, 06:01   #13 (permalink)
Member: 1324316
connect using diagnostic port in infinity cdma
and check connected or not then disable AT port and one other port disable and restart the modem again then it will show two ports NMEA AND DIAGNOSTIC PORT AND THEN HOPEFULLY U CAN FLASH
Old 08-16-2012, 15:25   #14 (permalink)
NiRaV.SoN!'s Avatar
Member: 1753913
Arrow
BR.
J@zz
ZTE Support
BR,
NiRaV_SoN!
The Following User Says Thank You to NiRaV.SoN! For This Useful Post:
Old 08-16-2012, 21:32   #15 (permalink)
Member: 1753928
Sonork: 100.1615906
@ Nirav
good job keep it up......
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 28 08-30-2012 03:40
read eeprom write eeprom, what do i need? jonthe Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 12-08-2010 05:24
How to upgrade firmware on Nokia Pepek Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 06-18-2000 23:29
5110 5.24 locked all 4 locks after unlocking... MCG Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 03-07-2000 21:24
Page generated in 0.37574 seconds with 11 queries
