08-21-2019, 07:57 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: earth
Member: 570373 Status: Offline Thanks Meter: 234 | alcatel 1066G unlock Unsupported nck box Detecting phone, wait... Phone must be off. Connect usb cable without pressing any key. Using connection mode 1 Making 10 sec timeout.. For some phones need to wait 5-20 sec untill will swith in diag. Detected: SPRD U2S Diag (COM31) Version Info 1066G_E8GB5_V1.6_180829_SIMLOCK_NEWPAPlatform Version MOCOR_16A.W17.09.3_ReleaseBASE Version BASE_SVNHW Version 1265A_MB_PCB_V1.108-29-2018 173022 IMEI 1: 3529361 IMEI 2: 352751019 Serial number: AZLB03BQGFC07UL BT: FFFFFFFFFFFF WIFI: FFFFFFFFFFFF Reading simlock backup, wait.... Saved to: C:\Users\naizer\Documents\spreadtrum_module\backup \spd_simlock_nvram_backup\3529361_AZLB03BQGFC07UL_ diag_simlock_nvram_backup_1.tar [0]Unsupported simlock, aborting.... [0]Unsupported Simlock Type Done. ACTION: Read Simlock Info. Detecting phone, wait... Phone must be off. Connect usb cable without pressing any key. Using connection mode 1 Detected: SPRD U2S Diag (COM31) Version Info 1066G_E8GB5_V1.6_180829_SIMLOCK_NEWPAPlatform Version MOCOR_16A.W17.09.3_ReleaseBASE Version BASE_SVNHW Version 1265A_MB_PCB_V1.108-29-2018 173022 IMEI 1: 35293610 IMEI 2: 3527510 Serial number: AZLB03BQGFC07UL BT: FFFFFFFFFFFF WIFI: FFFFFFFFFFFF Reading simlock backup, wait.... Saved to: C:\Users\naizer\Documents\spreadtrum_module\backup \spd_simlock_nvram_backup\35293613_AZLB03BQGFC07UL _diag_simlock_nvram_backup_2.tar [0]Unsupported simlock, aborting.... [0]Unsupported Simlock Type Done. |
08-21-2019, 08:12 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | alcatel 1066G direct unlock is not supported. If you want, you can flash unlocked firmware from support. |
The Following User Says Thank You to orbita For This Useful Post: |
08-22-2019, 07:56 | #3 (permalink) |
Member: 570373 Status: Offline Thanks Meter: 234 | EXE: NckBox Spreadtrum Module 1.1 ACTION: Flash Firmware. Selected firmware: 1066G_MWIE1_V1.6_180314_SIMLOCK.pac NV: Default Mode (protect calibration) Device Storage: NOR Detected: SPRD U2S Diag (COM31) [00:00:00] Sending loader. BOOT: SPRD3W Sending loader, keep boot key untill loader start. [00:00:00] Loader ok [00:00:00] Wait for loader.... Loader OK: Spreadtrum Boot Block version 1.2 Changing bautrate OK. [00:00:01] First boot done. [00:00:01] Sending second loader. [00:00:01] Second loader sent ok. [00:00:01] Making NV backup. IMEI: 3529361 Backup saved: C:\Users\naizer\Documents\spreadtrum_module\backup \spd_nvram_backup\352936106811111_saved_nv_.bin [00:00:02] Start write: NV IMEI 1: 35293 IMEI 2: 3527510 Model from phone: 1066G-2AE8GB5 Protecting GSM_CALI_ITEM_ID id: 0x2 Protecting BlueTooth id: 0x191 Protecting BandSelect id: 0xD Protecting MMITest id: 0x19A Protecting WIFI id: 0x199 Protecting SIMLOCK_USER_DATA id: 0x1F1 [00:00:03] Start write: SC6531EFM_sc6531efm_32X32_160X128BAR_AB_stone.bin [EraseFlash]Format: EraseUdisk [00:00:40]Format: 90000005 0 Format OK. [EraseFlash]Format: FLASH [00:00:41]Format: 90000003 C0000 Format OK. Flashing done. unlock ok |
08-22-2019, 20:42 | #4 (permalink) |
No Life Poster Join Date: Aug 2011 Location: caribbean island
Member: 1643797 Status: Offline Thanks Meter: 182 | not sure what i'm doing wrong here but phone still lock EXE: NckBox Spreadtrum Module 1.1 ACTION: Flash Firmware. Selected firmware: 1066G_MWIE1_V1.6_180314_SIMLOCK.pac NV: Default Mode (protect calibration) Device Storage: NOR Detected: SPRD U2S Diag (COM101) [00:00:00] Sending loader. BOOT: SPRD3W Sending loader, keep boot key untill loader start. [00:00:00] Loader ok [00:00:00] Wait for loader.... Loader OK: Spreadtrum Boot Block version 1.2 Changing bautrate OK. [00:00:01] First boot done. [00:00:01] Sending second loader. [00:00:01] Second loader sent ok. [00:00:01] Making NV backup. IMEI: 352936107523580 Backup saved: C:\Users\reid's phone Shop\Documents\spreadtrum_module\backup\spd_nvram_ backup\352936107523580_saved_nv__2.bin [00:00:01] Start write: NV IMEI 1: 352936107523580 IMEI 2: 352751019523267 Model from phone: 1066G-2*E8GB1 Protecting GSM_CALI_ITEM_ID id: 0x2 Protecting BlueTooth id: 0x191 Protecting BandSelect id: 0xD Protecting MMITest id: 0x19A Protecting WIFI id: 0x199 Protecting SIMLOCK_USER_DATA id: 0x1F1 [00:00:03] Start write: SC6531EFM_sc6531efm_32X32_160X128BAR_AB_stone.bin [EraseFlash]Format: EraseUdisk [00:00:49]Format: 90000005 0 Format OK. [EraseFlash]Format: FLASH [00:00:50]Format: 90000003 C0000 Format OK. Flashing done. Log saved: C:\Users\reid's phone Shop\Documents\spreadtrum_module\Saved_Logs\352936 107523580_writepac__2.txt Total Time: 00:01:01 Done. |
07-27-2020, 11:59 | #8 (permalink) |
No Life Poster Join Date: May 2002 Location: distant galaxy Age: 50
Member: 12386 Status: Offline Thanks Meter: 18 | hi can someone please help me i have just flashed my alcatel 1066g firmware with unlock firmware from support . all ok but when i turn on the phone its got dual sim firmware? which file is for uk single sim firmware. i have tried flashing several stiill dual firmware thanks |
07-27-2020, 12:05 | #9 (permalink) | |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
Firmware with A usually come with latin america phones and can have different gsm band. Example 1066D_ALAM1_V1.0_180912_UNLOCK.zip - dual sim 1066G_ALGB1_V1.3_171208_UNLOCK.rar - single sim If phone after flash have white display, check this document in server Difference between New Old PA of Tiger L5(1066) and select the corresponding upgrade software.pdf Last edited by orbita; 07-27-2020 at 12:11. | |
09-16-2022, 10:26 | #14 (permalink) |
No Life Poster Join Date: Sep 2007 Location: iPhone Age: 46
Member: 599385 Status: Offline Sonork: 100.1583205 Thanks Meter: 82 | I try to flash this Alcatel and getting this issue, any ideas whats wrong? EXE: NckDongle Spreadtrum Module 2.1.1 ACTION: Flash Firmware. Selected firmware: 1066G_TBDE5_V1.3_210729_UNLOCK_NEWPA.pac NV: Default Mode (protect calibration) Device Storage: NOR Start Detect phone. Phone must be off with battery inside. Insert USB cable after long press boot key Keep key untill boot complete. Detected: SPRD U2S Diag (COM41) [00:00:00] Sending loader. First loader start fail, aborting. Error untill sending boot, aborting. Total Time: 00:00:01 Done. |
09-18-2022, 06:53 | #15 (permalink) | |
If you will use more new module, it will give you hint what key to press also. | |
