03-23-2018, 15:33 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Nigeria Lagos
Member: 1014618 Status: Offline Sonork: 100.1637137 Thanks Meter: 110 | Asus Z00SD DEAD AFTER FORMAT so i flashed it but didnt boot non power at all Flash files count is :4 Action : Firmware update. Selected Model: 0-By CPU: MT6580 Exe version: NCKBox AndroidMTK 1.8.8.7 Scenario: [0]Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek USB Port (COM10) Boot mode: Brom Phone detected...Please wait Sending DA agent, please wait... Using Algo 1. ---------------------------------------------------- BaseBand CPU :MT6580 BaseBand CPU Secure Version : 05 BaseBand CPU Bootloader Version : FE ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) HYNIX 0x483847316505 EMMC FW VERSION: 07:00:00:00:00:00:00:00 EMMC CID: 90014A48384731 : 000000000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2c00000 [7.293 GB] Preloader SEC version: 2 Status: USB_FULL_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM13) Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Flash EMMC Algo Start. Preloader backup already exist, skip saving. Starting flash. Download firmware to flash now... Wait untill phone will start charging. All done. |
03-23-2018, 15:59 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Format full except preloader erase whole flash ic. Is normal this, sure phone will not power on after you erased full firmware. Phone can not start from 2 reasons. 1.Flashed firmware is incompatible with your phone. 2.You must flash firmware together with preloader(differ version). |
