12-15-2015, 21:40 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Cuba Age: 56
Member: 517318 Status: Offline Thanks Meter: 88 | Blu D143K MT6571 Nand dead after flash [ANSWERED] I need help with a Blu Dash Jr 4.0k D143k Type 01. was on just not working the touch, flash to solve the problem, other times I've solved so. As I can relive this phone I have used several firmwares but I fail to turn on Only shows that battery is charging attachment brom_debug Thanks mfeliu07 brom_debug - Download - 4shared |
12-16-2015, 10:58 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Hi mfeliu07 Exe only flash firmware. And flashing is ok for this CPU, confirmed by many users. Phone working condition is also depenent from working hardware and corect firmware. If phone is damaged , or is used wrong firmware can be problems also. |
The Following User Says Thank You to orbita For This Useful Post: |
12-16-2015, 14:18 | #3 (permalink) |
Member: 517318 Status: Offline Thanks Meter: 88 | Hello NCK is very good to work with MTK, I know always I use to work with them. In this case use the correct firmware, I called my attention to putting the phone in factory mode is on and makes all tests well. A little weird this. Greetings and thank you very much mfeliu07 |
The Following User Says Thank You to mfeliu07 For This Useful Post: |
