09-25-2014, 17:25 | #1 (permalink) |
Freak Poster Join Date: May 2009
Member: 1026469 Status: Offline Thanks Meter: 65 | BLU T200 (MT62230A) UNlock help [ANSWERED] I have provided a picture below in case you need extra info upload image online free |
09-25-2014, 18:53 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | What connector have phone? If phone have not usual connector, try to locate rx and tx on PCB board. Solder wires or use cable if posible and make boot info, selecting any(first one model) from generic mtk exe. Post result here after. |
09-25-2014, 19:32 | #3 (permalink) |
Member: 1026469 Status: Offline Thanks Meter: 65 | I have manage to get the unlock, i put a non supported sim and I don't get the insert unlock code box, What i get is a wrong sim message. Is there is a secret code to get the unlock code entry menu on this phone? ----------------------------------------------------- Reopen comport(COM8) BaseBand CPU : MT6223, E08 SW_VER : TL_M118DPU1370_F59LGP1_00.40 HW_VER : TELACOM23_08A_PMWY_HW Meta mode conected ok, start reading phone.... Phone imei[1] : Phone imei[2] : User code(128) : 1122 SIMLOCK INFO[1]: Block1(N) : Locked (remain:0) Code : 83522661 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C) : Unlocked SIMLOCK INFO[2]: Block1(N) : Locked (remain:0) Code : 83522661 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C) : Unlocked META END OK. All done. |
09-25-2014, 19:43 | #4 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Secret code will not work here Locked (remain:0). Unlock counter is 0, and phone will not allow to enter code. Need direct unlock to make. |
09-25-2014, 21:37 | #5 (permalink) |
Member: 1026469 Status: Offline Thanks Meter: 65 | I did a direct unlock using the Huawei G6600 as phone ( Thanks Orbita). It asked for the code that I got using the BLU T300. The problem is that everytime I turn off the phone and turn it on again, I have to put the code again. ANy solution for this? |
