05-30-2016, 12:00 | #1 (permalink) |
Freak Poster Join Date: Jun 2004 Location: Philippines Age: 64
Member: 69911 Status: Offline Thanks Meter: 69 | FRP Reset Error Exe version: NCKBox AndroidMTK 1.8.6.8 Selected model: A2010a Action: Reset FRP Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM Port (COM6) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6735M_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) SAMSUNG 0x513732534d42 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 15010051373253 : 000000000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2880000 [7.290 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : MediaTek DA USB VCOM Port (COM56) Checking data....wait! Error: S_DA_SDMMC_CONFIG_FAILED [3147]Error: S_DA_SDMMC_CONFIG_FAILED Wait untill phone will start charging. |
05-30-2016, 12:24 | #2 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Ethiopia
Member: 449991 Status: Online Thanks Meter: 933 | Exe version: NCKBox AndroidMTK 1.8.6.8 Selected model: A2010a Action: Reset FRP Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM Port (COM256) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6735M_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) SAMSUNG 0x513732534d42 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 15010051373253 : 000000000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2880000 [7.290 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : MediaTek DA USB VCOM Port (COM376) Checking data....wait! Error: S_DA_SDMMC_CONFIG_FAILED [3147]Error: S_DA_SDMMC_CONFIG_FAILED Wait untill phone will start charging. i olso face this problem hop it will fix on next update but try via generic |
The Following User Says Thank You to dereje For This Useful Post: |
05-31-2016, 02:08 | #3 (permalink) |
Member: 69911 Status: Offline Thanks Meter: 69 | DONE by installing OLDER Version - 1.8.6.5 Exe version: NCKBox AndroidMTK 1.8.6.5 Selected model: MT6735 Action: Reset FRP Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM Port (COM6) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6735M_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) SAMSUNG 0x513732534d42 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 15010051373253 : 000000000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2880000 [7.290 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : MediaTek DA USB VCOM Port (COM56) Checking data....wait! FORMAT EMMC FLASH : BEGIN: 0x6a00000 - LEN: 0x100000 FRP Reset Done. Wait untill phone will start charging. All done. |
The Following User Says Thank You to edpr_0507 For This Useful Post: |
