06-26-2015, 20:30 | #1 (permalink) |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | How to unlock idea mf190 ? [ANSWERED] Code: Module Ver. : 2.9 Com Port : COM146 : ZTE Diagnostics Interface (COM146) Baud Rate : 921600 Device : ZTE MF190 Operation : Read Info Port opened. Reading Information... Compile : Aug 29 2011 19:56:42 Release : May 01 2011 01:00:00 Hw Ver. : MF190 IMEI : 911133xxxxxxxxxxx Build : M6290A-KPRZL-2.4.0105T Software : BD_MF190V1.0.0B21 Checking for Modem Device.. Modem : COM145 : ZTE Proprietary USB Modem Reading AT Mode Info... Model : MF190 IMEI : 911133xxxxxxxxxxxxx Version : BD_IDEAMF190V1.0.0B01 Simlock : Custom Firmware Sim Status : SIM Unavailable Operation finished. Port Closed. Elapsed Time: 00:01 Code: Module Ver. : 2.9 Com Port : COM146 : ZTE Diagnostics Interface (COM146) Baud Rate : 921600 Device : ZTE MF190 Operation : Unlock Port Opened Reading Information... Compile : Aug 29 2011 19:56:42 Release : May 01 2011 01:00:00 Hw Ver. : MF190 IMEI : 911133xxxxxxxxxxx Build : M6290A-KPRZL-2.4.0105T Software : BD_MF190V1.0.0B21 Checking for Lock Data... Lock Data not found! Operation finished. Port Closed. Elapsed Time: 00:42 |
06-27-2015, 06:51 | #2 (permalink) |
No Life Poster Join Date: Jan 2013 Location: NCK Team
Member: 1873869 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,333 | Please flash it with Firmware in Support. Use 128MB FW if its 128MB Version. If you get some error in flashing then Try with other FW in recovery mode without disconnecting Modem. Just a hint, while Reading Info, always use non-accepted SIM Card to get real LOCK Info. Br, NCK Team |
08-05-2015, 11:58 | #4 (permalink) |
Member: 1873869 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,333 | If you select Wrong Firmware, lets say, 128MB for 64MB, then it will fail and will show you to select different firmware in logs. Just select correct size firmware and and tick Recovery Mode, and done. Better if you always use Skip EFS option. Br, NCK Team |
