04-06-2018, 09:48 | #1 (permalink) |
Freak Poster Join Date: May 2003 Location: Poland Age: 46
Member: 27843 Status: Offline Sonork: 100.1646294 Thanks Meter: 26 | htc 620 imei repair Selected connection metod: Adb connection Exe version: NCKBox AndroidMTK 1.8.8.8 Selected phone: HTC 620 Action : IMEI REPAIR. IMEI[1] for write : 359342063055910 IMEI[2] for write : 359342063088911 Repair IMEI Start. Phone lcd must be on and unlocked. If ask for SU acces, accept it. Device have root ---NVRAM IMEI---- PHONE IMEI 1 : 359342063055910 PHONE IMEI 2 : --------- WRITING IMEI[1] :359342063055910 --------- Writed OK. how to repair 2 imei?? |
04-06-2018, 13:05 | #4 (permalink) |
Member: 27843 Status: Offline Sonork: 100.1646294 Thanks Meter: 26 | after repair log: elected connection metod: Flash Connection Exe version: NCKBox AndroidMTK 1.8.8.8 Selected phone: HTC 620 Action : IMEI REPAIR. IMEI[1] for write : 359342063055910 IMEI[2] for write : 359342063088911 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM29) Boot mode: Preloader Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6592 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) SAMSUNG 0x513758534142 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 150100513758534142 : 00000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2880000 [7.290 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM99) Dumping data, wait. [3]Warning, nvram posible damaged!!. Wait untill phone will start charging. All done. imei is 355195000000017 not work |
04-06-2018, 13:50 | #7 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Posible you not readed exe logs. Code: Dumping data, wait. [3]Warning, nvram posible damaged!!. Wait untill phone will start charging. All done. imei is 355195000000017 not work You must solve first problem with your nvram. Second, exe not writed even 1 byte in your phone, it exit on error. So most posible was another reason for this error Code: nvram waring err=0x10 in wifi menu Also after succefull imei write in flash mode, need to wipe phone. Please be more carefull with what you do. Pressing buttons without any knowlege can finish with totally dead phone |
04-07-2018, 04:44 | #8 (permalink) |
Member: 27843 Status: Offline Sonork: 100.1646294 Thanks Meter: 26 | repair via flash mode. after reset emmc. imei is 355195000000017 - not conect in some gsm operator sigma via adb repair but not activate pack ;/ |
04-07-2018, 20:15 | #11 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Just wow You have default imei, and from your log nvram is damaged. If you will read again my repply, exactly this was my sugestion. |
