04-14-2018, 06:43 | #1 (permalink) |
No Life Poster Join Date: Sep 2004 Location: coast Age: 53
Member: 83397 Status: Offline Thanks Meter: 204 | Huawei lua-u02 frp remove nck box possible? Action : Boot Info. Selected Huawei:Ascend Y3 II[LUA-U29] Exe version: NCKBox AndroidMTK 1.8.8.8 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM Port (COM29) Boot mode: Preloader Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6582 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) HYNIX 0x483847316505 EMMC FW VERSION: 07:00:00:00:00:00:00:00 EMMC CID: 90014A483847316505 : 00000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2c00000 [7.293 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM Port (COM37) This phone have FRP partition. Build ID: HUAWEILUA-U02 Display ID: LUA-U02C588B100 Version: 5.1 Build Date: 2016年 10月 21日 星期五 17:13:39 CST Model: HUAWEI LUA-U02 Brand: HUAWEI Device: HWLUA-U6582 Region: GB Mediatek Version Release: ALPS.L1.MP12.V1.2_WT6582.WE.SH.L1_P6 Sw Internal Version: LUA-U02C588B100 BOOTLOADER CODE fastboot oem unlock 2038F78528E146ED Power phone in fastboot mode, press button Enter Bootloader Code and use this code: 2038F78528E146ED In some phones need to enable OEM UNLOCK in Developer options FRP CODE fastboot oem frp-unlock 2038F78528E146ED Power phone in fastboot mode, press button Enter FRP Code and use this code: 2038F78528E146ED IMEI[1]: 861080030969034 IMEI[2]: 861080030969034 Wait untill phone will start charging. All done. |
04-14-2018, 07:00 | #2 (permalink) | |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
fastboot oem frp-unlock 2038F78528E146ED Power phone in fastboot mode, press button Enter FRP Code and use this code: 2038F78528E146ED Or simple press in exe erase FRP button. | |
04-14-2018, 12:38 | #3 (permalink) | |
Member: 83397 Status: Offline Thanks Meter: 204 | Quote:
after power phone in fastboot there is no option in phone to enter the code and software when you select Lua-U02 frp reset button is not active. | |
04-14-2018, 12:52 | #4 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Yes indeed, in phone not exist button to remove frp. You must put phone in fastboot and use button from exe. I'am atached screenshot, hope it will help you. You selected Huawei:Ascend Y3 II[LUA-U29] and boot was ok. You can use this selection for FRP also. |
The Following 3 Users Say Thank You to orbita For This Useful Post: |
