Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > NCK Team products > NCK Box Premium v2
Old 11-09-2018, 10:03   #1 (permalink)
louka's Avatar
Member: 198016
Sonork: 100.1602918
Thanks Meter: 408
Huawei Y5 II[CUN-L21] Flash Error [ANSWERED]
Flash files count is :15
Action : Firmware update.
Selected Model: Huawei: Ascend Y5 II[CUN-L21]
Exe version: NCKBox AndroidMTK 1.8.9.4
Scenario: [0]Safe Flash
Reinsert phone battery.
Battery must be charged.
Phone must be off with battery inside.
Please insert USB cable now...
Detected : MediaTek PreLoader USB VCOM Port (COM6)
Boot mode: Preloader
BBCHIP: 321 0 ca00
Using Algo 2.
Scatter file loaded, not need emmi.
Phone detected...Please wait
Sending DA agent, please wait...
BaseBand CPU :MT6735
BaseBand CPU Secure Version : FF
BaseBand CPU Bootloader Version : 01
INT RAM: 128 KB SDRAM
EXT RAM: 1 GB DRAM
EMMC: (58Gb+8192Mb) HYNIX 0x483847316505
EMMC FW VERSION: 07:00:00:00:00:00:00:00
EMMC CID: 90014A483847316505 : 00000000000000
EMMC UA SIZE: 0x1d2000000
BOOT STYLE: EMMC BOOT
FULL LENGTH: 0x1d2c00000 [7.293 GB]
Status: USB_HIGH_SPEED
Detecting high speed port, wait......
If driver not installed, install high speed port driver.
If not need high speed port, disable it.
After repeat opperation.
Detected : MediaTek DA USB VCOM Port (COM7)
Warning, flashing preloader disabled!
If you change android version, preloader must be flashed.
Flash EMMC Algo Start.
Preloader backup already exist, skip saving.
Starting flash.
Error: To programming code area is forbidden in this phone.
To enable format need to flash rework secro.
Wait untill phone will start charging.
All done.
Old 11-09-2018, 10:28   #2 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
Try to read exe hint.
The Following User Says Thank You to orbita For This Useful Post:
Old 10-10-2020, 07:50   #3 (permalink)
Member: 341386
Sonork: 100.1647322
Thanks Meter: 42
where is rework secro file?
Old 10-10-2020, 08:24   #4 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
It must come with factory firmware.
In firmware to flash with fastboot, it will not exists.
In factory firmware to flash with flasher, it will exists.
Readed firmwre you can't write in this phone.
You get answer what you need?
The Following 2 Users Say Thank You to orbita For This Useful Post:
Page generated in 0.14051 seconds with 8 queries
