07-03-2019, 08:50 | #1 (permalink) |
Freak Poster Join Date: Mar 2010 Location: IVORY COAST,abidjan
Member: 1249629 Status: Offline Thanks Meter: 28 | Infinix x606d dead after flash I flased AN INFINIX x606D WITH X606 firmware and set is dead all x606d da file I got cant boot thee phone here is log with nck box Exe version: NCKBox AndroidMTK 2.0 Scenario: [0]Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MTK USB Port (COM21) Boot mode: Brom BBCHIP: 6580 0 ca00 Using Algo 1. Scatter file loaded, not need emmi. Phone detected...Please wait Sending DA agent, please wait... First stage DA fail, aborting [SECURE BOOT]Not supported by exe or wrongly selected phone If model is listed, please select correct model from list If model is not listed, use factory DA LOADER Try also to boot phone in brom mode(for some phones this work) BBCHIP MT6580 Boot Fail.!!!. [0]All done. WHAT IS THE PERFECT SOLUTION? |
07-04-2019, 07:37 | #2 (permalink) |
No Life Poster Join Date: Dec 2016 Location: .
Member: 2659717 Status: Offline Thanks Meter: 487 | First select brand and model secondly select full flash not safe flash and connect the phone as it dead it may not detect instantly when connected just leave it connected for some seconds the program will detect it and the flash process will start. leave it connected when flash process is complet and make sure it's start charging before u remove cable some dead boot may be battery issue so just leave to check the battery state. Lastly make sure u are using the same or correct firmware for the phone before u flash |
07-04-2019, 19:20 | #3 (permalink) | |
Freak Poster Join Date: Nov 2012 Location: Lagos, Nigeria
Member: 1846240 Status: Offline Thanks Meter: 86 | Quote:
