01-27-2015, 09:36 | #1 (permalink) | ||
Freak Poster Join Date: Dec 2006 Location: Philippines
Member: 405730 Status: Offline Thanks Meter: 184 | lenovo s650 invalid imei (cdc serial usb driver problem) [SOLVED] im trying to repair imei for this lenovo s650 with 4.4.2 android version in meta mode but im stuck in this cdc serial usb driver. i have tried all mtk cdc driver and ZTE_LENOVO_MTK_CDC_VCOM_drivers from support but no luck need urgent help from nck team. Quote:
01-27-2015, 10:00 | #2 (permalink) |
No Life Poster Join Date: Jan 2013 Location: NCK Team
Member: 1873869 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,333 | You can also try with MTK_Android_CDC_Drivers_new.rar First reboot in Meta Mode then try. If not work, you can install driver for Meta Port from Device Manager once phone in Rebooted in Meta Mode. Br, NCK Team |
01-27-2015, 10:31 | #3 (permalink) | |
Member: 405730 Status: Offline Thanks Meter: 184 | Quote:
01-27-2015, 10:44 | #4 (permalink) |
Member: 1873869 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,333 | What do you mean by same result? How we can see what is happening at your side by saying "same result"? You must check your self in Device Manager. If driver is not installed then it must be listed there with Yellow Exclamation mark. If you still can solve this issue, contact me on Yahoo Messenger. Br, NCK Team |
01-27-2015, 11:52 | #5 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | hi ralel. Check your pc, exe really not have connection problems. Code: same result.............. Here not exist magic, drivers not installed or incorectly installed, exe will not see phone. Also windows have control panel where show vid and pid for "problematic" device. Try to open control panel and check driver inf file and your vid_pid entry. Evantually add manual coresponding vid and pid in inf file. |
The Following User Says Thank You to orbita For This Useful Post: |
01-28-2015, 00:55 | #6 (permalink) |
Member: 405730 Status: Offline Thanks Meter: 184 | problem solved. flash and downgrade to version 4.2.2 with nckbox android mtk module then repair imei via adb mode, no need to root. thanks NCKCDMA & orbita |
01-28-2015, 01:19 | #7 (permalink) | |||
Member: 405730 Status: Offline Thanks Meter: 184 | flashing with 4.2.2 Quote:
writting imei Quote:
The Following User Says Thank You to ralel For This Useful Post: |
02-16-2015, 15:18 | #9 (permalink) | |
Freak Poster Join Date: Aug 2012 Location: Armenia Age: 36
Member: 1795596 Status: Offline Thanks Meter: 30 | Quote:
USB\VID_17EF&PID_7438&REV_0255&MI_02 USB\VID_17EF&PID_7438&MI_02 Lenovo Yoga cdc | |
