04-04-2020, 11:23 | #1 (permalink) |
No Life Poster Join Date: Jan 2020 Location: Algeria
Member: 2944109 Status: Offline Thanks Meter: 656 | Lenovo Vibe C2 K10a40 Flash + Restore NVRAM + Repair IMEI Code: Flash files count is :13 Action : Firmware update. Selected Model: 0-By CPU: ELBRUS Exe version: NCKBox AndroidMTK 2.7 Scenario: [0]Safe Flash Will be used loader: DA_SWSEC_CRYPTO20_K10a40.bin Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM4) Boot mode: Preloader BBCHIP: 335 0 ca00 Using Algo 2. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6735M BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) SAMSUNG 0x463732324d42 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 150100463732324D42 : 00000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2880000 [7.290 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM8) Backup preloader saved in firmware directory. Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Starting flash. Wait untill phone will start charging. [0]All done. Restore NVRAM done Code: Exe version: NCKBox AndroidMTK 2.7 Selected phone: ELBRUS Action: Restore NVRAM Flash Mode Will be used loader: DA_SWSEC_CRYPTO20_K10a40.bin Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM4) Boot mode: Preloader BBCHIP: 335 0 ca00 Using Algo 2. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6735M BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) SAMSUNG 0x463732324d42 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 150100463732324D42 : 00000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2880000 [7.290 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM8) [helio]Reset privacy, wait. Restoring NVRAM Need to perform WIPE or CLEAR EMMC after. Wait untill phone will start charging. [0]All done. IMEI REPAIR done Code: Selected connection metod: Flash Connection Exe version: NCKBox AndroidMTK 2.7 Selected phone: ELBRUS Action : IMEI REPAIR. IMEI[1] for write : 862xxxxxxxxx646 IMEI[2] for write : 862xxxxxxxxx647 Will be used loader: DA_SWSEC_CRYPTO20_K10a40.bin Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM4) Boot mode: Preloader BBCHIP: 335 0 ca00 Using Algo 2. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6735M BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) SAMSUNG 0x463732324d42 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 150100463732324D42 : 00000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2880000 [7.290 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM8) [helio]Reset privacy, wait. Dumping data, wait. Reading imei IMEI[1]: 862xxxxxxxxx707 IMEI[2]: 862xxxxxxxxx709 Backup saved: C:\nckbox\android_mtk\Android_MTK_Backup_Folder\nvram_backup\FLASH_MODE_NVRAM_MT6735M_862753030878707_862753031198709_04_03_2020_15_48_46.zip Writing imei IMEI[1] TO UPDATE: 862xxxxxxxxx646 IMEI[2] TO UPDATE: 862xxxxxxxxx647 Generic IMEI OK Processing dinamic imei. IMEI[1] TO UPDATE: 862xxxxxxxxx646 IMEI[2] TO UPDATE: 862xxxxxxxxx647 Wait untill phone will start charging. [0]All done. All operations were successful with the Great NCK KING |
The Following User Says Thank You to Gsm-Ahmed For This Useful Post: |
