Micromax Q349 Frp Unlock Unsuccess. need help Read Info Code: Action : Boot Info. Code: Exe version: NCKBox AndroidMTK 2.1 Code: Exe version: NCKBox AndroidMTK 2.1 Code: Exe version: NCKBox AndroidMTK 2.1 Code: Flash files count is :4 all method try but frp remain not unlocked. |
This can meen read only emmc, or phone have another kind of lock, not frp. Based on logs, all is ok, and must work. |
Check emmc with another tool read write ok .. Phone show its frp lock . AFTER ALL OPERATION STILL SHOW THIS Code: Action : Boot Info. |
:) Sure In case of read only emmc will help only direct write-read checking. This so called "Check emmc with another tool read write ok .. Phone show its frp lock" will not help you with exactly nothing. Logic of all this is different and exactly why we not add this in our tool. It's not real in many cases. You have many posts in forum, i'am expected from you little more knowlege about how this work :confused: Anyway...if other tool say all ok with emmc, you can do frp reset with other tool. If with emmc is all ok, it must work. |
Just another question?? If emmc readonly them full flash will be complete or not.. Version change after flash mean emmc read only or emmc is good ? |
Code: Flash files count is :11 FYI: EMMC SEEMS GOOD FOR NOW :-D |
In emmc flash ic exists small microcontroler what handle all storage space and we not work with storage, we work with this microcontroler, and error reporting also is handled by this microcontroler. This is difference between nand and emmc. If on nand storage we will have error on read only block, here microcontroler can report write ok, but block will remain not changed or changed with random data. Your phone can have some so called bad blocks. And deppend where this blocks is located, phone can not start after flash. Or can start ok, here nobody can't say nothing 100%, only way to be sure 100% is to connect emmc to some jtag tool and check directly storage. On full flash it send repartition command, it can help or phone will return after some time with same problem. What meen this frp, if userdata checsum is ok, it was not changed, if we will modify somehow "not autorized" userdata, will be frp. Bad blocks also can cause this "not autorized" modification. |
Thank you sir . Please chang my post topic to unlock sucess.. |
