Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > NCK Team products > NCK Box
Old 10-25-2019, 09:27   #1 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 690
Micromax Q349 Frp Unlock Unsuccess. need help
Read Info
 Action : Boot Info.
 Selected 0-By CPU:ELBRUS
 Exe version: NCKBox AndroidMTK 2.1
 Reinsert phone battery.
 Battery must be charged.
 Phone must be off with battery inside.
 Please insert USB cable now...
 Detected : MediaTek PreLoader USB VCOM (Android) (COM109)
 Boot mode: Preloader
 BBCHIP: 6580 0 ca00
 Using Algo 1.
 Phone detected...Please wait
 Sending DA agent, please wait...
 BaseBand CPU :MT6580
 BaseBand CPU Secure Version : FF
 BaseBand CPU Bootloader Version : 01
 INT RAM: 128 KB SDRAM
 EXT RAM: 1 GB  DRAM
 EMMC: (58Gb+8192Mb) HYNIX 0x483847316505
 EMMC FW VERSION: 07:00:00:00:00:00:00:00
 EMMC CID: 90014A483847316505 : 00000000000000
 EMMC UA SIZE: 0x1d2000000
 BOOT STYLE: EMMC BOOT
 FULL LENGTH: 0x1d2c00000      [7.293 GB]
 Status: USB_HIGH_SPEED
 Detecting high speed port, wait......
 If driver not installed, install high speed port driver.
 If not need high speed port, disable it.
 After repeat opperation.
 Detected : MediaTek DA USB VCOM (Android) (COM110)
 Build ID: MRA58K
 Display ID: MMX_Q349_SW_V20_HW_V1.0_21072016
 Version: 6.0
 Build Date: Thu Jul 21 14:26:06 CST 2016
 Model: Micromax Q349
 Brand: Micromax
 Device: Q349
 Manufacturer: Micromax
 Mediatek Version Release: ALPS.W10.24.p0
 FRP partition: /dev/block/platform/mtk-msdc.0/11120000.msdc0/by-name/frp
 This phone have FRP partition.
 IMEI[1]: xxxxxxxxxxxxxxxxx
 IMEI[2]: xxxxxxxxxxxxxxxxx
 Wait untill phone will start charging.
 [0]All done.
Auto Reset FRP
 Selected model: 0-By CPU  ELBRUS
 [auto]Action: Reset FRP
 BBCHIP: 6580 0 ca00
 Using Algo 1.
 EXT RAM: 1 GB  DRAM
 Resetting userdata.
 Checking data, wait...
 Writing FRP, wait...
 FRP Reset Done.
 [0]All done.
Erase Mode Reset FRP
 [erase]Action: Reset FRP
 BBCHIP: 6580 0 ca00
 Using Algo 1.
 EXT RAM: 1 GB  DRAM
 Erasing FRP, wait...
 [2]FORMAT - BEGIN: 0x4fa0000        - LEN: 0x100000
 FRP Reset Done.
 [0]All done.
Write Mode Frp Reset
 [write]Action: Reset FRP
 BBCHIP: 6580 0 ca00
 Using Algo 1.
 EXT RAM: 1 GB  DRAM
 FRP Reset Done.
 [0]All done.
flash frp rest package
 Flash files count is :4
 Action : Firmware update.
 Selected Model: 0-By CPU: ELBRUS
 Scenario: [0]Safe Flash
 BBCHIP: 6580 0 ca00
 Using Algo 1.
 Scatter file loaded, not need emmi.
 EXT RAM: 1 GB  DRAM
C:\Users\user\Documents\Android_MTK\frp_reset_package\MT6580_EMMC_MRA58K__6_0_Micromax Q349_Micromax_xxxxxxxxxxxxx_10_25_2019_13_06_40\preloader_backup_25_10_2019_13_07\preloader_p4200.bin
 Backup preloader saved in firmware directory.
 Warning, flashing preloader disabled!
 If you change android version, preloader must be flashed.
 Starting flash.
 [0]All done.
all method try but frp remain not unlocked.
Old 10-25-2019, 10:01   #2 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 5,279
This can meen read only emmc, or phone have another kind of lock, not frp.
Based on logs, all is ok, and must work.
Old 10-25-2019, 10:13   #3 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 690
Check emmc with another tool read write ok .. Phone show its frp lock .
AFTER ALL OPERATION STILL SHOW THIS
 Action : Boot Info.
 BBCHIP: 6580 0 ca00
 Using Algo 1.
 EXT RAM: 1 GB  DRAM
 Build ID: MRA58K
 Version: 6.0
 Brand: Micromax
 Device: Q349
 IMEI[1]:
 IMEI[2]:
 [0]All done.
Old 10-25-2019, 10:25   #4 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 5,279
Sure
In case of read only emmc will help only direct write-read checking.
This so called "Check emmc with another tool read write ok .. Phone show its frp lock" will not help you with exactly nothing.
Logic of all this is different and exactly why we not add this in our tool.
It's not real in many cases.
You have many posts in forum, i'am expected from you little more knowlege about how this work
Anyway...if other tool say all ok with emmc, you can do frp reset with other tool.
If with emmc is all ok, it must work.
The Following User Says Thank You to orbita For This Useful Post:
Old 10-25-2019, 10:28   #5 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 690
Just another question?? If emmc readonly them full flash will be complete or not.. Version change after flash mean emmc read only or emmc is good ?
Old 10-25-2019, 10:39   #6 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 690
 Flash files count is :11
 BBCHIP: 6580 0 ca00
 Using Algo 1.
 EXT RAM: 1 GB  DRAM
C:\Users\user\Desktop\MMX_Q349_SW_V20_HW_V2.0_21072016\preloader_backup_25_10_2019_14_06\preloader_p4200.bin
 Starting flash.
 lk checksum is executing ...
 boot checksum is executing ...
 recovery checksum is executing ...
 logo checksum is executing ...
 secro checksum is executing ...
 system checksum is executing ...
 cache checksum is executing ...
 userdata checksum is executing ...
 [0]All done.
AFTER FULL FLASH FRP RESET DONE.. MAY BE FIRMWARE HAVE SOMETHING BETTER LOCK.
FYI: EMMC SEEMS GOOD FOR NOW :-D
Old 10-25-2019, 10:47   #7 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 5,279
In emmc flash ic exists small microcontroler what handle all storage space and we not work with storage, we work with this microcontroler, and error reporting also is handled by this microcontroler.
This is difference between nand and emmc.
If on nand storage we will have error on read only block, here microcontroler can report write ok, but block will remain not changed or changed with random data.
Your phone can have some so called bad blocks.
And deppend where this blocks is located, phone can not start after flash.
Or can start ok, here nobody can't say nothing 100%, only way to be sure 100% is to connect emmc to some jtag tool and check directly storage.
On full flash it send repartition command, it can help or phone will return after some time with same problem.
What meen this frp, if userdata checsum is ok, it was not changed, if we will modify somehow "not autorized" userdata, will be frp.
Bad blocks also can cause this "not autorized" modification.
Old 10-25-2019, 10:52   #8 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 690
Thank you sir . Please chang my post topic to unlock sucess..
Page generated in 0.31396 seconds with 7 queries
