05-30-2015, 13:40 | #1 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,211 | NCK BOX CDMA Module v2.8 Update Released - [30/05/2015] - Samsung Android - Backup/Wipe/Restore Partitions, Write Certificate, Write IMEI/MEID, Reset SPC, Write PRL - LG 6300 Full Support - Flashing (Normal/Emergency), Blink Repair, Write PRL/EFS, Write ESN/MEID - Alcatel 255c (May 01 2011) - Unlock / Flashing Samsung Android Backup/Wipe/Restore Partitions - You can Backup and Wipe any Partition you want. If you Tick "Do Not Wipe" Checkbox, it will only Backup Selected Partitions. Click on Get Partitions and it will list all the partitions with their names (if identified). Backup are saved in ZIP format, you can restore Backup anytime you want. Please note that all these functions need Root. These functions are not limited to Samsung only. You can use this function to keep backup of sensitive partitions. For example, for Reset EFS, you may need to Wipe EFS, FSG, FSC, MODEMST1 and MODEMST2 partitions. For safety reasons, it will always create backup when wiping a partition. Please note that you can Wipe any partition you select, so select partitions with EXTREME CAUTION. Write Certificate -You can write IMEI Certificate with UART Connection. It can also check Certificate Compatibility with KeyID from Certificate and Phone if KeyID data is saved in Certificate File. For now, it will try to Write Certificate even if KeyID mismatch. It will work only if MSL is default after Reset EFS. Write IMEI/MEID -You can write any IMEI/MEID of your choice. It will work only if MSL is default after Reset EFS. Only UART Connection is Supported. Reset SPC - Just connect phone with UART Cable and Reset SPC. - SPC will be restted to 222222 (Default after Reset EFS). Write PRL - You can write any PRL file. Please use Samsung Mobile Diagnostic Port to Write PRL. Others: -Enabled Emergency Mode Flashing for Alcatel 255c -Fixed Bug in Haier C380 Full Flashing in Normal Mode -Fixed Save Error on Read Flash for Phones having Special Characters in Hw Ver. -Added option to put RAW HEX frames with spaces i.e. (29 01 00) in Diagnostic Tool -Added option to Skip CRC Calculation for RAW Frames in Diagnostic Tool -Improved AllWinner IMEI Write Method -Changed and Improved AllWinner Remove Google Locks Method -Fixed False Failed Message for AllWinner ADB Wipe Method Download From SUPPORT AREA Official website: NCK BOX Follow us on twitter: https://twitter.com/NCKTeam & on Face Book https://www.facebook.com/nckteamproducts NO THNX POSTS OR SPAM POSTS PLEASE, ONLY DISCUSSION REGARDS THIS UPDATE OR TEST LOGS WITH RELATED MODELS. PS. PLEASE MAKE SURE YOU HAVE FULL INSTALLER INSTALLED FIRST THEN INSTALL NEW VERSION FULLY TO AVOID HAVING ISSUES. PS.2: Now You can see your activation date when you calculate any server based IMEI operation. |
The Following 30 Users Say Thank You to Fast Unlocking For This Useful Post: |
05-30-2015, 16:01 | #9 (permalink) |
No Life Poster Join Date: Feb 2013 Location: U.P-75 ETAWAH Age: 34
Member: 1889562 Status: Offline Thanks Meter: 617 | Module Ver. : 2.8 Com Port : ADB Interface Baud Rate : Not Applicable Device : Samsung Generic Operation : Read Info (ADB) Searching for Device... Device Found Model : SM-G350E Version : 4.4.2 Hardware : scx15 Baseband : G350EDDU0ANH1 SIM Card : ABSENT Type : GSM IMEI(1) : Null/Empty IMEI(2) : Null/Empty Root Status : Rooted Operation Finished. Elapsed Time: 00:06 Log saved as \!Log\LOG_15_05_30_20_31_19.log how to repair dual imei |
05-30-2015, 17:35 | #10 (permalink) |
No Life Poster Join Date: Jan 2013 Location: NCK Team
Member: 1873869 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,333 | For now, only first imei can be repaired. If phone is EFS Erased then you can write Certificate to get IMEI back. We will soon add more things. So have patience. Br, NCK Team |
The Following 2 Users Say Thank You to NCKCDMA For This Useful Post: |
05-31-2015, 10:30 | #13 (permalink) |
Member: 1873869 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,333 | You can wipe any partition you want, but use it with caution. If you wipe some critical partition, and phone does not connect over ADB, then you may not be able to Restore it. Br, NCK Team |
05-31-2015, 22:10 | #14 (permalink) |
Insane Poster Join Date: May 2015
Member: 2394513 Status: Offline Thanks Meter: 8 | im been blocked trying the update hi when i try to download the update your page block me entirely even my NCKBOX with this message Your connection to this server has been blocked in this server's firewall. You need to contact the server owner for further information. Your blocked IP address is 152.166.115.1 This server's hostname is please help i dont know whats wrong |
