10-16-2014, 11:56 | #1 (permalink) |
Freak Poster Join Date: Mar 2010
Member: 1271694 Status: Offline Thanks Meter: 15 | NCK BOX ERROR Card not found etc.. [ANSWERED] i have nck dongle and nck box in different locations, the dongle works absolutely fine however the box doesn't. . the box works fine when i first turn on the computer as it opens alright. it works fine as long as i calculate codes and use it constantly however after 10 mins or so inactivity the warning box appears automatically "Security Card not found" i checked windows task manager but there is nothing running in the background. the only solution is to restart the computer and open the software again....this cycle repeats. Another issue is that i can't copy paste imeis into the imei box using CTRL+V as it only works with right mouse click then paste... I never had these issues with the nck dongle. Last edited by Fast Unlocking; 10-16-2014 at 15:26. |
10-16-2014, 14:37 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Hi charikaar. For me this is like hardware damaged box. If box not have waranty, try to move security card from nckbox to nckdongle and check. If box have waranty, try to talk with reseller. |
10-16-2014, 14:42 | #3 (permalink) |
Member: 1271694 Status: Offline Thanks Meter: 15 | Thank you for your reply. I only bought the box Brand New less than 6 months ago from OrangeMobile ( www.gsmorange.com) so its still under warranty. I will contact my reseller. Thanks |
10-16-2014, 15:31 | #4 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,265 | the issue is not with box rather in your port loosing power on ideal so solution is simple , change port or use external usb hub with power supply, or just close software when u don t use , because i assure u that if orange mobile test it and it works fine then..... sure he will return to u also make sure box not tampered no opened screws etc... |
10-17-2014, 10:55 | #5 (permalink) |
Member: 1271694 Status: Offline Thanks Meter: 15 | He tell me [09:45:50] ORANGE Mobile®: U need buy new one I think there is one year manufacturer warranty with this box. All the screws are intact and nothing has been tampered with. These issues occurs on various laptops,port, hubs etc therefore I believe this to be genuine issue due to manufacturing defect. I kindly request replacement with NCK Dongle. Thanks |
11-26-2014, 17:49 | #6 (permalink) |
No Life Poster Join Date: Oct 2011 Location: ireland Age: 46
Member: 1670851 Status: Offline Thanks Meter: 267 | hi. recenlty ive had exactly same problems.. and my box is just over 1yr old and not covered by resellers warranty anymore.. so what i did was, ive opened up the box, cleaned up a bit contacts on card and put card back.. since then works like a charm |
10-24-2016, 19:40 | #8 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Main module work with buth nckdongle and nckbox. Android mtk not. If user have nckdongle, must be used nckdongle exe. If user have nckbox, need to use nckbox exe. I'am checked personally with many users and this is most common mistake maked. If nckbox user will use nckdongle exe, error will be exactly this , smart card not found. If nckdongle user will use nckbox exe, error will be exactly this , smart card not found. Last edited by orbita; 10-24-2016 at 19:46. |
